[petsc-users] Numbering of DMPlexGetCellNumbering
Sat Mar 9 15:57:24 CST 2013
On Thu, Mar 7, 2013 at 3:56 PM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
> Hi,
> For an small distributed unstructured mesh  with overlap 1
> which is *not* interpolated yet, if I do a DMPlexGetCellNumbering()
> I obtain an IS as follows:
> [0] Number of indices in set 6
> [0] 0 -6
> [0] 1 0
> [0] 2 -8
> [0] 3 1
> [0] 4 2
> [0] 5 3
> [1] Number of indices in set 6
> [1] 0 4
> [1] 1 5
> [1] 2 6
> [1] 3 -1
> [1] 4 7
> [1] 5 -4.
> Running the same example but by DMPlexInterpolate() and then
> DMPlexGetCellNumbering() provides instead the output:
> [0] 0 0
> [0] 1 1
> [0] 2 2
> [0] 3 3
> [0] 4 4
> [0] 5 5
> [1] 0 6
> [1] 1 7
> [1] 2 8
> [1] 3 9
> [1] 4 10
> [1] 5 11
There is something wrong with this result. It has to do with the order in
which you created
things. Right now, I do not have DMInterpolate() update the communication
structures, since
it would involve coordination between processes. Thus you should call
DMInterpolate()
before DMDistribute().
     Matt
> The former result I find very useful since it provides the number of
> ghost cells on each processor (the negative IS values) and moreover
> the negative IS values also indicate the global numbering of the
> ghost cells. Eg: On the first processor the cell 0 is a ghost cell with
> its global numbering 5.
> The behavior of DMPlexGetCellNumbering() after the interpolation does
> not bother me but I would like to know in the former case if the output
> is the right output i.e, it is not merely a side effect which might get
> changed later on.
> Thank You.
> Regards,
> Garnet
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130309/7947bf70/attachment.html>
