[petsc-users] [Need Help] Time dependent split operator method
Dharmendar Reddy dharmareddy84 at gmail.com
Wed Jun 12 16:08:28 CDT 2013
Hello,
           I am trying to implement a split operator method to solve time
dependent Schrodinger euqation. I use a semi implicit discretization for
the time operator. I have not used petsc TS before, it will be helpful  if
you can give me some pointers to implementing this algorithm:
Actual equation:   i*hbar*ddt(x) = (H1+H2)*x  (linear problem)
A1 = i*hbar/dt * IdentityMat -  H1/2
B1 = i*hbar/dt * IdentityMat + H2/2
A2 = i*hbar/dt * IdentityMat  - H2/2
B2 = i*hbar/dt * IdentityMat + H1/2
x1,x2 are vectors
do ic=1,NumTimeSteps
  solve substep1 :   A1*x1 = B1*x2
  solve substep2 :   A2*x2 = B2*x1
   copy solution:  x(ic*dt) = x2
end do
I have following constraints:
1.) I Want the time step to be fixed user specified value
2.) Matrices A1 and A2 can be reorder to be tri or penta diagonal. I would
like to use this for fast direct solve. Typical matrix sizes 10^5 to 10^6
with 3 to 5 non zeros per row.
3.) based on the time it take for my matlab code, which seem to use
umfpack, i think a direct solve will be fast enough for my needs.
petsc TS has the theta method which seems like the one i should be using
but its not clear to me how to do the stepping
Thanks
Reddy
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130612/2b85f9a6/attachment.html>
