[petsc-users] [Libmesh-users] Trying to set up a field-split preconditioner
subramanya sadasiva potaman at outlook.com
Fri Jul 19 20:12:23 CDT 2013
I forgot to mention it, but I am using this with the petsc virs solver.
> From: potaman at outlook.com
> To: petsc-users at mcs.anl.gov; libmesh-users at lists.sourceforge.net
> Date: Fri, 19 Jul 2013 20:56:39 -0400
> Subject: [Libmesh-users] Trying to set up a field-split preconditioner
> Hi,
> I am trying to set up a fieldsplit preconditioner for my Cahn Hilliard solver and I get the following error,
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------[0]PETSC ERROR: Petsc has generated inconsistent data![0]PETSC ERROR: Unhandled case, must have at least two fields, not 0![0]PETSC ERROR: ------------------------------------------------------------------------
> These are the options that I am using, -ch_solve is just a prefix.
> -ch_solve_pc_type fieldsplit-ch_solve_pc_fieldsplit_type schur-ch_solve_fieldsplit_block_size 2-ch_solve_fieldsplit_0_field 1-ch_solve_fieldsplit_1_field 0-ch_solve_fieldsplit_0_ksp_type cg -ch_solve_fieldsplit_0_pc_type hypre-ch_solve_fieldsplit_0_pc_type_hypre boomeramg -ch_solve_fieldsplit_1_ksp_type cg-ch_solve_fieldsplit_1_pc_type hypre -ch_solve_fieldsplit_1_pc_type_hypre boomeramg
> Any ideas?
> Thanks,Subramanya
> See everything from the browser to the database with AppDynamics
> Get end-to-end visibility with application monitoring from AppDynamics
> Isolate bottlenecks and diagnose root cause in seconds.
> Start your free trial of AppDynamics Pro today!
> http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
> Libmesh-users mailing list
> Libmesh-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/libmesh-users
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130719/5dce7391/attachment.html>
