[petsc-users] Trying to set up a field-split preconditioner
Fri Jul 19 23:09:10 CDT 2013
On Fri, Jul 19, 2013 at 9:59 PM, subramanya sadasiva <potaman at outlook.com>wrote:
> Hi Matt,
> The DM being created is here (this is from Libmesh code
> (petscdmlibmesh.C )
>    01047 {
>    01048 PetscErrorCode ierr;
>    01049 PetscFunctionBegin;
>    01050 ierr = DMCreate(comm, dm); CHKERRQ(ierr);
>    01051 ierr = DMSetType(*dm, DMLIBMESH); CHKERRQ(ierr);
>    01052 ierr = DMLibMeshSetSystem(*dm, sys); CHKERRQ(ierr);
>    01053 PetscFunctionReturn(0);
>    01054 }
> This file has methods to access the  variables assigned to the DM (this
> seems to be stored in a struct.)
> So , I guess one should be able to add a bit of code to create sections as
> you mentioned somewhere around here.
Okay, they have their own DM. It must implement one of the interfaces for
field specification. They could provide
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateFieldDecomposition.html
or at a lower level
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateSubDM.html
which in turn can be constructed by specifying a default PetscSection
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMSetDefaultSection.html
    Matt
> Thanks,
> Subramanya
> Date: Fri, 19 Jul 2013 21:33:11 -0500
> Subject: Re: [petsc-users] Trying to set up a field-split preconditioner
> From: knepley at gmail.com
> To: potaman at outlook.com
> CC: petsc-users at mcs.anl.gov
> On Fri, Jul 19, 2013 at 9:17 PM, subramanya sadasiva <potaman at outlook.com>
> wrote:
> Hi Matt,
> I am using Libmesh so the DM stuff is actually in the background, and
> unfortunately the matrix doesn't have a saddle point,
> I thought that
>   -ch_solve_fieldsplit_block_size 2
>   -ch_solve_fieldsplit_0_fields 0
>   -ch_solve_fieldsplit_1_fields 1
> The block_size argument presumes you are using a DA. Are you?
> The other two options just say select the first DM field as field 0 in
> this PC, and the same with the second field. The
> DM must inform the PC about the initial field decomposition.
> would inform the solver of the structure. If this doesn't work owing to
> the fact that the problem is only being solved on a section of the mesh
> (because of the reduced space method), I guess I will have to use the
> PetscSection. Does that sound right?
> First, I think the right people to do this are the Libmesh people (we will
> of course help them). Second, you have not said
> whether you are using a structured or unstructured mesh. What DM class
> does the solver actually see?
>   Thanks,
>       Matt
> Thanks,
> Subramanya
> CC: petsc-users at mcs.anl.gov; libmesh-users at lists.sourceforge.net
> On Fri, Jul 19, 2013 at 7:56 PM, subramanya sadasiva <potaman at outlook.com>
> wrote:
> Hi,
> I am trying to set up a fieldsplit preconditioner for my Cahn Hilliard
> solver and I get the following error,
> You have to tell the PCFIELDSPLIT about the dofs in each field. So
> 1) You are probably not using a DA, since it would tell it automatically
> 2) If you have a saddle point, you can use
> -pc_fieldsplit_detect_saddle_point
> 3) If none of those apply, you can set a PetscSection describing your
> layout to the DM for the solver.
>      Since this is new, I suspect you will need help, so mail back.
>   Thanks,
>      Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data!
> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 0!
> [0]PETSC ERROR:
> These are the options that I am using,
> -ch_solve is just a prefix.
> -ch_solve_pc_type fieldsplit
> -ch_solve_pc_fieldsplit_type schur
> -ch_solve_fieldsplit_0_field 1
> -ch_solve_fieldsplit_1_field 0
> -ch_solve_fieldsplit_0_ksp_type cg
> -ch_solve_fieldsplit_0_pc_type hypre
> -ch_solve_fieldsplit_0_pc_type_hypre boomeramg
> -ch_solve_fieldsplit_1_ksp_type cg
> -ch_solve_fieldsplit_1_pc_type hypre
> -ch_solve_fieldsplit_1_pc_type_hypre boomeramg
> Any ideas?
> Thanks,
> Subramanya
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130719/29785c37/attachment-0001.html>
