[petsc-users] petsc viewer
Mon Jul 8 13:00:59 CDT 2013
On Jul 8, 2013, at 12:38 PM, "Shaohao Chen" <shchen at www.phys.lsu.edu> wrote:
> Dear all,
> I can use VecView(vec, viewer) and correctly output a distributed vector. But when I use it in an
> iteration, it doesn't work. My codes are like:
> PetscViewerCreate(PETSC_COMM_WORLD, &viewer1);
> ......  // modify values of vec
> VecView(vec, viewer1) ;  // correct
> PetscViewerCreate(PETSC_COMM_WORLD, &viewer2);
You need to set the type of viewer here.
> for(i=0;i<n;i++){
>  VecView(vec, viewer2) ;  // incorrect
> In viewer1, it outputs the whole correct vector. In viewer2, it just outputs part of the vector and
> then stop at the first step of the iteration.
   What do you mean "stop"? Does it print an error message?
> And it becomes much slower when I add the VecView line
> in the iteration. The same happens to MatView. What is the problem here?
 calls to  VecView and MatView (especially) will slow down a code since it involves IO. In particular if the file you are saving to is on a slow file server it could slow it down a great deal. Best to save to a local disk.
   Barry
> Thank you for your attention!
> Shaohao Chen
> Department of Physics & Astronomy,
> Louisiana State University,
> Baton Rouge, LA
