[petsc-users] DMPlex Fortran examples
Dharmendar Reddy dharmareddy84 at gmail.com
Tue Mar 5 01:18:13 CST 2013
Hello,
         Trying to understand the DMPlexCreateSection first. I have created
a test case, can you please have a look at it? Actually the code has a link
error on my system with petsc-dev.  I used DMPlexeCreateBoxMesh to create
the mesh. Looks like there is no Fortran interface to that function. If i
comment out the dmplexcreateboxmesh. It does create and executable.
petscDMTest_v2.o: In function `MAIN__':
petscDMTest_v2.F90:(.text+0x9b): undefined reference to
`dmplexcreateboxmesh_'
make: [testDMMeshv2] Error 1 (ignored)
Also, If include finclude/petsc.h90 instead of finclude/petsch.h i get
compile error :
petscDMTest_v2.F90(73): error #6691: A pointer dummy argument may only be
argument a
ssociated with a pointer.   [NUMCOMP]
  call DMPlexCreateSection(dmMesh, topologyDim, numField, numComp, numDof, &
argument a
ssociated with a pointer.   [NUMDOF]
petscDMTest_v2.F90(74): error #6691: A pointer dummy argument may only be
argument a
ssociated with a pointer.   [BCFIELD]
                           numBC, bcField, bcPointIS,section,ierr)
argument a
ssociated with a pointer.   [BCPOINTIS]
Please have a look at the attached test case and Makefile
On Mon, Mar 4, 2013 at 7:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 4, 2013 at 7:50 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>wrote:
>> Hello,
>>          Is there a DMPlex based fortran example for solving a pde such
>> as laplace ? Even a c example will do. I am not able to understand the
>> terminology of chart, cone etc. Is there a paper or user guide to learn
>> more about the definitions of terms such as chart cone stratum ? I remember
>> reading a presentation file by mathew about sieve. Is there a newer
>> tutorial with terminology mapped to the new DMPlex/DMMesh functions.
> There is a fully worked out Stokes example (SNES ex62) and a Finite Volume
> example (TS ex11),
> and there are a few tests. You should not need much of that stuff for
> defining a problem. I am
> writing up a paper about ex11 right now. There is a short manual section
> on unstructured grids as well.
> I think the key thing to understand is how to define a data layout over
> the mesh using a PetscSection.
> Once that is done, all the DM functions work as normal, and the last hard
> part is coding your residual
> loop. I have support for FEM schemes, but its undocumented and slightly
> complex in order to allow
> GPU assembly, so you may be more comfortable with your own element loop to
> start.
>   Thanks,
>      Matt
>> Thanks
>> Reddy
>> Dharmendar Reddy Palle
>> Graduate Student
>> Microelectronics Research center,
>> University of Texas at Austin,
>> 10100 Burnet Road, Bldg. 160
>> MER 2.608F, TX 78758-4445
>> e-mail: dharmareddy84 at gmail.com
>> Phone: +1-512-350-9082
>> United States of America.
>> Homepage: https://webspace.utexas.edu/~dpr342
> experiments lead.
> -- Norbert Wiener
Graduate Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130305/cc0727ed/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130305/cc0727ed/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130305/cc0727ed/attachment-0001.obj>
