[petsc-users] possible error
Nachiket Gokhale gokhalen at gmail.com
Thu Mar 14 14:37:47 CDT 2013
> Message: 5
> Date: Thu, 14 Mar 2013 11:49:06 -0700
> From: Randall Mackie <rlmackie862 at gmail.com>
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] possible error
> Message-ID: <BE1D9C27-B333-423F-BB61-7519A7F7910D at gmail.com>
> Content-Type: text/plain; charset=us-ascii
> Nachiket,
> I've run into a similar situation before, where my code ran fine in debug mode, bombed out with segmentation violation
> in optimize mode, and yet I couldn't find anything in valgrind. In my case, I eventually tracked it down to some variable
> not being broadcast to all processors, and so that variable would often take some weird value on some processor.
> I tracked it down by putting in a goto statement (that would go to the end of the code and PetscFinalize) early in my code,
> and if it ran fine, then I'd move the goto statement down further in the code, and then keep moving it
> until the program bombed, and this helped me track it down the issue. Also, if you run on just 1 processor do you see the same
> behavior?
> Randy M.
Hi Randy,
Thanks for your message. I see the same behavior on one processor.
I'm upgrading gcc right now; if that does not fix it - I will try to
track it down using your method.
-Nachiket
