[petsc-users] ISGetIndicesF90
Thu Mar 14 01:25:05 CDT 2013
Did you include 'petscis.h90' [or petsc.h90] in your code?
Do the examples ex1f90.F and ex3f90.F in
src/vec/is/is/examples/tutorials work for you?
Satish
On Wed, 13 Mar 2013, George Pau wrote:
> Hi,
> I am getting the following error when I used the above subroutine:
> Fortran runtime error: Pointer actual argument 'idx_ptr' is not associated
> The following is how the subroutine is called:
> IS :: is_global
> PetscScalar, pointer :: idx_ptr(:)
> PetscErrorCode :: pierr
> call ISGetIndicesF90(is_global,idx_ptr,pierr)
> I read on the command reference page that it doesn't work with some fortran
> compiler.  I have gfortran 4.6.3 on Ubuntu machine.  Could my fortran be
> the problem? I have tested ISGetIndices and it works. I really want to use
> ISGetIndicesF90 instead of ISGetIndices since I cannot do bound check with
> the later.
> Thanks,
> George
