[petsc-users] How to understand these error messages
Tue Jun 25 15:15:18 CDT 2013
On Jun 25, 2013, at 5:09 AM, Fande Kong <fd.kong at siat.ac.cn> wrote:
> Hi Barry,
> If I use the intel mpi, my code can correctly run and can produce some correct results. Yes, you are right. The IBM MPI has some bugs.
    Thanks for letting us know.
   Barry
> Thank you for your help.
> Regards,
> On Tue, Jun 25, 2013 at 11:08 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 25 Jun 2013, Fande Kong wrote:
> > Hi Barry,
> > How to use valgrind to debug parallel program on the supercomputer with
> > many cores? If we follow the instruction "mpiexec -n NPROC valgrind
> > --tool=memcheck -q --num-callers=20 --log-file=valgrind.log.%p
> > PETSCPROGRAMNAME -malloc off PROGRAMOPTIONS",  for 10000 cores, 10000 files
> > will be printed. Maybe we need to put all information into a single file.
> > How to do this?
> For this many cores - the PIDs across nodes won't be unique. It might
> map over to say 1000 files - so I suggest [assuming $HOSTNAME is set
> on each host]
> --log-file=valgrind.log.%q{HOSTNAME}.%p
> You don't want to be mixing output from all the cores - then it would
> be unreadable.
> But if your filesystem cannot handle these many files - you could try
> consolidating output per node as:
> [or perhaps create a subdir per node or something - and stash files in
> these dirs]
> for each hostname: mkdir -p ${HOSTNAME}
> --log-file=%q{HOSTNAME}/valgrind.log.%p
> Satish
> Fande Kong
> ShenZhen Institutes of Advanced Technology
> Chinese Academy of Sciences
