[petsc-users] Seg fault when using DMDATSSetIFunctionLocal with DMComposite
Sat Dec 14 10:21:08 CST 2013
Mani Chandra <mc0710 at gmail.com> writes:
> Can the function DMDATSSetIFunctionLocal be used with a global DM which has
> been constructed from many DMs' combined into a DMComposite?
No, DMDA* functions can only be used with DMDA, not DMCOMPOSITE or any
other DM implementation.
> I put a single DM for each one of the variables that I wanted to solve
> for and combined them in a single one with DMComposite, but the
> timestepping seg faults with the following error
> 0x00007ffff69d3786 in VecScatterBegin_SGToSG (ctx=0x924400, x=0x90b640,
> y=0x920340, addv=INSERT_VALUES, mode=SCATTER_FORWARD) at
> /home/mc/Downloads/petsc/src/vec/vec/utils/vscat.c:370
> 370         for (i=0; i<n; i++) yv[tslots[i]]  = xv[fslots[i]];
> Would the only way to use a DMComposite with TS be using TSSetIFunction and
> then scatters the DMComposite to individual DMs' inside the function?
Yes.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131214/5549a7ad/attachment.pgp>
