[petsc-users] PCSHELL
Su Yan suyan0 at gmail.com
Thu Jul 25 16:04:25 CDT 2013
Thanks, Barry.
I have interfaced PETSc with MKL ILUT preconditioner through PCSHELL, but
want to use reordering technique comes with the PETSc package. Probably I
can do it by extracting the reordering matrices, but the system matrix is
the Jacobian set by SNESSetJacobian() and solved by KSP. Since the Jacobian
matrix is changing for different Newton steps, I am strill trying to figure
out how to implement the reordering my self.
Best,
Su
On Thu, Jul 25, 2013 at 3:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jul 25, 2013, at 12:01 PM, Su Yan <suyan0 at gmail.com> wrote:
> > Hi, can I use PCSetType(myPC, PCSHELL); together with
> PCFactorSetMatOrderingType(myPC, MATORDERINGRCM)?
>    PCFactorSetMatOrdering() is only effective if the PC is a subclass of
> PCFactor, for example PCLU is a subclass of PCFactor as are PCILU and
> PCCHOLESKY and PCICC
>    If you want to use things like this you cannot use PCSHELL (which is a
> subclass of only the basic PC) you can copy the code for PCCreate_LU() for
> example and modify it for what you want to do.  Or you can register new
> factorization and solver package as a MatSolverPackage; see for example
> superlu.c in mat/impls/aij/seq/superlu/
>    What is it you want to do?
>    Barry
> > Will the reordering still take effect?
> > Thanks,
> > Su
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130725/a241b485/attachment.html>
