[petsc-users] petsc viewer
Shaohao Chen shchen at www.phys.lsu.edu
Mon Jul 8 12:38:24 CDT 2013
Dear all,
I can use VecView(vec, viewer) and correctly output a distributed vector. But when I use it in an
iteration, it doesn't work. My codes are like:
PetscViewerCreate(PETSC_COMM_WORLD, &viewer1);
......  // modify values of vec
VecView(vec, viewer1) ;  // correct
PetscViewerCreate(PETSC_COMM_WORLD, &viewer2);
for(i=0;i<n;i++){
  VecView(vec, viewer2) ;  // incorrect
In viewer1, it outputs the whole correct vector. In viewer2, it just outputs part of the vector and
then stop at the first step of the iteration. And it becomes much slower when I add the VecView line
in the iteration. The same happens to MatView. What is the problem here?
Thank you for your attention!
Shaohao Chen
Department of Physics & Astronomy,
Louisiana State University,
Baton Rouge, LA
