[petsc-users] Eigenvalue solver method in Petsc
Sun Mar 17 17:43:47 CDT 2013
On Mar 17, 2013, at 5:42 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sun, 17 Mar 2013, Barry Smith wrote:
>>>> On Mar 17, 2013, at 3:51 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> On Sun, 17 Mar 2013, Sonya Blade wrote:
>>>>>>>>> Cygwin is required to build PETSc, but not to use it.
>>>>>>>> How about the MSys interface, which I've already installed.
>>>>>>> Not currently, as far as I know.
>>>>>>> whats your compiler requirement? And why?
>>>>>> I use gfortran which ships with MinGW and with Msys I feel more
>>>>>> comfortable.
>>>>> Are you looking at sequential use of PETSc - or parallel? I see mpich
>>>>> doesn't work with msys/mingw.
>>>>  And why not.
>>> Sorry - forgot to post this link.
>>> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-July/007458.html
>>>> It is far more natural than cygwin.
>>> How so? Even python [which is now considered a universal requirement?] doesn't compile on it.
>>  Why compile python? Windows already has a perfectly good python to use.
> Our build tools don't work with MS paths.
   Buildsystem does, as does cmake. Which ones don't work?
  Barry
> Satish
>>> Satish
>>>>> You can try an install of petsc with msys - and see if it works. If not send
>>>>> us logs at petsc-maint.
>>>>> [its possible things won't work - and you would have to use
>>>>> cygwin/gfortran. Presumably it shouldn't conflict with your msys
>>>>> install]
>>>>> Satish
