[petsc-users] MatMatMult size error
Hong Zhang hzhang at mcs.anl.gov
Wed Jun 19 09:38:27 CDT 2013
Glad to know the problem is fixed in the release.
Report to us whenever you encounter problem in using PETSc.
Hong
On Wed, Jun 19, 2013 at 12:21 AM, Jim Fonseca <jefonseca at gmail.com> wrote:
> Hi Hong,
> It's been a while but we have found that moving to PETSc3.4 solved this
> problem with MatMatMult() in PETSc3.3p5.
> Thanks,
> Jim
> On Tue, Jan 15, 2013 at 4:43 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>> Jim :
>> Can you switch to petsc-dev? MatMatMult()
>> has been updated significantly in petsc-dev
>> If you still see problem in petsc-dev, send us a short code that
>> produce the error. We'll check it.
>> Hong
>> > Hi,
>> > We are in the process of upgrading from Petsc 3.2 to 3.3p5.
>> > We are creating  matrices A and B in this way.
>> >       petsc_matrix = new Mat;
>> >       ierr = MatCreateDense(comm, m, num_cols
>> ,num_rows,num_cols,data,A);
>> > Elsewhere, we have this. It gets called a few times, and on the 4th
>> time,
>> > the size of matrix is C is wrong. Please see the output below. What
>> could be
>> > the problem?
>> >      C = new Mat;
>> >      double fill = PETSC_DEFAULT;
>> >      MatMatMult(A,B,MAT_INITIAL_MATRIX, fill, C);
>> >        int m,n;
>> >        MatGetOwnershipRange(A, &m, &n);
>> >        cerr << "A.m = " <<  m << "\n";
>> >        cerr << "A.n = " <<  n << "\n";
>> >        MatGetSize(A,&m,&n);
>> >        cerr << "A global rows = " <<  m << "\n";
>> >        cerr << "A global cols = " <<  n << "\n";
>> >        MatGetOwnershipRange(B, &m, &n);
>> >        cerr << "B.m = " <<  m << "\n";
>> >        cerr << "B.n = " <<  n << "\n";
>> >        MatGetSize(B,&m,&n);
>> >        cerr << "B global rows = " <<  m << "\n";
>> >        cerr << "B global cols = " <<  n << "\n";
>> >        MatGetOwnershipRange(*C, &m, &n);
>> >        cerr << "C.m = " <<  m << "\n";
>> >        cerr << "C.n = " <<  n << "\n";
>> >        MatGetSize(*C,&m,&n);
>> >        cerr << "C global rows = " <<  m << "\n";
>> >        cerr << "C global cols = " <<  n << "\n";
>> > A.m = 0
>> > A.n = 59
>> > A global rows = 59
>> > A global cols = 320
>> > B.m = 0
>> > B.n = 320
>> > B global rows = 320
>> > B global cols = 320
>> > C.m = 0
>> > C.n = 59
>> > C global rows = 59
>> > C global cols = 320
>> > A.m = 0
>> > A.n = 59
>> > A global rows = 59
>> > A global cols = 320
>> > B.m = 0
>> > B.n = 320
>> > B global rows = 320
>> > B global cols = 59
>> > C.m = 10922
>> > C.n = -1389327096
>> > C global rows = -1389327112
>> > C global cols = -1389327112
>> > Thanks,
>> > Jim
>> > Jim Fonseca, PhD
>> > Research Scientist
>> > Network for Computational Nanotechnology
>> > Purdue University
>> > 765-496-6495
>> > www.jimfonseca.com
> Jim Fonseca, PhD
> Research Scientist
> Purdue University
> 765-496-6495
> www.jimfonseca.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130619/3a7fdf33/attachment-0001.html>
