[petsc-users] Optimal memory layout for finite differences
Fri Dec 13 11:24:37 CST 2013
Mani Chandra <mc0710 at gmail.com> writes:
> Hi Everyone,
> Would it be a good idea to arrange the data in fastest direction in the
> following manner for the ease of aligned loads and vector operations?
> Total grid points = 4n
> 0, n, 2n, 3n, 1, n+1, 2n+1, 3n+1 and so on
> Ref: "Tuning a Finite Difference Computation for Parallel Vector Processors"
> http://ieeexplore.ieee.org/xpl/articleDetails.jsp?arnumber=6341495
This paper does not solve a problem.  It performs AVX optimization for
repeated application of a 1D stencil update using an s-step technique.
There are many reasons why the present form of this work is impractical,
including that it cannot be used with preconditioning, nor with standard
Krylov methods, and that generalizing to multiple spatial dimensions,
variable coefficients, etc., throws a wrench in the mix.
I recommend skipping this premature optimization of 1% of the actual
problem and actually get your science done.  There are more practical
ways to optimize when the time comes.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131213/44c146dc/attachment.pgp>
