[petsc-users] Partitioning and AO problem
Tue Mar 26 08:19:01 CDT 2013
"Miguel A. Fernández" <miguel.fernandez at inria.fr> writes:
> Dear all,
> I'm using Petsc interface to ParMetis, as detailed in section 3.5 of the user's manual.
> I have a problem with the creation of the AO mapps using the sentence
> AOCreateBasicIS(isg,PETSC NULL,&ao);
This line in the user's manual is incorrect. See Section 2.3.1 for a
proper explanation.
> where isg contains for each local node the new global (petsc) number of that node.
> The problem is that the resulting AO map is inverted, and hence the results obtained with
> AOApplicationToPetsc and AOPetscToApplication are not correct.
You have the arguments backward.
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/AOCreateBasic.html
It's not clear from your description above whether you have an
"application ordering" or just a local to global map.
