[petsc-users] -pc_factor_mat_solver_package wish_list
Mon Jan 7 17:02:44 CST 2013
On Jan 7, 2013, at 8:46 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> It would be very easy to make PetscFListFind interpret choice1:choice2:choice3 as searching for items in that order, in which case this sort of option would work anywhere. This sounds convenient to me, though if you have impl-specific suboptions, you'll be notified that those were not used in -options_left. Is this okay?
   Jed,
   How would this be done in the code? Ideally there is a functional interface with a corresponding OptionsData base interface. Something like the equivalent of PCFactorSetMatSolverPackages(pc,{MATSOLVERSUPERLU_DIST,MATSOLVERMUMPS, MATSOLVERPETSC,PETSC_NULL})
   Then follow this paradigm for all set types and packages? But then since there is  a PCFactorSetMatSolverPackage() and a PCFactorSetMatSolverPackages() should there be
a -pc_factor_mat_solver_package  package AND -pc_factor_mat_solver_packages  package1:package2  ?
    Barry
> On Mon, Jan 7, 2013 at 8:41 AM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> I have just compiled Petsc with "--with-64-bit-indices" and I see that MUMPS is missing but superLu still there.  Ok like that.
> Now I would like to have something like this on my command line:
> -pc_factor_mat_solver_package mumps_if_available_otherwise_superlu_dist
> How can I add or register something in petsc to have this behavior?
> Thank you!
> Eric
