[petsc-users] GAMG and linear elasticity
Umut Tabak u.tabak at tudelft.nl
Sun Sep 1 11:12:57 CDT 2013
On 09/01/2013 06:01 PM, Tabrez Ali wrote:
> Mark/Umut
> Here's the code http://defmod.googlecode.com/
> If you have PETSc installed with METIS then you can build the
> executable simply by running "make all PETSC_DIR=/home/user/petsc"
> The three meshes that I am testing GAMG on are available at
> http://www.geology.wisc.edu/~stali/defmod/gamg_test_input_files.tar.gz
Thanks for this information, BTW, is that software you are using for
visualization is Mayavi2?
