[petsc-users] Zero pivot in LU factorisation
Toby T.W.Searle at sms.ed.ac.uk
Thu Jul 25 06:37:07 CDT 2013
Hi Jose,
Thanks for the help.
I am sure my matrix is non-singular because I have used the eigenvalue
solver from scipy for this particular problem. I can send you the
spectrum if that would be helpful.
  -st_type sinvert with -eps_target -0.2 (which is where a large number
of eigenvalues ought to be) does not work either. Similar to before I get:
piexec ./ex7 -f1 LHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc  -f2
RHS-N7-M40-Re0.0-b0.1-Wi5.0-amp0.02.petsc -st_type sinvert -eps_target -0.2
Generalized eigenproblem stored in file.
  Reading COMPLEX matrices from binary files...
Read in matrices...
Creating Eigensolver...
Solving system...
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Detected zero pivot in LU factorization:
see http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot!
[0]PETSC ERROR: Zero pivot row 0 value 0 tolerance 2.22045e-14!
[0]PETSC ERROR:
Kind Regards,
Toby
On 25/07/2013 11:44, Jose E. Roman wrote:
> The default is to solve as B^{-1} A x = lambda x
> With -st_type sinvert -eps_target 0  then it is solved as A^{-1} B x = theta x
> The latter is probably what you need (or with a different target). Are you sure your A-matrix is non-singular?
> Jose
> El 25/07/2013, a las 11:38, Toby escribió:
>> Dear all,
>> I have a generalised matrix problem: A x = lambda B x. My matrix B is diagonal and positive semi-definite. My matrix A is a non-hermitian complex matrix.
>> My problem is essentially that when using the SLEPc generalised eigenvalue solver I get the error "zero pivot in LU factorisation". The rest of the below is details about the problem and things I have tried so far.
>> The matrix will be at its largest about 48000 by 48000, and I want to find the eigenvalues. The eigenvalues I am interested in are ones with the largest real part near 0+0i. Ideally, I want to be able to find them even if they are internal (i.e when there are other eigenvalues with larger positive real part in the spectrum). However, I would be happy if I could get it to work for problems where all eigenvalues have real parts < 0 apart from the eigenvalue of interest.
>> At the moment I have used the scipy linalg.eig and sparse.eigs functions. As far as I know, these use LAPACK and ARPACK respectively to do the heavy lifting. I have decided to see if I can achieve better performance through using the SLEPc library. If this is a bad decision, let me know!
>> I want to move onto using PETSc with the SLEPc eigenvalue solvers. I have been trying out SLEPc using the examples provided as part of the tutorial. Exercise 7 reads matricies A and B from a file and outputs the solutions. I got this to work fine using the matrices provided. However, if I substitute a smaller sized test version of my problem (6000x6000), I get a variety of errors depending on the command line arguments I supply.
>> The main problem I have is the error: "zero pivot in LU factorisation!" when I use the default settings.
>> I think this might be related to the fact that B contains rows of zeros, although my understanding of linear algebra is somewhat basic. Is this true?
>> I have tried setting the options suggested on the petsc website, -pc_factor_shift_type NONZERO etc but all I get is an additional warning that these options were not used
>> I assumed that this was a problem with the preconditioner, so I tried setting -eps_target to 0.1 and both with and without specifying -st_type sinvert and shift. Still I get the same error.
>> Then I tried -st_pc_type jacobi and st_pc_type bjacobi. jacobi runs, but does not produce any eigenvalues. Block jacobi does an LU factorisation and gives me the same error again.
>> The default method is krylov-schur, so I have experimented with the -eps_type gd and -eps_type jd options. Unfortunately these seem to produce nonsense eigenvalues, which do not appear on the spectrum at all when I solve using LAPACK in scipy.
>> I know my matrix problem is not singular, because I can solve it using scipy.
>> Do you know of any books/guides I might need to read besides the PETSC and SLEPC manuals to understand the behaviour of all these different solvers?
>> The output from the case with no command line options is given below.
>> Thanks a lot for taking the time to read this!
>> Kind Regards,
>> Toby
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
