[petsc-users] Slepc installation
Wed Mar 27 23:48:49 CDT 2013
On Thu, 28 Mar 2013, Sonya Blade wrote:
> DEar All,
> Here is out put from Python console after runing teh suggested Python code script.
> >>> import os
> >>> print os.path.realpath(os.getcwd())
> C:\Python27
> >>> print os.path.realpath(os.environ['SLEPC_DIR'])
> D:\TEST_FOLDER_dell\slepc
You should be using cygwin python here from cygwin-shell [as per the
installation instructions]- not MS-Python [console].
> Interesting thing here is, why Python script returns the
> backslashed path although I'm sure that I set it in
> environmental  variables as forward slashed path.
> And here is the output from the CygWin terminal
> nobody at nobody /cygdrive/d/TEST_FOLDER_dell/slepc
> $ export SKPEC_DIR=D:/TEST_FOLDER_dell/slepc/
See the cygwin path above in your bash prompt? Thats what you should be using.
Also you have a typo for SLEPC_DIR
export SLEPC_DIR=/cygdrive/d/TEST_FOLDER_dell/slepc
Satish
> $ ./configure
> Checking environment...
> cygwin warning:
>   MS-DOS style path detected: D:/TEST_FOLDER_dell/slepc
>   Preferred POSIX equivalent is: /cygdrive/d/TEST_FOLDER_dell/slepc
>   CYGWIN environment variable option "nodosfilewarning" turns off this warning.
>   Consult the user's guide for more details about POSIX paths:
>     http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
> ERROR: SLEPC_DIR is not the current directory
> Your help will be appreciated,
