[petsc-users] Using GAMG to speed up solving of Poisson eqn
Mark F. Adams mfadams at lbl.gov
Thu Jul 25 13:48:16 CDT 2013
>> -poisson_ksp_monitor -poisson_pc_gamg_verbose
"verbose" takes an integer so give it > 0.  0 is the default.  But getting a stack trace in the debugger is much better.
Does this code run correctly with simple default (ILU) preconditioning?  As I recall you were getting floating point exceptions when computing the extreme eigen values.  Try running with ILU and add -poisson_ksp_monitor_singular_value to see if this a general problem or a GAMG specific problem.
