[petsc-users] What does "--with-is-color-value-type=short" mean?
Fri Jul 12 12:59:03 CDT 2013
 Inge,
   We will need the entire error message to know what the issue is. The --with-is-color-value=short should be fine and is not likely the cause of the problem.
   Barry
On Jul 12, 2013, at 4:17 AM, Inge Gutheil <i.gutheil at fz-juelich.de> wrote:
> Hello,
> sorry, I do not use PETSc, I only installl it for those who want to use
> it. I installed it on an BlueGene/P with the example for that machine
> and now I am going to install it for BlueGene/Q and I don't see an
> example file for that machine.
> I had used the same arch-bgp-... file with modified known-sizeof things
> for the 64-bit architecture and the installs and examples usually were
> ok. Now one  user had problems and in the errors there was something
> about is-color, so do I have to omit the "--with-is-color-value=short"
> for bgq?
> Thanks for your answers
> Inge Gutheil
> Inge Gutheil
> Juelich Supercomputing Centre
> Institute for Advanced Simulation
> Forschungszentrum Juelich GmbH
> 52425 Juelich, Germany
>      Phone:   +49-2461-61-3135
>      Fax:     +49-2461-61-6656
>      E-mail:i.gutheil at fz-juelich.de
> 52425 Juelich
> Sitz der Gesellschaft: Juelich
> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
> Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender),
> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
> Prof. Dr. Sebastian M. Schmidt
> Das Forschungszentrum oeffnet seine Tueren am Sonntag, 29. September, von 10:00 bis 17:00 Uhr: http://www.tagderneugier.de
