[petsc-users] DMMeshCreateMeshFromAdjacency
Dharmendar Reddy dharmareddy84 at gmail.com
Sat Mar 2 19:54:04 CST 2013
As you said, I do not need, PETSC_USE_FORTRAN_INTERFACES. The interface to
dmmeshcreatefromadjacency is not defined in
finclude/ftn-custom/petscdmmesh.h90
it is only defined in
finclude/ftn-auto/petscdmmesh.h90
On Sat, Mar 2, 2013 at 7:51 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>wrote:
> Hello,
>         Sorry, I was going to create a test case. Anyways here is the
> error message
> petscDMTest_v2.o: In function `MAIN__':
> petscDMTest_v2.F90:(.text+0x354): undefined reference to
> `dmmeshcreatemeshfromad
> jacency_'
> make: [testDMMesh] Error 1 (ignored)
> I have attached a test case and makefile.  make all should gen rate the
> executable.
> Thanks
> Reddy
> On Sat, Mar 2, 2013 at 7:10 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Sat, 2 Mar 2013, Dharmendar Reddy wrote:
>> > Hello,
>> >         I am trying to use DMMeshCreateMeshFromAdjacency in a Fortran
>> code.
>> > I get undefined reference error.
>> What error? please copy/paste
>> > I include the following file in my program
>> > #include "finclude/petsc.h90"
>> > I see that fortran interface to DMMeshCreateMeshFromAdjacency is defined
>> > only in
>> > I am not able to figure out if PETSC_USE_FORTRAN_INTERFACES is defined.
>> I
>> > did not compile the code. I am runing the code on TACC stampede. I tried
>> > adding
>> > #define PETSC_USE_FORTRAN_INTERFACES 1
>> > in my program before the petsc inlcude line but i still get error.
>> 1. again 'get error' doesn't tell us anything.
>> And you shouldn't need PETSC_USE_FORTRAN_INTERFACES to use
>> Satish
>> > Thanks
>> > Reddy
> Dharmendar Reddy Palle
> Graduate Student
> Microelectronics Research center,
> University of Texas at Austin,
> 10100 Burnet Road, Bldg. 160
> MER 2.608F, TX 78758-4445
> e-mail: dharmareddy84 at gmail.com
> Phone: +1-512-350-9082
> United States of America.
> Homepage: https://webspace.utexas.edu/~dpr342
Graduate Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130302/1bf40d4f/attachment.html>
