[petsc-users] Trying to set up a field-split preconditioner
Fri Jul 19 20:54:22 CDT 2013
On Fri, Jul 19, 2013 at 7:56 PM, subramanya sadasiva <potaman at outlook.com>wrote:
>  Hi,
> I am trying to set up a fieldsplit preconditioner for my Cahn Hilliard
> solver and I get the following error,
You have to tell the PCFIELDSPLIT about the dofs in each field. So
1) You are probably not using a DA, since it would tell it automatically
2) If you have a saddle point, you can use
-pc_fieldsplit_detect_saddle_point
3) If none of those apply, you can set a PetscSection describing your
layout to the DM for the solver.
     Since this is new, I suspect you will need help, so mail back.
     Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data!
> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 0!
> [0]PETSC ERROR:
> These are the options that I am using,
> -ch_solve is just a prefix.
> -ch_solve_pc_type fieldsplit
> -ch_solve_pc_fieldsplit_type schur
> -ch_solve_fieldsplit_block_size 2
> -ch_solve_fieldsplit_0_field 1
> -ch_solve_fieldsplit_1_field 0
> -ch_solve_fieldsplit_0_ksp_type cg
> -ch_solve_fieldsplit_0_pc_type hypre
> -ch_solve_fieldsplit_0_pc_type_hypre boomeramg
> -ch_solve_fieldsplit_1_ksp_type cg
> -ch_solve_fieldsplit_1_pc_type hypre
> -ch_solve_fieldsplit_1_pc_type_hypre boomeramg
> Any ideas?
> Thanks,
> Subramanya
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130719/d7aedf78/attachment.html>
