[petsc-users] dmda and structures
Gideon Simpson gideon.simpson at icloud.com
Sat Dec 28 19:44:00 CST 2013
I'm trying to use 1D DMDA's to manage distributed monte carlo computations, and I've got the following problem.  If I know, in advance, how many floating points are needed for each realization, everything is fine.  But, if I want to be able to set this at run time, I can't get it to work.  What I have is:
typedef struct {
  PetscScalar id;
  PetscScalar *x;
} Realization;
then, in the main part of the code:
  Realization *realization_array;
  DM sim_data_da;
  Vec sim_data_vec;
  PetscInt xsize=10, realization_dof, i;
  PetscOptionsGetInt(NULL, "-xsize", &xsize, NULL);
realization_dof	  = xsize + 1;
  DMDACreate1d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE, batch_size, realization_dof, 0, NULL, &sim_data_da);
  DMCreateGlobalVector(sim_data_da,&sim_data_vec);
  DMDAVecGetArray(sim_data_da, sim_data_vec, & realization_array);
  Up to this point, I have no problem, but, when I try to access realization_array[i].x[j], I get memory errors.  Is this fundamentally unworkable, or  is there a fix?
-gideon
