[petsc-users] Trying to set up a field-split preconditioner
subramanya sadasiva potaman at outlook.com
Fri Jul 19 23:50:58 CDT 2013
Hi Matt, I see that there is an implementation of the interface to DMCreateFieldDecomposition.html .  So does this sound right?1. I get index sets ,and variable names from the dm create field decomposition 2. Once I have these , I create fieldsplits and name them using this.. 3. And I guess I should be ready to go.. One question that remains is that the fieldsplit is created on a full matrix. However, an algorithm such as VIRS operates only on a subset of this full DM. Will the fieldsplit and preconditioner created on the full DM carry over to the subsidiary DMs?Thanks for all the help!Subramanya
 Date: Fri, 19 Jul 2013 23:09:10 -0500
Subject: Re: [petsc-users] Trying to set up a field-split preconditioner
To: potaman at outlook.com
CC: petsc-users at mcs.anl.gov
On Fri, Jul 19, 2013 at 9:59 PM, subramanya sadasiva <potaman at outlook.com> wrote:
Hi Matt,
The DM being created is here (this is from Libmesh code
(petscdmlibmesh.C )
   01047 {
   01048 PetscErrorCode ierr;
   01049 PetscFunctionBegin;
   01050 ierr = DMCreate(comm, dm); CHKERRQ(ierr);
   01051 ierr = DMSetType(*dm, DMLIBMESH); CHKERRQ(ierr);
   01052 ierr = DMLibMeshSetSystem(*dm, sys); CHKERRQ(ierr);
   01053 PetscFunctionReturn(0);
   01054 }
This file has methods to access the  variables assigned to the DM (this seems to be stored in a struct.) So , I guess one should be able to add a bit of code to create sections as you mentioned somewhere around here.
Okay, they have their own DM. It must implement one of the interfaces for field specification. They could provide
  http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateFieldDecomposition.html
or at a lower level
  http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateSubDM.html
which in turn can be constructed by specifying a default PetscSection
  http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMSetDefaultSection.html
    Matt
Thanks, Subramanya
Date: Fri, 19 Jul 2013 21:33:11 -0500
On Fri, Jul 19, 2013 at 9:17 PM, subramanya sadasiva <potaman at outlook.com> wrote:
Hi Matt,
I am using Libmesh so the DM stuff is actually in the background, and unfortunately the matrix doesn't have a saddle point,
I thought that
  -ch_solve_fieldsplit_block_size 2
  -ch_solve_fieldsplit_0_fields 0
  -ch_solve_fieldsplit_1_fields 1
The block_size argument presumes you are using a DA. Are you?
The other two options just say select the first DM field as field 0 in this PC, and the same with the second field. The
DM must inform the PC about the initial field decomposition.
would inform the solver of the structure. If this doesn't work owing to the fact that the problem is only being solved on a section of the mesh (because of the reduced space method), I guess I will have to use the PetscSection. Does that sound right?
First, I think the right people to do this are the Libmesh people (we will of course help them). Second, you have not said
whether you are using a structured or unstructured mesh. What DM class does the solver actually see?
      Matt
Subramanya
CC: petsc-users at mcs.anl.gov; libmesh-users at lists.sourceforge.net
On Fri, Jul 19, 2013 at 7:56 PM, subramanya sadasiva <potaman at outlook.com> wrote:
I am trying to set up a fieldsplit preconditioner for my Cahn Hilliard solver and I get the following error,
You have to tell the PCFIELDSPLIT about the dofs in each field. So
1) You are probably not using a DA, since it would tell it automatically
2) If you have a saddle point, you can use -pc_fieldsplit_detect_saddle_point
3) If none of those apply, you can set a PetscSection describing your layout to the DM for the solver.
     Since this is new, I suspect you will need help, so mail back.
     Matt
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Petsc has generated inconsistent data!
[0]PETSC ERROR: Unhandled case, must have at least two fields, not 0!
[0]PETSC ERROR: ------------------------------------------------------------------------
These are the options that I am using,
-ch_solve is just a prefix.
-ch_solve_pc_type fieldsplit
-ch_solve_pc_fieldsplit_type schur
-ch_solve_fieldsplit_0_field 1
-ch_solve_fieldsplit_1_field 0
-ch_solve_fieldsplit_0_ksp_type cg
-ch_solve_fieldsplit_0_pc_type hypre
-ch_solve_fieldsplit_0_pc_type_hypre boomeramg
-ch_solve_fieldsplit_1_ksp_type cg
-ch_solve_fieldsplit_1_pc_type hypre
-ch_solve_fieldsplit_1_pc_type_hypre boomeramg
Any ideas?
Subramanya
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130720/85809132/attachment.html>
