[petsc-users] Partitioning and AO problem
"Miguel A. Fernández" miguel.fernandez at inria.fr
Tue Mar 26 08:42:59 CDT 2013
Thanks for your quick reply.
>> I'm using Petsc interface to ParMetis, as detailed in section 3.5 of the user's manual.
>> I have a problem with the creation of the AO mapps using the sentence
>> AOCreateBasicIS(isg,PETSC NULL,&ao);
> This line in the user's manual is incorrect. See Section 2.3.1 for a
> proper explanation.
OK, good to know ;).
>> where isg contains for each local node the new global (petsc) number of that node.
>> The problem is that the resulting AO map is inverted, and hence the results obtained with
>> AOApplicationToPetsc and AOPetscToApplication are not correct.
> You have the arguments backward.
Yes, I agree, and this explains why the ApplicationToPetsc and PetscToApplication maps are inverted.
The problem is that you can neither call AOCreateBasicIS(PETSC_NULL,isg,&ao);
since it seems that PETSC_NULL is only allowed in the second argument.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/AOCreateBasic.html
> It's not clear from your description above whether you have an
> "application ordering" or just a local to global map.
I have an application ordering and a petsc ordering, both global, in the spirit of Section 2.3.1.
Here, the application ordering is the natural ordering (0, 1, 2, … ), resulting from a simple distribution
of the nodes across processors, before partition with ParMetis.
Best,
Miguel
INRIA Paris - Rocquencourt
Building 16, office 11
78153 Le Chesnay Cedex (France)
phone: +33 (0)1 3963 5470
fax: +33 (0)1 3963 5882
www-rocq.inria.fr/who/Miguel.Fernandez
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130326/16f995dc/attachment-0001.html>
