[petsc-users] FEM on 2D poisson equation
Olivier Bonnefon olivier.bonnefon at avignon.inra.fr
Thu Jul 18 08:39:29 CDT 2013
On 07/18/2013 03:26 PM, Matthew Knepley wrote:
> On Thu, Jul 18, 2013 at 8:17 AM, Olivier Bonnefon
> <olivier.bonnefon at avignon.inra.fr
> <mailto:olivier.bonnefon at avignon.inra.fr>> wrote:
>     It is what I wanted, it works.
>     If I well understand the code, ex12.h contains the P1
>     implementation. To simulate an other system, with time dependences
>     for examples (du/dt), I have to adapt the plugin functions.
> The way I would add time dependence is to convert this from a SNES
> example into a TS example. I can help you
> do this since I want to start using TS by default. Does this sound
> reasonable?
Yes, of course. My goal is to simulate diffusive equation with non
linear sources, for example Lotka-Voltera competion.
Olivier B
>   Thanks,
>      Matt
>     Thanks a lot.
>     Olivier B
>     On 07/18/2013 01:12 PM, Matthew Knepley wrote:
>>     On Thu, Jul 18, 2013 at 5:08 AM, Olivier Bonnefon
>>         Hello,
>>         I have a 2-d heat equation that I want to simulate with Finit
>>         Element Method, to do this, I'm looking for an example
>>         solving 2D poisson equation with FEM (DMDA or DMPlex). Is
>>         there an example like this ?
>>     There is, but there it is still somewhat problematic. I use FIAT
>>     to generate the basis function tabulation,
>>     so you have to configure with
>>       --download-fiat --download-scientificpython --download-generator
>>     and you need mesh generation and partitioning
>>       --download-triangle --download-chaco
>>     and then you can run SNES ex12 using Builder (which will make the
>>     header file)
>>       python2.7 ./config/builder2.py check
>>     src/snes/examples/tutorials/ex12.c
>>     Jed and I are working on an all C version of tabulation which
>>     would mean that you could bypass
>>     the Python code generation step. Once the header is generated for
>>     the element you want, then
>>     you can just run the example as normal.
>>         Matt
>>         Thanks a lot.
>>         Olivier Bonnefon
>>         Olivier Bonnefon
>>         INRA PACA-Avignon, Unité BioSP
>>         Tel: +33 (0)4 32 72 21 58
>>         <tel:%2B33%20%280%294%2032%2072%2021%2058>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
>     Olivier Bonnefon
>     Tel:+33 (0)4 32 72 21 58  <tel:%2B33%20%280%294%2032%2072%2021%2058>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
Olivier Bonnefon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130718/874ec63a/attachment-0001.html>
