[petsc-users] FEM on 2D poisson equation
Olivier Bonnefon olivier.bonnefon at avignon.inra.fr
Tue Jul 30 09:06:24 CDT 2013
Hello,
I want to use PETSC for large problem about diffusive model in
epidemiological field.
I'm using the slides 'Advanced PETSc Tutorial, Maison de la Simulation,
Orsay, France, June 2013 (Matt)'.
My first step is to simulated a problem 0=-\nabla u + f(u), where f is a
linear or non-linear function, with FEM. To do this I'm adapting the
example ex12.c for the linear problem:
0=-\nabla u + w*w*u
with the exact solution u(x,y)=exp(w*x)+exp(w*y). The Dirichlet boundary
condition are defined from the exact solution, like in example ex12.
To do this, I change only the two following functions:
double WW=1.0;
void quadratic_u_2d(const PetscReal x[], PetscScalar *u)
   *u = exp(WW*(x[0])) +exp(WW*(x[1]))  ;
void f0_u(const PetscScalar u[], const PetscScalar gradU[], const
PetscReal x[], PetscScalar f0[])
   const PetscInt Ncomp = NUM_BASIS_COMPONENTS_0;
   PetscInt       comp;
   for (comp = 0; comp < Ncomp; ++comp) f0[comp] = WW*WW*u[comp] ;
The result is :
$ ./ex12 -refinement_limit 0.01 -snes_monitor_short -snes_converged_reason
   0 SNES Function norm 22.1518
   1 SNES Function norm 0.364312
   2 SNES Function norm 0.0165162
   3 SNES Function norm 0.000792446
   4 SNES Function norm 3.81143e-05
   5 SNES Function norm 1.83353e-06
   6 SNES Function norm 8.8206e-08
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 6
Number of SNES iterations = 6
L_2 Error: 0.00511
Something is wrong because it is a linear problem, why the snes didn't
converge in one iteration ?
Thanks a lot.
Olivier B
On 07/18/2013 03:39 PM, Olivier Bonnefon wrote:
> On 07/18/2013 03:26 PM, Matthew Knepley wrote:
>> On Thu, Jul 18, 2013 at 8:17 AM, Olivier Bonnefon
>> <olivier.bonnefon at avignon.inra.fr
>> <mailto:olivier.bonnefon at avignon.inra.fr>> wrote:
>>     It is what I wanted, it works.
>>     If I well understand the code, ex12.h contains the P1
>>     implementation. To simulate an other system, with time
>>     dependences for examples (du/dt), I have to adapt the plugin
>>     functions.
>> The way I would add time dependence is to convert this from a SNES
>> example into a TS example. I can help you
>> do this since I want to start using TS by default. Does this sound
>> reasonable?
> Yes, of course. My goal is to simulate diffusive equation with non
> linear sources, for example Lotka-Voltera competion.
> Olivier B
>>   Thanks,
>>      Matt
>>     Thanks a lot.
>>     Olivier B
>>     On 07/18/2013 01:12 PM, Matthew Knepley wrote:
>>>     On Thu, Jul 18, 2013 at 5:08 AM, Olivier Bonnefon
>>>         Hello,
>>>         I have a 2-d heat equation that I want to simulate with
>>>         Finit Element Method, to do this, I'm looking for an example
>>>         solving 2D poisson equation with FEM (DMDA or DMPlex). Is
>>>         there an example like this ?
>>>     There is, but there it is still somewhat problematic. I use FIAT
>>>     to generate the basis function tabulation,
>>>     so you have to configure with
>>>       --download-fiat --download-scientificpython --download-generator
>>>     and you need mesh generation and partitioning
>>>       --download-triangle --download-chaco
>>>     and then you can run SNES ex12 using Builder (which will make
>>>     the header file)
>>>       python2.7 ./config/builder2.py check
>>>     src/snes/examples/tutorials/ex12.c
>>>     Jed and I are working on an all C version of tabulation which
>>>     would mean that you could bypass
>>>     the Python code generation step. Once the header is generated
>>>     for the element you want, then
>>>     you can just run the example as normal.
>>>         Matt
>>>         Thanks a lot.
>>>         Olivier Bonnefon
>>>         Olivier Bonnefon
>>>         INRA PACA-Avignon, Unité BioSP
>>>         Tel: +33 (0)4 32 72 21 58
>>>         <tel:%2B33%20%280%294%2032%2072%2021%2058>
>>>     What most experimenters take for granted before they begin their
>>>     experiments is infinitely more interesting than any results to
>>>     which their experiments lead.
>>>     -- Norbert Wiener
>>     Olivier Bonnefon
>>     Tel:+33 (0)4 32 72 21 58  <tel:%2B33%20%280%294%2032%2072%2021%2058>
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
> Olivier Bonnefon
Olivier Bonnefon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130730/fd06191c/attachment.html>
