[petsc-users] Using PETSc with CMake on Windows
John Fettig john.fettig at gmail.com
Fri Mar 8 14:54:49 CST 2013
Looking through the mailing list archives, I found a pointer to Jed's
CMake module FindPETSc.cmake.  Has this been tested on windows?
Should this work when PETSc has been installed via make install?  The
directions given at the end of that say
Install complete. It is useable with
PETSC_DIR=/path/to/my/petsc/install [and no more PETSC_ARCH].
Now to check if the libraries are working do (in current directory):
make PETSC_DIR=/path/to/my/petsc/install test
However, when I only set PETSC_DIR, CMake bails with
CMake Error at FindPETSc.cmake:118 (message):
  The pair
  PETSC_ARCH= do not specify a valid PETSc installation
Call Stack (most recent call first):
  CMakeLists.txt:9 (include)
-- PETSc could not be found.  Be sure to set PETSC_DIR and PETSC_ARCH.
(missing:  PETSC_INCLUDES PETSC_LIBRARIES PETSC_EXECUTABLE_RUNS)
Thanks for any help,
John
