[petsc-users] newbie questions on preconditioner LU
Mon Jan 28 13:01:30 CST 2013
On Mon, Jan 28, 2013 at 1:39 PM, Ling Zou <lingzou80 at gmail.com> wrote:
> Hi, All
> I am trying to understand how the preconditioner works when using KSP.
> For example, when using KSP to solve the linear system problem,
> Ax = b
> with the default left preconditioning. We actually solve,
> M^(-1) * A x = M^(-1) * b
> where, M is the preconditioning matrix and in many cases, we just use A as
> the preconditioning matrix.
> Question:
> 1), Is the understanding above correct?
This is too simplistic. If you really mean M^{-1}, then no, you (almost)
never use A as M. If you mean an
approximate inverse to M, then yes.
> 2), If the understanding above is correct, is it correct to state the
> different methods provided in PETSc (such as PCLU, PCILU, etc) are to
> calculate the inverse matrix M^(-1) from M?
An approximate inverse.
> 3), How to understand this sentence in the manual (PETSc Users Manual,
> Reversion 3.3, page 78, under 4.4 Preconditioners)
> "The direct preconditioner, PCLU, is, in fact, a direct solver for the
> linear system that uses LU factorization. PCLU is included as a
> preconditioner so that PETSc has a consistent interface among direct and
> iterative linear solvers."
> Does this indicate when using PCLU, we solve Ax = b directly using LU
> factorization, or, we solve M^(-1) from M using LU factorization?
Same thing, if M = A,
  M^{-1} A x = A^{-1} A x = x = A^{-1} b
which is Gaussian elimination for the original problem.
   Matt
> As a beginner to the PETSc, all questions are probably too simple. I'd
> appreciate it if someone could answer my questions.
> Best,
> Ling
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130128/7c3f14c3/attachment.html>
