[petsc-users] An issue of order of accuracy.
Alan zhenglun.wei at gmail.com
Tue Dec 10 00:45:50 CST 2013
Thank you, Dr. Smith.
I 'cooked up' a 4th-order polynomial and find out that the Poisson
solver with uniform Cartesian mesh is 2nd order of accuracy. Also, if
the solution is 3rd or less order polynomial, the L2Norm shows very
small round-off error, which is usually 1e-7 if the -ksp_rtol is 1-e7.
Following this idea, I re-derived the coefficients for the Poisson
equation for solver with non-uniform grid, which is attached with a
.docx file. From the equation, it indicates that at least 3rd or higher
order polynomial should be constructed for the solution to detect the
real order of accuracy. In other words, for solution of 2nd or lower
order polynomials, the L2Norm should show very small round-off error.
However, the reality is not and here is a brief description of my tests.
The test focuses on the three-dimensional Poisson solver with
non-uniform Cartesian mesh, which is modified from
/src/ksp/ksp/example/tutorial/ex45.c. For simplicity, in this test, only
x-direction has non-uniform grid, y- and z- are uniform grid. I have 3
sets of tests, which are recorded in TestRun attached. The difference
among these 3 sets of tests are the -ksp_rtol. Each set has 3 different
commands to run the program with different ksp solver (GMRES or
richardson) and pc type (GAMG and Hypre boomeramg).
As I recorded in TestRun, while the ksp_rtol is 1e-7, the L2Norm is
fairly large. As Dr. Smith explained, tight algebraic tolerances are
needed to eliminate the algebraic error. Therefore, I changed ksp_rtol
to 10-e15. However, the L2Norm can only reach 1e-7. Compared with the
Poisson solver with uniform Cartesian mesh (which the L2Norm exhibits
1e-7 round-off error as -ksp_rtol = 1e-7), the L2Norm from the
non-uniform Poisson solver is relatively high. Is this normal?
Moreover, the Residual norm shown for cases with ksp_rtol = 1e-15 is
around 7, 28 or even 81, which are far away from the real ksp_rtol
imported. I monitored the ksp iterations with ksp_monitor and found out
that these solvers usually iterate around 20 times. Why wouldn't them
continue to iterate until the 1e-15 is achieved?
Based on my observation, neither solver/pc works fine for this Poisson
solver with non-uniform mesh. Is there any other option to made some
improvements?
At last, for the Poisson solver with non-uniform Cartesian grid, is
there any better way to prove its validity?
sincerely appreciate,
Alan
>   Alan,
>    I changed your initial grid size to 10 to get faster solve times and get what is below.  Note that your “exact solution” is quadratic, since the method is second order this means that not only is the “exact solution” an exact solution to the PDE, it is also an exact solution to the algebraic equations (for any grid size) hence the L2Norm of the error is only due to the round off of the algebraic solution, not due to any discretization error. In general, when testing for discretization error you always need to “cook up” an exact solution that is not completely represented in the approximation space. You also need to use a really tight algebraic tolerance to eliminate the algebraic error from the computation
> ~/Src/petsc/test-dir  master $ ./ex45 -pc_type mg  -ksp_rtol 1e-12
> mx = 10, my = 10, mz =10, mm = 1, nn = 1, pp = 1
> Residual norm 1.81616e-12
> L2Norm = 1.107359e-12
> Total Time Elapsed: 0.048599
> ~/Src/petsc/test-dir  master $ ./ex45 -pc_type mg  -ksp_rtol 1e-12 -da_refine 1
> mx = 19, my = 19, mz =19, mm = 1, nn = 1, pp = 1
> Residual norm 3.36741e-12
> L2Norm = 1.037148e-12
> Total Time Elapsed: 0.183398
> ~/Src/petsc/test-dir  master $ ./ex45 -pc_type mg  -ksp_rtol 1e-12 -da_refine 2
> mx = 37, my = 37, mz =37, mm = 1, nn = 1, pp = 1
> Residual norm 1.09476e-11
> L2Norm = 2.330658e-12
> Total Time Elapsed: 1.180839
> ~/Src/petsc/test-dir  master $ ./ex45 -pc_type mg  -ksp_rtol 1e-12 -da_refine 3
> mx = 73, my = 73, mz =73, mm = 1, nn = 1, pp = 1
> Residual norm 3.19809e-11
> L2Norm = 2.278763e-12
> Total Time Elapsed: 10.819450
> ~/Src/petsc/test-dir  master $ ./ex45 -pc_type mg   -da_refine 3
> Residual norm 0.000103197
> L2Norm = 1.011806e-05
> Total Time Elapsed: 7.250106
> On Dec 4, 2013, at 5:25 PM, Alan Z. Wei <zhenglun.wei at gmail.com> wrote:
>> Dear all,
>>     I hope you had a great Thanksgiving.
>>     Currently, I tested the order of accuracy for /src/ksp/ksp/tutorial/example/ex45.c. Since the 2nd-order discretization is used in this program and ksp solver is converged to 10^-7, I expected that the solution should provides a 2nd-order in L2 norm. However, as I tested (even with a Laplace equation), the L2 norm slope is much less than 2. Sometime, if the grid size is reduced, the L2 norm increases. Could anyone help me about this issue, please?
>> Here is the L2 norm outputted:
>> Grid	L2 norm (10^-8)
>> 0.05	4.36242
>> 0.025	2.20794
>> 0.0125	7.02749
>> 0.00625	12.64
>>     Once the grid size is reduced to half, the number of the grid will be multiplied by 8 in order to keep the same size of the computational domain.
>>     The code is also attached. It is from ex45.c with very little modifications.
>> thanks in advance,
>> Alan
>> <ex45.c><TestRun.txt>
Laplacian in 3D. Modeled by the partial differential equation
   - Laplacian u = 1,0 < x,y,z < 1,
with boundary conditions
   u = 1 for x = 0, x = 1, y = 0, y = 1, z = 0, z = 1.
   This uses multigrid to solve the linear system
   See src/snes/examples/tutorials/ex50.c
   Can also be run with -pc_type exotic -ksp_type fgmres
static char help[] = "Solves 3D Laplacian using multigrid.\n\n";
#include <petscksp.h>
#include <petscdmda.h>
const double dx = 5.;
const double dy = 5.;
const double dz = 5.;
const int imax = 20;
const int jmax = 10;
const int kmax = 10;
const int seci1 = 5;
const int seci2 = 10;
const int seci3 = 5;
const double rdx1 = 2.;
const double rdx3 = 4.;
extern PetscErrorCode ComputeMatrix(KSP,Mat,Mat,MatStructure*,void*);
extern PetscErrorCode ComputeRHS(KSP,Vec,void*);
extern PetscErrorCode ComputeInitialGuess(KSP,Vec,void*);
extern PetscErrorCode PostP(DM, Vec, Vec);
extern double RealDx(int);
extern double RealPx(int);
extern void CalTotalLength();
PetscInt       i,j,k,mx,my,mz,xm,ym,zm,xs,ys,zs;
double TotalLength1_x, TotalLength2_x, TotalLength3_x;
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
  PetscErrorCode ierr;
  KSP            ksp;
  PetscReal      norm;
  DM             da;
  Vec            x,b,r;
  Mat            A;
  double t1, t2;
  PetscInitialize(&argc,&argv,(char*)0,help);
  CalTotalLength();
  t1 = MPI_Wtime();
  ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
  ierr = DMDACreate3d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,-imax,-jmax,-kmax,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,0,&da);CHKERRQ(ierr);
  ierr = KSPSetDM(ksp,da);CHKERRQ(ierr);
  ierr = KSPSetComputeInitialGuess(ksp,ComputeInitialGuess,NULL);CHKERRQ(ierr);
  ierr = KSPSetComputeRHS(ksp,ComputeRHS,NULL);CHKERRQ(ierr);
  ierr = KSPSetComputeOperators(ksp,ComputeMatrix,NULL);CHKERRQ(ierr);
  ierr = DMDestroy(&da);CHKERRQ(ierr);
  ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
  printf("Check #1!!\n");
  ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
  printf("Check #2!!\n");
  ierr = KSPGetSolution(ksp,&x);CHKERRQ(ierr);
  ierr = KSPGetRhs(ksp,&b);CHKERRQ(ierr);
  ierr = VecDuplicate(b,&r);CHKERRQ(ierr);
  ierr = KSPGetOperators(ksp,&A,NULL,NULL);CHKERRQ(ierr);
  ierr = MatMult(A,x,r);CHKERRQ(ierr);
  ierr = VecAXPY(r,-1.0,b);CHKERRQ(ierr);
  ierr = VecNorm(r,NORM_2,&norm);CHKERRQ(ierr);
  ierr = PetscPrintf(PETSC_COMM_WORLD,"Residual norm %G\n",norm);CHKERRQ(ierr);
  ierr = KSPGetDM(ksp, &da);CHKERRQ(ierr);
  ierr = PostP(da, x, b);
  ierr = VecDestroy(&r);CHKERRQ(ierr);
  ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
  t2 = MPI_Wtime();
  printf("Total Time Elapsed: %f\n", t2-t1);
  ierr = PetscFinalize();
  return 0;
#undef __FUNCT__
#define __FUNCT__ "ComputeRHS"
PetscErrorCode ComputeRHS(KSP ksp,Vec b,void *ctx)
  PetscInt       i,j,k,mx,my,mz,xm,ym,zm,xs,ys,zs, mm,nn,pp;
  DM             dm;
  PetscScalar    ***barray;
  double af;
  PetscFunctionBeginUser;
  ierr    = KSPGetDM(ksp,&dm);CHKERRQ(ierr);
  ierr    = DMDAGetInfo(dm,0,&mx,&my,&mz,&mm,&nn,&pp,0,0,0,0,0,0);CHKERRQ(ierr);
  printf("mx = %d, my = %d, mz =%d, mm = %d, nn = %d, pp = %d\n", mx, my, mz, mm, nn, pp);
  ierr    = DMDAGetCorners(dm,&xs,&ys,&zs,&xm,&ym,&zm);CHKERRQ(ierr);
  ierr    = DMDAVecGetArray(dm,b,&barray);CHKERRQ(ierr);
  for (k=zs; k<zs+zm; k++) {
    for (j=ys; j<ys+ym; j++) {
      for (i=xs; i<xs+xm; i++) {
        af = 0.5*(RealDx(i)*RealDx(i-1)*dy*dy*dz*dz);
        if (i==0 || j==0 || k==0 || i==mx-1 || j==my-1 || k==mz-1) {
//          barray[k][j][i] = -1.*(1000.*pow(RealPx(i),2.0)/2.+RealPx(i))*af;
          barray[k][j][i] = (1000.*pow(RealPx(i),2.0)/2.+RealPx(i));
        } else {
          barray[k][j][i] = -1000.*pow(RealPx(i),.0)*af;
  ierr = DMDAVecRestoreArray(dm,b,&barray);CHKERRQ(ierr);
  PetscFunctionReturn(0);
#undef __FUNCT__
#define __FUNCT__ "ComputeInitialGuess"
PetscErrorCode ComputeInitialGuess(KSP ksp,Vec b,void *ctx)
  ierr = VecSet(b,0);CHKERRQ(ierr);
#undef __FUNCT__
#define __FUNCT__ "ComputeMatrix"
PetscErrorCode ComputeMatrix(KSP ksp,Mat jac,Mat B,MatStructure *stflg,void *ctx)
  DM             da;
  PetscScalar    v[7];
  MatStencil     row,col[7];
  PetscScalar dxValue, dxValue1, dyValue, dyValue1, dzValue, dzValue1, aa, ax, ay, az, af;
  ierr    = KSPGetDM(ksp,&da);CHKERRQ(ierr);
  ierr    = DMDAGetInfo(da,0,&mx,&my,&mz,0,0,0,0,0,0,0,0,0);CHKERRQ(ierr);
  ierr    = DMDAGetCorners(da,&xs,&ys,&zs,&xm,&ym,&zm);CHKERRQ(ierr);
        row.i = i; row.j = j; row.k = k;
        dxValue = RealDx(i-1);
        dxValue1 = RealDx(i);
        dyValue = dy;
        dyValue1 = dy;
        dzValue = dz;
        dzValue1 = dz;
        aa = (dyValue*dyValue1*dzValue*dzValue1 + dxValue*dxValue1*dzValue*dzValue1 + dxValue*dxValue1*dyValue*dyValue1);
        ax = dyValue*dyValue1*dzValue*dzValue1/(dxValue+dxValue1);
        ay = dxValue*dxValue1*dzValue*dzValue1/(dyValue+dyValue1);
        az = dxValue*dxValue1*dyValue*dyValue1/(dzValue+dzValue1);
//        af = 0.5*(dxValue*dxValue1*dyValue*dyValue1*dzValue*dzValue1);
//          v[0] = -1.*af;
          v[0] = 1.;
          ierr = MatSetValuesStencil(B,1,&row,1,&row,v,INSERT_VALUES);CHKERRQ(ierr);
        } else {
          v[0] = -1.*dzValue1*az;col[0].i = i; col[0].j = j; col[0].k = k-1;
          v[1] = -1.*dyValue1*ay;col[1].i = i; col[1].j = j-1; col[1].k = k;
          v[2] = -1.*dxValue1*ax;col[2].i = i-1; col[2].j = j; col[2].k = k;
          v[3] = aa;col[3].i = row.i; col[3].j = row.j; col[3].k = row.k;
          v[4] = -1.*dxValue*ax;col[4].i = i+1; col[4].j = j; col[4].k = k;
          v[5] = -1.*dyValue*ay;col[5].i = i; col[5].j = j+1; col[5].k = k;
          v[6] = -1.*dzValue*az;col[6].i = i; col[6].j = j; col[6].k = k+1;
          ierr = MatSetValuesStencil(B,1,&row,7,col,v,INSERT_VALUES);CHKERRQ(ierr);
  ierr   = MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  ierr   = MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  *stflg = SAME_NONZERO_PATTERN;
#undef __FUNCT__
#define __FUNCT__ "PostP"
PetscErrorCode PostP(DM da, Vec x, Vec b) {
  PetscScalar ***DpArray;
  double L2Norm;
  FILE *fpr;
  fpr = fopen("Check.dat", "w");
  L2Norm = 0.;
  ierr = DMDAVecGetArray(da, x, &DpArray);CHKERRQ(ierr);
        L2Norm += pow(DpArray[k][j][i] - (1000.*pow(RealPx(i),2.)/2.+RealPx(i)), 2.0);
//        L2Norm += pow(DpArray[k][j][i] - 1., 2.0);
        fprintf(fpr, "%f %f %.10f \n", RealPx(i), RealDx(i), DpArray[k][j][i]);
  fclose(fpr);
  L2Norm = pow(L2Norm/(mx)/(my)/(mz), 0.5);
  printf("L2Norm = %e\n", L2Norm);
  ierr = DMDAVecRestoreArray(da, x, &DpArray);CHKERRQ(ierr);
#undef __FUNCT__
#define __FUNCT__ "CalTotalLength"
void CalTotalLength() {
  TotalLength1_x = (rdx1==1.)?dx*seci1:dx*((pow(rdx1,seci1+1)-1.0)/(rdx1-1.0)-1.);
  TotalLength2_x = TotalLength1_x+seci2*dx;
  TotalLength3_x = (rdx3==1.)?TotalLength2_x+dx*seci3:TotalLength2_x+dx*((pow(rdx3,seci3+1)-1.0)/(rdx3-1.0)-1.);
  printf("Total Length on X-direction: %f  %f  %f\n", TotalLength1_x, TotalLength2_x, TotalLength3_x);
#undef __FUNCT__
#define __FUNCT__ "RealDx"
double RealDx(int IndexI) {
  double DeltaCoord;
  if(IndexI >= seci1+seci2 && IndexI <= seci1+seci2+seci3) {
    DeltaCoord = dx*pow(rdx3,IndexI-seci1-seci2+1);
  } else if(IndexI >= -1 && IndexI <= seci1) {
    DeltaCoord = dx*(pow(rdx1,seci1-IndexI));
  } else if(IndexI > seci1 && IndexI < seci1+seci2) {
    DeltaCoord = dx;
  }  else {
    printf("Fetal Error in RealDx!! @ %d \n", IndexI); exit(0);
  return DeltaCoord;
#undef __FUNCT__
#define __FUNCT__ "RealPx"
double RealPx(int IndexI) {
  double PhyCoord;
    PhyCoord = (rdx1==1.)?dx*(seci1-IndexI):dx*((pow(rdx1,seci1-IndexI+1)-1.0)/(rdx1-1.0)-1.);
    PhyCoord = TotalLength1_x - PhyCoord;
  } else if(IndexI > seci1 && IndexI <= seci1+seci2) {
    PhyCoord = TotalLength1_x + (IndexI-seci1)*dx;
  } else if(IndexI > seci1+seci2 && IndexI <= seci1+seci2+seci3) {
    PhyCoord = (rdx3==1.)?dx*(IndexI-seci1-seci2):dx*((pow(rdx3,IndexI-seci1-seci2+1)-1.0)/(rdx3-1.0)-1.);
    PhyCoord = TotalLength2_x + PhyCoord;
  } else {
    printf("Fetal Error in PhyX!!\n"); exit(0);
  return PhyCoord;
CFLAGS	         =
FFLAGS	         =
CPPFLAGS         =
FPPFLAGS         =
#LOCDIR           = src/ksp/ksp/examples/tutorials/
EXAMPLESC        = ex1.c ex2.c ex3.c ex4.c ex5.c ex7.c ex8.c ex8g.c ex9.c \
                ex10.c ex11.c ex12.c ex13.c ex15.c ex16.c ex18.c ex23.c \
                ex25.c ex27.c ex28.c ex29.c ex30.c ex31.c ex32.c ex34.c \
                 ex38.c ex39.c ex40.c ex41.c ex42.c ex43.c \
                ex45.c ex46.c  ex49.c ex50.c ex51.c ex52.c ex53.c \
                ex54.c ex55.c ex56.c ex58.c
EXAMPLESF        = ex1f.F ex2f.F ex6f.F ex11f.F ex13f90.F ex14f.F ex15f.F ex21f.F ex22f.F ex44f.F90 ex45f.F ex54f.F
MANSEC           = KSP
CLEANFILES       = rhs.vtk solution.vtk
NP               = 1
include ${PETSC_DIR}/conf/variables
include ${PETSC_DIR}/conf/rules
ex1: ex1.o  chkopts
	-${CLINKER} -o ex1 ex1.o  ${PETSC_KSP_LIB}
	${RM} ex1.o
ex1f: ex1f.o  chkopts
	-${FLINKER} -o ex1f ex1f.o  ${PETSC_KSP_LIB}
	${RM} ex1f.o
ex2: ex2.o  chkopts
	-${CLINKER} -o ex2 ex2.o  ${PETSC_KSP_LIB}
	${RM} ex2.o
ex2a: ex2a.o  chkopts
	-${CLINKER} -o ex2a ex2a.o  ${PETSC_KSP_LIB}
	${RM} ex2a.o
ex2f: ex2f.o  chkopts
	-${FLINKER} -o ex2f ex2f.o  ${PETSC_KSP_LIB}
	${RM} ex2f.o
ex3: ex3.o  chkopts
	-${CLINKER} -o ex3 ex3.o  ${PETSC_KSP_LIB}
	${RM} ex3.o
ex4: ex4.o  chkopts
	-${CLINKER} -o ex4 ex4.o  ${PETSC_KSP_LIB}
	${RM} ex4.o
ex5: ex5.o  chkopts
	-${CLINKER} -o ex5 ex5.o  ${PETSC_KSP_LIB}
	${RM} ex5.o
ex6: ex6.o  chkopts
	-${CLINKER} -o ex6 ex6.o  ${PETSC_KSP_LIB}
	${RM} ex6.o
ex6f: ex6f.o  chkopts
	-${FLINKER} -o ex6f ex6f.o  ${PETSC_KSP_LIB}
	${RM} ex6f.o
ex7: ex7.o  chkopts
	-${CLINKER} -o ex7 ex7.o  ${PETSC_KSP_LIB}
	${RM} ex7.o
ex8: ex8.o  chkopts
	-${CLINKER} -o ex8 ex8.o  ${PETSC_KSP_LIB}
	${RM} ex8.o
ex8g: ex8g.o  chkopts
	-${CLINKER} -o ex8g ex8g.o  ${PETSC_KSP_LIB}
	${RM} ex8g.o
ex9: ex9.o  chkopts
	-${CLINKER} -o ex9 ex9.o  ${PETSC_KSP_LIB}
	${RM} ex9.o
ex10: ex10.o  chkopts
	-${CLINKER} -o ex10 ex10.o  ${PETSC_KSP_LIB}
	${RM} ex10.o
ex11: ex11.o  chkopts
	-${CLINKER} -o ex11 ex11.o  ${PETSC_KSP_LIB}
	${RM} ex11.o
ex11f: ex11f.o  chkopts
	-${FLINKER} -o ex11f ex11f.o  ${PETSC_KSP_LIB}
	${RM} ex11f.o
ex12: ex12.o  chkopts
	-${CLINKER} -o ex12 ex12.o  ${PETSC_KSP_LIB}
	${RM} ex12.o
ex13: ex13.o  chkopts
	-${CLINKER} -o ex13 ex13.o  ${PETSC_KSP_LIB}
	${RM} ex13.o
ex13f90: ex13f90.o  chkopts
	-${FLINKER} -o ex13f90 ex13f90.o  ${PETSC_KSP_LIB}
	${RM} ex13f90.o
ex14: ex14.o  chkopts
	-${CLINKER} -o ex14 ex14.o  ${PETSC_KSP_LIB}
	${RM} ex14.o
ex14f: ex14f.o  chkopts
	-${FLINKER} -o ex14f ex14f.o  ${PETSC_KSP_LIB}
	${RM} ex14f.o
ex15: ex15.o  chkopts
	-${CLINKER} -o ex15 ex15.o  ${PETSC_KSP_LIB}
	${RM} ex15.o
ex15f: ex15f.o  chkopts
	-${FLINKER} -o ex15f ex15f.o  ${PETSC_KSP_LIB}
	${RM} ex15f.o
ex16: ex16.o  chkopts
	-${CLINKER} -o ex16 ex16.o  ${PETSC_KSP_LIB}
	${RM} ex16.o
ex17: ex17.o  chkopts
	-${CLINKER} -o ex17 ex17.o  ${PETSC_KSP_LIB}
	${RM} ex17.o
ex18: ex18.o  chkopts
	-${CLINKER} -o ex18 ex18.o  ${PETSC_KSP_LIB}
	${RM} ex18.o
ex20: ex20.o  chkopts
	-${CLINKER} -o ex20 ex20.o  ${PETSC_KSP_LIB}
	${RM} ex20.o
ex21f: ex21f.o  chkopts
	-${FLINKER} -o ex21f ex21f.o  ${PETSC_KSP_LIB}
	${RM} ex21f.o
ex22: ex22.o  chkopts
	-${CLINKER} -o ex22 ex22.o  ${PETSC_SNES_LIB}
	${RM} ex22.o
ex22f: ex22f.o  chkopts
	-${FLINKER} -o ex22f ex22f.o  ${PETSC_SNES_LIB}
	${RM} ex22f.o
ex23: ex23.o  chkopts
	-${CLINKER} -o ex23 ex23.o  ${PETSC_KSP_LIB}
	${RM} ex23.o
ex25: ex25.o  chkopts
	-${CLINKER} -o ex25 ex25.o  ${PETSC_SNES_LIB}
	${RM} ex25.o
ex26: ex26.o  chkopts
	-${CLINKER} -o ex26 ex26.o  ${PETSC_KSP_LIB}
	${RM} ex26.o
ex27: ex27.o  chkopts
	-${CLINKER} -o ex27 ex27.o  ${PETSC_KSP_LIB}
	${RM} ex27.o
ex28: ex28.o  chkopts
	-${CLINKER} -o ex28 ex28.o  ${PETSC_SNES_LIB}
	${RM} ex28.o
ex29: ex29.o  chkopts
	-${CLINKER} -o ex29 ex29.o  ${PETSC_SNES_LIB}
	${RM} ex29.o
ex30: ex30.o  chkopts
	-${CLINKER} -o ex30 ex30.o  ${PETSC_KSP_LIB}
	${RM} ex30.o
ex31: ex31.o  chkopts
	-${CLINKER} -o ex31 ex31.o  ${PETSC_SNES_LIB}
	${RM} ex31.o
ex32: ex32.o  chkopts
	-${CLINKER} -o ex32 ex32.o  ${PETSC_SNES_LIB}
	${RM} ex32.o
ex33: ex33.o chkopts
	-${CLINKER} -o ex33 ex33.o ${PETSC_SNES_LIB}
	${RM} ex33.o
ex34: ex34.o chkopts
	-${CLINKER} -o ex34 ex34.o ${PETSC_SNES_LIB}
	${RM} ex34.o
ex35: ex35.o chkopts
	-${CLINKER} -o ex35 ex35.o ${PETSC_SNES_LIB}
	${RM} ex35.o
ex36: ex36.o chkopts
	-${CLINKER} -o ex36 ex36.o ${PETSC_SNES_LIB}
	${RM} ex36.o
ex37: ex37.o chkopts
	-${CLINKER} -o ex37 ex37.o ${PETSC_SNES_LIB}
	${RM} ex37.o
ex38: ex38.o chkopts
	-${CLINKER} -o ex38 ex38.o ${PETSC_SNES_LIB}
	${RM} ex38.o
ex39: ex39.o chkopts
	-${CLINKER} -o ex39 ex39.o ${PETSC_SNES_LIB}
	${RM} ex39.o
ex40: ex40.o chkopts
	-${CLINKER} -o ex40 ex40.o ${PETSC_SNES_LIB}
	${RM} ex40.o
ex41: ex41.o chkopts
	-${CLINKER} -o ex41 ex41.o ${PETSC_SNES_LIB}
	${RM} ex41.o
ex42: ex42.o chkopts
	-${CLINKER} -o ex42 ex42.o ${PETSC_KSP_LIB}
	${RM} ex42.o
ex43: ex43.o chkopts
	-${CLINKER} -o ex43 ex43.o ${PETSC_KSP_LIB}
	${RM} ex43.o
# not tested in nightly builds because requires F90 compiler that handles long lines
ex44f: ex44f.o  chkopts
	-${FLINKER} -o ex44f ex44f.o  ${PETSC_KSP_LIB}
	${RM} ex44f.o
ex45f: ex45f.o  chkopts
	-${FLINKER} -o ex45f ex45f.o  ${PETSC_KSP_LIB}
	${RM} ex45f.o
ex45: ex45.o chkopts
	-${CLINKER} -o ex45 ex45.o ${PETSC_KSP_LIB}
	${RM} ex45.o
ex46: ex46.o chkopts
	-${CLINKER} -o ex46 ex46.o ${PETSC_KSP_LIB}
	${RM} ex46.o
ex47: ex47.o chkopts
	-${CLINKER} -o ex47 ex47.o ${PETSC_KSP_LIB}
	${RM} ex47.o
ex49: ex49.o chkopts
	-${CLINKER} -o ex49 ex49.o ${PETSC_KSP_LIB}
	${RM} ex49.o
ex50: ex50.o chkopts
	-${CLINKER} -o ex50 ex50.o ${PETSC_KSP_LIB}
	${RM} ex50.o
ex51: ex51.o chkopts
	-${CLINKER} -o ex51 ex51.o ${PETSC_KSP_LIB}
	${RM} ex51.o
ex52: ex52.o chkopts
	-${CLINKER} -o ex52 ex52.o ${PETSC_KSP_LIB}
	${RM} ex52.o
ex53: ex53.o chkopts
	-${CLINKER} -o ex53 ex53.o ${PETSC_KSP_LIB}
	${RM} ex53.o
ex54: ex54.o chkopts
	-${CLINKER} -o ex54 ex54.o ${PETSC_KSP_LIB}
	${RM} ex54.o
ex54f: ex54f.o  chkopts
	-${FLINKER} -o ex54f ex54f.o  ${PETSC_KSP_LIB}
	${RM} ex54f.o
ex55: ex55.o chkopts
	-${CLINKER} -o ex55 ex55.o ${PETSC_KSP_LIB}
	${RM} ex55.o
ex56: ex56.o chkopts
	-${CLINKER} -o ex56 ex56.o ${PETSC_KSP_LIB}
	${RM} ex56.o
ex57f: ex57f.o  chkopts
	-${FLINKER} -o ex57f ex57f.o  ${PETSC_KSP_LIB}
	${RM} ex57f.o
ex58: ex58.o chkopts
	-${CLINKER} -o ex58 ex58.o ${PETSC_KSP_LIB}
	${RM} ex58.o
ex59: ex59.o chkopts
	-${CLINKER} -o ex59 ex59.o ${PETSC_KSP_LIB}
	${RM} ex59.o
runex1:
	-@${MPIEXEC} -n 1 ./ex1 -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex1_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex1_1.out ex1_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex1_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex1_1.tmp
runex1_2:
	-@${MPIEXEC} -n 1 ./ex1 -pc_type sor -pc_sor_symmetric -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always >\
	   ex1_2.tmp 2>&1;   \
	   if (${DIFF} output/ex1_2.out ex1_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex1_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex1_2.tmp
runex1_3:
	-@${MPIEXEC} -n 1 ./ex1 -pc_type eisenstat -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always >\
	   ex1_3.tmp 2>&1;   \
	   if (${DIFF} output/ex1_3.out ex1_3.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex1_3, diffs above \n========================================="; fi; \
	   ${RM} -f ex1_3.tmp
runex1f:
	-@${MPIEXEC} -n 1 ./ex1f -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex1f_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex1f_1.out ex1f_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex1f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex1f_1.tmp
runex2:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_monitor_short -m 5 -n 5 -ksp_gmres_cgs_refinement_type refine_always > ex2_1.tmp 2>&1; \
	   if (${DIFF} output/ex2_1.out ex2_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex2_1.tmp
runex2_2:
	-@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 5 -n 5 -ksp_gmres_cgs_refinement_type refine_always > ex2_2.tmp 2>&1; \
	   if (${DIFF} output/ex2_2.out ex2_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex2_2.tmp
runex2_3:
	-@${MPIEXEC} -n 1 ./ex2 -pc_type sor -pc_sor_symmetric -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > \
	    ex2_3.tmp 2>&1;   \
	   if (${DIFF} output/ex2_3.out ex2_3.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_3, diffs above \n========================================="; fi; \
	   ${RM} -f ex2_3.tmp
runex2_4:
	-@${MPIEXEC} -n 1 ./ex2 -pc_type eisenstat -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always >\
	    ex2_4.tmp 2>&1;   \
	   if (${DIFF} output/ex2_4.out ex2_4.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_4, diffs above \n========================================="; fi; \
	   ${RM} -f ex2_4.tmp
runex2_5:
	-@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 5 -n 5 -mat_view draw -ksp_gmres_cgs_refinement_type refine_always -nox  > ex2_5.tmp 2>&1; \
	   if (${DIFF} output/ex2_2.out ex2_5.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_5, diffs above \n========================================="; fi; \
	   ${RM} -f ex2_5.tmp
runex2_7:
	-@${MPIEXEC} -n 1 ./ex2 -pc_type ilu -pc_factor_drop_tolerance 0.01,0.0,2 > ex2_7.tmp 2>&1; \
	   if (${DIFF} output/ex2_7.out ex2_7.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_7, diffs above \n========================================="; fi; \
	   ${RM} -f ex2_7.tmp
runex2_bjacobi:
	-@${MPIEXEC} -n 4 ./ex2 -pc_type bjacobi -pc_bjacobi_blocks 1 -ksp_monitor_short -sub_pc_type jacobi -sub_ksp_type gmres > ex2.tmp 2>&1; \
	   if (${DIFF} output/ex2_bjacobi.out ex2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_bjacobi, diffs above \n========================================="; fi; \
	   ${RM} -f ex2.tmp
runex2_bjacobi_2:
	-@${MPIEXEC} -n 4 ./ex2 -pc_type bjacobi -pc_bjacobi_blocks 2 -ksp_monitor_short -sub_pc_type jacobi -sub_ksp_type gmres -ksp_view > ex2.tmp 2>&1; \
	   if (${DIFF} output/ex2_bjacobi_2.out ex2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_bjacobi_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex2.tmp
runex2_bjacobi_3:
	-@${MPIEXEC} -n 4 ./ex2 -pc_type bjacobi -pc_bjacobi_blocks 4 -ksp_monitor_short -sub_pc_type jacobi -sub_ksp_type gmres > ex2.tmp 2>&1; \
	   if (${DIFF} output/ex2_bjacobi_3.out ex2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2_bjacobi_3, diffs above \n========================================="; fi; \
	   ${RM} -f ex2.tmp
runex2_specest_1:
	-@${MPIEXEC} -n 1 ./ex2 -m 80 -n 80 -ksp_type fgmres -pc_type ksp -ksp_ksp_type specest -ksp_monitor_short > ex2.tmp 2>&1; \
	   ${DIFF} output/ex2_specest_1.out ex2.tmp || echo ${PWD} "\nPossible problem with with ex2_specest_1, diffs above \n========================================="; \
	   ${RM} -f ex2.tmp
runex2_specest_2:
	-@${MPIEXEC} -n 1 ./ex2 -m 80 -n 80 -ksp_type fgmres -pc_type ksp -ksp_ksp_type specest -ksp_monitor_short -ksp_specest_ksp_type cg > ex2.tmp 2>&1; \
	   ${DIFF} output/ex2_specest_2.out ex2.tmp || echo ${PWD} "\nPossible problem with with ex2_specest_2, diffs above \n========================================="; \
	   ${RM} -f ex2.tmp
runex2_chebyest_1:
	-@${MPIEXEC} -n 1 ./ex2 -m 80 -n 80 -ksp_pc_side right -pc_type ksp -ksp_ksp_type chebyshev -ksp_ksp_max_it 5 -ksp_ksp_chebyshev_estimate_eigenvalues 0.9,0,0,1.1 -ksp_monitor_short > ex2.tmp 2>&1; \
           ${DIFF} output/ex2_chebyest_1.out ex2.tmp || echo ${PWD} "\nPossible problem with with ex2_chebyest_1, diffs above \n========================================="; \
           ${RM} -f ex2.tmp
runex2_chebyest_2:
	-@${MPIEXEC} -n 1 ./ex2 -m 80 -n 80 -ksp_pc_side right -pc_type ksp -ksp_ksp_type chebyshev -ksp_ksp_max_it 5 -ksp_ksp_chebyshev_estimate_eigenvalues 0.9,0,0,1.1 -ksp_est_ksp_type cg -ksp_monitor_short > ex2.tmp 2>&1; \
           ${DIFF} output/ex2_chebyest_2.out ex2.tmp || echo ${PWD} "\nPossible problem with with ex2_chebyest_2, diffs above \n========================================="; \
           ${RM} -f ex2.tmp
runex2_chebyest_3:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type fgmres -pc_type ksp -ksp_ksp_type chebyshev -ksp_ksp_chebyshev_estimate_eigenvalues 0.1,1.1 -ksp_ksp_max_it 1 -ksp_ksp_norm_type none -m 100 -n 100 -ksp_ksp_chebyshev_hybrid -ksp_ksp_chebyshev_hybrid_purification 0 -ksp_ksp_chebyshev_hybrid_chebysteps 10 > ex2.tmp 2>&1; \
           ${DIFF} output/ex2_chebyest_3.out ex2.tmp || echo ${PWD} "\nPossible problem with with ex2_chebyest_3, diffs above \n========================================="; \
           ${RM} -f ex2.tmp
runex2_chebyest_4:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type fgmres -pc_type ksp -ksp_ksp_type chebyshev -ksp_ksp_chebyshev_estimate_eigenvalues 0.1,1.1 -ksp_ksp_max_it 1 -ksp_ksp_norm_type none -m 100 -n 100 -ksp_ksp_chebyshev_hybrid -ksp_ksp_chebyshev_hybrid_purification 1 -ksp_ksp_chebyshev_hybrid_chebysteps 10 > ex2.tmp 2>&1; \
           ${DIFF} output/ex2_chebyest_4.out ex2.tmp || echo ${PWD} "\nPossible problem with with ex2_chebyest_3, diffs above \n========================================="; \
           ${RM} -f ex2.tmp
runex2_umfpack:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package umfpack > ex2_umfpack.tmp 2>&1; \
           if (${DIFF} output/ex2_umfpack.out ex2_umfpack.tmp) then true; \
           else echo ${PWD} ; echo "Possible problem with with ex2_umfpack, diffs above \n========================================="; fi; \
           ${RM} -f ex2_umfpack.tmp
runex2_fbcgs:
	-@${MPIEXEC} -n 1 ./ex2 -ksp_type fbcgs -pc_type ilu  > ex2.tmp 2>&1; \
           if (${DIFF} output/ex2_fbcgs.out ex2.tmp) then true; \
           else echo ${PWD} ; echo "Possible problem with with ex2_fbcgs, diffs above \n========================================="; fi; \
           ${RM} -f ex2.tmp
runex2_fbcgs_2:
	-@${MPIEXEC} -n 3 ./ex2 -ksp_type fbcgsr -pc_type bjacobi > ex2.tmp 2>&1; \
           if (${DIFF} output/ex2_fbcgs_2.out ex2.tmp) then true; \
           else echo ${PWD} ; echo "Possible problem with with ex2_fbcgs_2, diffs above \n========================================="; fi; \
           ${RM} -f ex2.tmp
runex2f:
	-@${MPIEXEC} -n 2 ./ex2f -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex2f_1.tmp 2>&1; \
	   if (${DIFF} output/ex2f_1.out ex2f_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex2f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex2f_1.tmp
runex5:
	-@${MPIEXEC} -n 1 ./ex5 -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex5_1.tmp 2>&1; \
	   if (${DIFF} output/ex5_1.out ex5_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex5_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex5_1.tmp
runex5_2:
	-@${MPIEXEC} -n 2 ./ex5 -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always \
	   -ksp_rtol .000001 > ex5_2.tmp 2>&1;   \
	   if (${DIFF} output/ex5_2.out ex5_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex5_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex5_2.tmp
runex5_5:
	-@${MPIEXEC} -n 2 ./ex5 -ksp_gmres_cgs_refinement_type refine_always > ex5_5.tmp 2>&1; \
	   if (${DIFF} output/ex5_5.out ex5_5.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex5_5, diffs above \n========================================="; fi; \
	   ${RM} -f ex5_5.tmp
runex6f:
	-@${MPIEXEC} -n 1 ./ex6f -pc_type jacobi -mat_view -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex6f_1.tmp 2>&1; \
	   if (${DIFF} output/ex6f_1.out ex6f_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex6f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex6f_1.tmp
runex7:
	-@${MPIEXEC} -n 2 ./ex7 -ksp_monitor_short -nokspview -ksp_gmres_cgs_refinement_type refine_always> ex7_1.tmp 2>&1; \
	   if (${DIFF} output/ex7_1.out ex7_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex7_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex7_1.tmp
runex9:
	-@${MPIEXEC} -n 1 ./ex9 -t 2 -pc_type jacobi -ksp_monitor_short -ksp_type gmres -ksp_gmres_cgs_refinement_type refine_always \
	   -s2_ksp_type bcgs -s2_pc_type jacobi -s2_ksp_monitor_short \
           > ex9_1.tmp 2>&1; \
	   if (${DIFF} output/ex9_1.out ex9_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex9_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex9_1.tmp
NP = 1
M  = 4
N  = 5
MDOMAINS = 2
NDOMAINS = 1
OVERLAP=1
runex8:
	-@${MPIEXEC} -n ${NP} ./ex8 -m $M -n $N -user_set_subdomains -Mdomains ${MDOMAINS} -Ndomains ${NDOMAINS} -overlap ${OVERLAP} -print_error ${ARGS}
VALGRIND=
runex8g:
	-@${MPIEXEC} -n ${NP} ${VALGRIND} ./ex8g -M $M -N $N -user_set_subdomains -Mdomains ${MDOMAINS} -Ndomains ${NDOMAINS} -overlap ${OVERLAP} -print_error ${ARGS}
BREAKPOINT=
runex8g_debug:
	-@${MPIEXEC} -n ${NP} xterm -e gdb -ex 'set breakpoint pending on' -ex 'b ${BREAKPOINT}' -ex r -ex bt --args ./ex8g -M $M -N $N -user_set_subdomains -Mdomains ${MDOMAINS} -Ndomains ${NDOMAINS} -overlap ${OVERLAP} -print_error ${ARGS}
runex8_1:
	-@${MPIEXEC} -n 1 ./ex8 -print_error > ex8_1.tmp 2>&1; \
	   if (${DIFF} output/ex8_1.out ex8_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex8_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex8_1.tmp
runex8g_1:
	-@${MPIEXEC} -n 1 ./ex8g -M 7 -N 9 -user_set_subdomains -Mdomains 1 -Ndomains 3 -overlap 1 -print_error -pc_gasm_print_subdomains > ex8g_1.tmp 2>&1; \
	    if (${DIFF} output/ex8g_1.out ex8g_1.tmp) then true; \
	    else echo ${PWD} ; echo "Possible problem with with ex8g_1, diffs above \n========================================="; fi; \
	    ${RM} -f ex8g_1.tmp
runex8g_2:
	-@${MPIEXEC} -n 2 ./ex8g -M 7 -N 9 -user_set_subdomains -Mdomains 1 -Ndomains 3 -overlap 1 -print_error -pc_gasm_print_subdomains > ex8g_2.tmp 2>&1; \
	   if (${DIFF} output/ex8g_2.out ex8g_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex8g_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex8g_2.tmp
runex8g_3:
	-@${MPIEXEC} -n 3 ./ex8g -M 7 -N 9 -user_set_subdomains -Mdomains 1 -Ndomains 3 -overlap 1 -print_error -pc_gasm_print_subdomains > ex8g_3.tmp 2>&1; \
	   if (${DIFF} output/ex8g_3.out ex8g_3.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex8g_3, diffs above \n========================================="; fi; \
	   ${RM} -f ex8g_3.tmp
runex10_basic:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${PETSC_DIR}/include/datafiles/matrices/spd-${PETSC_SCALAR_TYPE}-${PETSC_INDEX_SIZE}-${PETSC_SCALAR_SIZE} > ex10_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_1.out ex10_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_1.tmp
# See http://www.mcs.anl.gov/petsc/documentation/faq.html#datafiles for how to obtain the datafiles used below
runex10_2:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_type bicg \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_2.out ex10_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_2.tmp
runex10_3:
	-@${MPIEXEC} -n 2 ./ex10 -ksp_type bicg -pc_type asm \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_3.tmp 2>&1; \
	   if (${DIFF} output/ex10_3.out ex10_3.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_3, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_3.tmp
runex10_4:
	-@${MPIEXEC} -n 1 ./ex10 -ksp_type bicg -pc_type lu \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_4.tmp 2>&1; \
	   if (${DIFF} output/ex10_4.out ex10_4.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_4, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_4.tmp
runex10_5:
	-@${MPIEXEC} -n 1 ./ex10 -ksp_type bicg \
	   -f0 ${DATAFILESPATH}/matrices/medium > ex10_5.tmp 2>&1; \
	   if (${DIFF} output/ex10_5.out ex10_5.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_5, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_5.tmp
runex10_6:
	-@${MPIEXEC} -n 1 ./ex10 -pc_factor_levels 2 -pc_factor_fill 1.73 -ksp_gmres_cgs_refinement_type refine_always \
	   -f0 ${DATAFILESPATH}/matrices/fem1 > ex10_6.tmp 2>&1; \
	   if (${DIFF} output/ex10_6.out ex10_6.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_6, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_6.tmp
BS = 2 3 4 5 6 7 8
runex10_7:
	- at touch ex10_7.tmp
	- at for bs in ${BS}; do \
	 ${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -viewer_binary_skip_info \
                    -mat_type seqbaij -matload_block_size $$bs -ksp_max_it 100 -ksp_gmres_cgs_refinement_type refine_always -ksp_rtol \
                    1.0e-15 -ksp_monitor_short >> ex10_7.tmp 2>&1 ; \
                    1.0e-15 -ksp_monitor_short -pc_factor_mat_ordering_type nd >> ex10_7.tmp 2>&1 ; \
                    1.0e-15 -ksp_monitor_short -pc_factor_levels 1 >> ex10_7.tmp 2>&1 ; \
                    -mat_type seqbaij -matload_block_size $$bs -ksp_type preonly \
                    -ksp_monitor_short -pc_type lu  >> ex10_7.tmp 2>&1 ; \
         done;
	- at if (${DIFF} output/ex10_7.out ex10_7.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_7, diffs above \n========================================="; fi;
	-@${RM} -f ex10_7.tmp
runex10_8:
	-@${MPIEXEC} -n 1 ./ex10 -ksp_diagonal_scale -pc_type eisenstat -ksp_monitor_short -ksp_diagonal_scale_fix \
	   -f0 ${DATAFILESPATH}/matrices/medium -ksp_gmres_cgs_refinement_type refine_always  -mat_no_inode > ex10_8.tmp 2>&1; \
	   if (${DIFF} output/ex10_8.out ex10_8.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_8, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_8.tmp
runex10_9:
	- at touch ex10_9.tmp
	- at for type in gmres; do \
          for bs in 1 2 3 4 5 6 7; do \
                    1.0e-15 -ksp_monitor_short >> ex10_9.tmp 2>&1 ; \
	 ${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_gmres_cgs_refinement_type refine_always -viewer_binary_skip_info \
                    -mat_type seqbaij -matload_block_size $$bs -ksp_max_it 100 -ksp_rtol \
                    1.0e-15 -ksp_monitor_short -trans >> ex10_9.tmp 2>&1 ; \
          for np in 2 3; do \
	 ${MPIEXEC} -n $$np ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -viewer_binary_skip_info \
                    -mat_type mpibaij -matload_block_size $$bs -ksp_max_it 100 -ksp_gmres_cgs_refinement_type refine_always -ksp_rtol \
	 ${MPIEXEC} -n $$np ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_gmres_cgs_refinement_type refine_always -viewer_binary_skip_info \
                    -mat_type mpibaij -matload_block_size $$bs -ksp_max_it 100 -ksp_rtol \
         done; done; done;
	- at if (${DIFF} output/ex10_9.out ex10_9.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_9, diffs above \n========================================="; fi;
	-@${RM} -f ex10_9.tmp
runex10_10:
	-@${MPIEXEC} -n 2 ./ex10  -ksp_type fgmres -pc_type ksp \
	   -f0 ${DATAFILESPATH}/matrices/medium -ksp_fgmres_modifypcksp -ksp_monitor_short> ex10_10.tmp 2>&1; \
	   if (${DIFF} output/ex10_10.out ex10_10.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_10, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_10.tmp
runex10_11:
	-@${MPIEXEC} -n 2 ./ex10 -f0 http://ftp.mcs.anl.gov/pub/petsc/matrices/testmatrix.gz > ex10_11.tmp 2>&1;\
	   if (${DIFF} output/ex10_11.out ex10_11.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_11, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_11.tmp
runex10_12:
	-@${MPIEXEC} -n 1 ./ex10 -mat_aij_matlab -pc_type lu -f0 ${DATAFILESPATH}/matrices/arco1 > ex10_12.tmp 2>&1;\
	   if (${DIFF} output/ex10_12.out ex10_12.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_12, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_12.tmp
runex10_13:
	-@${MPIEXEC} -n 1 ./ex10 -mat_type lusol -pc_type lu -f0 ${DATAFILESPATH}/matrices/arco1 > ex10_13.tmp 2>&1;\
	   if (${DIFF} output/ex10_13.out ex10_13.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_13, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_13.tmp
runex10_14:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type spai -f0 ${DATAFILESPATH}/matrices/medium > ex10_14.tmp 2>&1; \
	  ${DIFF} output/ex10_14.out ex10_14.tmp || echo ${PWD} "\nPossible problem with with ex10_14, diffs above \n========================================="; \
	  ${RM} -f ex10_14.tmp
runex10_15:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type hypre -pc_hypre_type pilut -f0 ${DATAFILESPATH}/matrices/medium > ex10_15.tmp 2>&1;\
	   if (${DIFF} output/ex10_15.out ex10_15.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_15, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_15.tmp
runex10_16:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type hypre -pc_hypre_type parasails -f0 ${DATAFILESPATH}/matrices/medium > ex10_16.tmp 2>&1;\
	   if (${DIFF} output/ex10_16.out ex10_16.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_16, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_16.tmp
runex10_17:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type hypre -pc_hypre_type boomeramg -f0 ${DATAFILESPATH}/matrices/medium > ex10_17.tmp 2>&1;\
	   if (${DIFF} output/ex10_17.out ex10_17.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_17, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_17.tmp
#   The following leaves memory unfreed. It appears to be Euclid does something improper with its MPI_Comm
runex10_18:
	-@${MPIEXEC} -n 3 ./ex10 -pc_type hypre -pc_hypre_type euclid -f0 ${DATAFILESPATH}/matrices/medium > ex10_18.tmp 2>&1;\
	   if (${DIFF} output/ex10_18.out ex10_18.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_18, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_18.tmp
LEVELS = 0 2 4
runex10_19:
	- at touch ex10_19aij.tmp
	- at touch ex10_19sbaij.tmp
	- at for levels in ${LEVELS}; do \
	${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/poisson1 -ksp_type cg -pc_type icc -pc_factor_levels $$levels >> ex10_19aij.tmp 2>&1; \
	 ${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/poisson1 -ksp_type cg -pc_type icc -pc_factor_levels $$levels -mat_type seqsbaij >> ex10_19sbaij.tmp 2>&1; \
	done;
	- at if (${DIFF} ex10_19aij.tmp ex10_19sbaij.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_19, diffs above \n========================================="; fi; \
	${RM} -f ex10_19aij.tmp ex10_19sbaij.tmp
# Start a sequential user code [on 1 node, assembling seqaij] and then
# spwan a parallel solver on 2 procs.
runex10_22:
	-@${MPIEXEC} -n 2 ./ex10 -hmpi_merge_size 2 -pc_type hmpi  -ksp_type preonly -hmpi_pc_type ksp -f0 ${DATAFILESPATH}/matrices/medium > ex10_22.tmp 2>&1;\
	   if (${DIFF} output/ex10_22.out ex10_22.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_22, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_22.tmp
runex10_23:
	-@${MPIEXEC} -n 2 ./ex10 -hmpi_merge_size 2 -pc_type hmpi  -ksp_type preonly -hmpi_pc_type ksp -hmpi_ksp_pc_type bjacobi -hmpi_ksp_ksp_type gmres -f0 ${DATAFILESPATH}/matrices/medium > ex10_23.tmp 2>&1;\
	   if (${DIFF} output/ex10_23.out ex10_23.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_23, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_23.tmp
runex10_24:
	-@${MPIEXEC} -n 2 ./ex10 -hmpi_merge_size 2 -pc_type hmpi -hmpi_pc_type sor -f0 ${DATAFILESPATH}/matrices/medium -hmpi_ksp_monitor_short -initialguess -ksp_type gmres -ksp_monitor_short -ksp_view > ex10_24.tmp 2>&1;\
	   if (${DIFF} output/ex10_24.out ex10_24.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_24, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_24.tmp
# Start a parallel user code [on 4 nodes, assembling MPIAIJ with
# np=4] and then spwan a parallel sub-domain-solver on each node
# [with np=2]. This emulates mixed MPI-shared memory model [MPI between
# nodes, MPI within the nodes]
runex10_25:
	-@${MPIEXEC} -n 8 ./ex10 -hmpi_merge_size 2 -sub_pc_type hmpi -f0 ${DATAFILESPATH}/matrices/medium -ksp_monitor_short> ex10_25.tmp 2>&1;\
	   if (${DIFF} output/ex10_25.out ex10_25.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_25, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_25.tmp
runex10_superlu_lu_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu -num_numfac 2 -num_rhs 2 > ex10_superlu_lu_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_superlu_lu_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_superlu_lu_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_superlu_lu_1.tmp
runex10_superlu_dist_lu_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist -num_numfac 2 -num_rhs 2 > ex10_superlu_lu_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_superlu_lu_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_superlu_lu_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_superlu_lu_2.tmp
runex10_superlu_dist_lu_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist -num_numfac 2 -num_rhs 2 > ex10_superlu_lu_2.tmp 2>&1; \
runex10_umfpack:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type seqaij -pc_factor_mat_solver_package umfpack -num_numfac 2 -num_rhs 2 > ex10_umfpack.tmp 2>&1; \
	   if (${DIFF} output/ex10_umfpack.out ex10_umfpack.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_umfpack, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_umfpack.tmp
runex10_mumps_lu_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type seqaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_lu_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_lu_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_lu_1.tmp
runex10_mumps_lu_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type mpiaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_lu_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_lu_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_lu_2.tmp
runex10_mumps_lu_3:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type seqbaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -matload_block_size 2 > ex10_mumps_lu_3.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_3.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_lu_3, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_lu_3.tmp
runex10_mumps_lu_4:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type lu -mat_type mpibaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -matload_block_size 2 > ex10_mumps_lu_4.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_lu_4.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_lu_4, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_lu_4.tmp
runex10_mumps_cholesky_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type sbaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -mat_ignore_lower_triangular > ex10_mumps_cholesky_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_cholesky_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_cholesky_1.tmp
runex10_mumps_cholesky_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type sbaij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 -mat_ignore_lower_triangular > ex10_mumps_cholesky_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_cholesky_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_cholesky_2.tmp
runex10_mumps_cholesky_3:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_3.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_3.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_cholesky_3, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_cholesky_3.tmp
runex10_mumps_cholesky_4:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_4.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_4.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_cholesky_4, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_cholesky_4.tmp
runex10_mumps_cholesky_spd_1:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -matload_spd -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_spd_1.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_spd_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_cholesky_spd_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_cholesky_spd_1.tmp
runex10_mumps_cholesky_spd_2:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_type preonly -pc_type cholesky -mat_type aij -matload_spd -pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 > ex10_mumps_cholesky_spd_2.tmp 2>&1; \
	   if (${DIFF} output/ex10_mumps.out ex10_mumps_cholesky_spd_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_cholesky_spd_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mumps_cholesky_spd_2.tmp
NSUBCOMM = 8 7 6 5 4 3 2 1
runex10_mumps_redundant:
	- at touch ex10_mumps_redundant.tmp
	- at for nsubcomm in ${NSUBCOMM}; do \
	${MPIEXEC} -n 8 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_type preonly -pc_type redundant -pc_redundant_number $$nsubcomm -redundant_pc_factor_mat_solver_package mumps -num_numfac 2 -num_rhs 2 >> ex10_mumps_redundant.tmp 2>&1; \
	done;
	- at if (${DIFF} output/ex10_mumps_redundant.out ex10_mumps_redundant.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mumps_redundant, diffs above \n========================================="; fi; \
	${RM} -f ex10_mumps_redundant.tmp;
runex10_superlu_dist_redundant:
	- at touch ex10_superlu_dist_redundant.tmp
	${MPIEXEC} -n 8 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_type preonly -pc_type redundant -pc_redundant_number $$nsubcomm -redundant_pc_factor_mat_solver_package superlu_dist -num_numfac 2 -num_rhs 2 >> ex10_superlu_dist_redundant.tmp 2>&1; \
	done;
	- at if (${DIFF} output/ex10_mumps_redundant.out ex10_superlu_dist_redundant.tmp) then true; \
	  else echo ${PWD} ; echo "Possible problem with with ex10_superlu_dist_redundant, diffs above \n========================================="; fi; \
	${RM} -f ex10_superlu_dist_redundant.tmp;
runex10_ILU: # test ilu fill greater than zero
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -pc_factor_levels 1  > ex10_20.tmp 2>&1; \
	   if (${DIFF} output/ex10_ILU.out ex10_20.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_ILU, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_20.tmp
runex10_ILUBAIJ: # test ilu fill greater than zero
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -pc_factor_levels 1 -mat_type baij > ex10_20.tmp 2>&1; \
runex10_cg:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -mat_type mpisbaij -ksp_type cg -pc_type eisenstat -ksp_monitor_short -ksp_converged_reason > ex10_20.tmp 2>&1; \
	   if (${DIFF} output/ex10_cg_singlereduction.out ex10_20.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_cg, diffs above \n========================================="; fi; \
runex10_cg_singlereduction:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -mat_type mpisbaij -ksp_type cg -pc_type eisenstat -ksp_monitor_short -ksp_converged_reason -ksp_cg_single_reduction > ex10_20.tmp 2>&1; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_cg_singlereduction, diffs above \n========================================="; fi; \
runex10_seqaijcrl:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type seqaijcrl > ex10_seqaijcrl.tmp 2>&1; \
	   if (${DIFF} output/ex10_seqcrl.out ex10_seqaijcrl.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_seqaijcrl, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_seqaijcrl.tmp
runex10_mpiaijcrl:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type mpiaijcrl > ex10_mpiaijcrl.tmp 2>&1; \
	   if (${DIFF} output/ex10_mpiaij.out ex10_mpiaijcrl.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mpiaijcrl, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mpiaijcrl.tmp
runex10_seqaijperm:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type seqaijperm > ex10_seqaijperm.tmp 2>&1; \
	   if (${DIFF} output/ex10_seqcsrperm.out ex10_seqaijperm.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_seqaijperm, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_seqaijperm.tmp
runex10_mpiaijperm:
	-@${MPIEXEC} -n 2 ./ex10 -f0 ${DATAFILESPATH}/matrices/small -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type mpiaijperm > ex10_mpiaijperm.tmp 2>&1; \
	   if (${DIFF} output/ex10_mpicsrperm.out ex10_mpiaijperm.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_mpiaijperm, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_mpiaijperm.tmp
runex10_aijcusparse:
	-@${MPIEXEC} -n 1 ./ex10 -f0 ${DATAFILESPATH}/matrices/medium -ksp_monitor_short -ksp_view -mat_view ascii::ascii_info -mat_type aijcusparse > ex10_aijcusparse.tmp 2>&1; \
	   if (${DIFF} output/ex10_aijcusparse.out ex10_aijcusparse.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex10_aijcusparse, diffs above \n========================================="; fi; \
	   ${RM} -f ex10_aijcusparse.tmp
runex11:
	-@${MPIEXEC} -n 1 ./ex11 -n 6 -norandom -pc_type none -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex11_1.tmp 2>&1; \
	   if (${DIFF} output/ex11_1.out ex11_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex11_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex11_1.tmp
runex11f:
	-@${MPIEXEC} -n 1 ./ex11f -n 6 -norandom -pc_type none -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex11f_1.tmp 2>&1; \
	   if (${DIFF} output/ex11f_1.out ex11f_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex11f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex11f_1.tmp
runex12:
	-@${MPIEXEC} -n 1 ./ex12 -ksp_gmres_cgs_refinement_type refine_always > ex12_1.tmp 2>&1; \
	   if (${DIFF} output/ex12_1.out ex12_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex12_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex12_1.tmp
runex13:
	-@${MPIEXEC} -n 1 ./ex13 -m 19 -n 20 -ksp_gmres_cgs_refinement_type refine_always > ex13_1.tmp 2>&1; \
	   if (${DIFF} output/ex13_1.out ex13_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex13_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex13_1.tmp
runex13f90:
	-@${MPIEXEC} -n 1 ./ex13f90 -m 19 -n 20 -ksp_gmres_cgs_refinement_type refine_always > ex13f90_1.tmp 2>&1; \
	   if (${DIFF} output/ex13f90_1.out ex13f90_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex13f90_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex13f90_1.tmp
runex14f:
	-@${MPIEXEC} -n 1 ./ex14f -no_output -ksp_gmres_cgs_refinement_type refine_always > ex14_1.tmp 2>&1; \
	   if (${DIFF} output/ex14_1.out ex14_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex14f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex14_1.tmp
runex15:
	-@${MPIEXEC} -n 2 ./ex15 -ksp_view -user_defined_pc -ksp_gmres_cgs_refinement_type refine_always > ex15_1.tmp 2>&1; \
	   if (${DIFF} output/ex15_1.out ex15_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex15_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex15_1.tmp
runex15f:
	-@${MPIEXEC} -n 2 ./ex15f -ksp_view -user_defined_pc -ksp_gmres_cgs_refinement_type refine_always > ex15f_1.tmp 2>&1; \
	   if (${DIFF} output/ex15f_1.out ex15f_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex15f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex15f_1.tmp
runex16:
	-@${MPIEXEC} -n 2 ./ex16 -ntimes 4 -ksp_gmres_cgs_refinement_type refine_always > ex16_1.tmp 2>&1; \
	   if (${DIFF} output/ex16_1.out ex16_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex16_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex16_1.tmp
runex18:
	-@${MPIEXEC} -n 3 ./ex18 -m 39 -n 18 -ksp_monitor_short -permute nd > ex18_1.tmp 2>&1; \
	   ${DIFF} output/ex18_1.out ex18_1.tmp || printf "${PWD}\nPossible problem with with ex18_1, diffs above \n========================================="; \
	   ${RM} -f ex18_1.tmp
runex18_2:
	-@${MPIEXEC} -n 3 ./ex18 -m 39 -n 18 -ksp_monitor_short -permute rcm > ex18_2.tmp 2>&1; \
	   ${DIFF} output/ex18_2.out ex18_2.tmp || printf "${PWD}\nPossible problem with with ex18_2, diffs above \n========================================="; \
	   ${RM} -f ex18_2.tmp
runex21f:
	-@${MPIEXEC} -n 1 ./ex21f  > ex21f_1.tmp 2>&1; \
	   if (${DIFF} output/ex21f_1.out ex21f_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex21f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex21f_1.tmp
runex22f:
	-@${MPIEXEC} -n 1 ./ex22f -pc_mg_type full -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type preconditioned -pc_type mg -da_refine 2 -ksp_type fgmres > ex22_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex22_1.out ex22_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex22f_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex22_1.tmp
runex23:
	-@${MPIEXEC} -n 1 ./ex23 -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex23_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex23_1.out ex23_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex23_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex23_1.tmp
runex23_2:
	-@${MPIEXEC} -n 3 ./ex23 -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always > ex23_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex23_2.out ex23_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex23_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex23_2.tmp
runex25:
	-@${MPIEXEC} -n 1 ./ex25 -pc_type mg -ksp_type fgmres -da_refine 2 -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type unpreconditioned -ksp_view -pc_mg_type full  > ex25_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex25_1.out ex25_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex25_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex25_1.tmp
runex25_2:
	-@${MPIEXEC} -n 2 ./ex25 -pc_type mg -ksp_type fgmres -da_refine 2 -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type unpreconditioned -ksp_view -pc_mg_type full > ex25_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex25_2.out ex25_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex25_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex25_2.tmp
runex28:
	-@${MPIEXEC} -n 1 ./ex28 -ksp_monitor_short -pc_type mg -pc_mg_type full -ksp_type fgmres -da_refine 2 -mg_levels_ksp_type gmres -mg_levels_ksp_max_it 1 -mg_levels_pc_type ilu > ex28_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex28_1.out ex28_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex28_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex28_1.tmp
runex29:
	-@${MPIEXEC} -n 1 ./ex29 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 8 > ex29_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex29_1.out ex29_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex29_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex29_1.tmp
runex29_2:
	-@${MPIEXEC} -n 1 ./ex29  -bc_type neumann -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 8 -mg_levels_pc_factor_shift_type nonzero -mg_coarse_pc_factor_shift_type nonzero > ex29_2.tmp 2>&1;	  \
	   if (${DIFF} output/ex29_2.out ex29_2.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex29_2, diffs above \n========================================="; fi; \
	   ${RM} -f ex29_2.tmp
runex30:
	-@${MPIEXEC} -n 1 ./ex30 > ex30_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex30_1.out ex30_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex30_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex30_1.tmp
runex32:
	-@${MPIEXEC} -n 1 ./ex32 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -pc_mg_levels 3 -mg_coarse_pc_factor_shift_type nonzero > ex32_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex32_1.out ex32_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex32_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex32_1.tmp
runex34:
	-@${MPIEXEC} -n 1 ./ex34  -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -pc_mg_levels 3 -mg_coarse_pc_factor_shift_type nonzero -ksp_view > ex34_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex34_1.out ex34_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex34_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex34_1.tmp
runex38:
	-@${MPIEXEC} -n 1 ./ex38 -ksp_monitor_short  > ex38_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex38_1.out ex38_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex38_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex38_1.tmp
runex39:
	-@${MPIEXEC} -n 1 ./ex39 -mat_no_inode -ksp_monitor_short  > ex39_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex39_1.out ex39_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex39_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex39_1.tmp
runex40:
	-@${MPIEXEC} -n 1 ./ex40 -mat_no_inode -ksp_monitor_short  > ex40_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex40_1.out ex40_1.tmp) then true; \
	   else echo ${PWD} ; echo "Possible problem with with ex40_1, diffs above \n========================================="; fi; \
	   ${RM} -f ex40_1.tmp
runex43:
	-@${MPIEXEC} -n 1 ./ex43 -stokes_ksp_type fgmres -stokes_ksp_rtol 1e-8 -stokes_pc_type fieldsplit -stokes_pc_fieldsplit_block_size 3 -stokes_pc_fieldsplit_type SYMMETRIC_MULTIPLICATIVE -stokes_pc_fieldsplit_0_fields 0,1 -stokes_pc_fieldsplit_1_fields 2 -stokes_fieldsplit_0_ksp_type preonly -stokes_fieldsplit_0_pc_type lu -stokes_fieldsplit_1_ksp_type preonly -stokes_fieldsplit_1_pc_type jacobi -c_str 0 -solcx_eta0 1.0 -solcx_eta1 1.0e6 -solcx_xc 0.5 -solcx_nz 2 -mx 20 -my 20 -stokes_ksp_monitor_short > ex43_1.tmp 2>&1;	  \
	   ${DIFF} output/ex43_1.out ex43_1.tmp || echo ${PWD} "\nPossible problem with with ex43_1, diffs above \n========================================="; \
	   ${RM} -f ex43_1.tmp
runex43_2:
	-@${MPIEXEC} -n 1 ./ex43 -stokes_ksp_type fgmres -stokes_ksp_rtol 1e-8 -stokes_pc_type fieldsplit -stokes_pc_fieldsplit_block_size 3 -stokes_pc_fieldsplit_type SYMMETRIC_MULTIPLICATIVE -stokes_fieldsplit_u_ksp_type preonly -stokes_fieldsplit_u_pc_type lu -stokes_fieldsplit_p_ksp_type preonly -stokes_fieldsplit_p_pc_type jacobi -c_str 0 -solcx_eta0 1.0 -solcx_eta1 1.0e6 -solcx_xc 0.5 -solcx_nz 2 -mx 20 -my 20 -stokes_ksp_monitor_short > ex43_2.tmp 2>&1;	  \
	   ${DIFF} output/ex43_1.out ex43_2.tmp || echo ${PWD} "\nPossible problem with with ex43_2, diffs above \n========================================="; \
	   ${RM} -f ex43_2.tmp
runex43_3:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_ksp_type gcr -stokes_ksp_gcr_restart 60 -stokes_ksp_norm_type unpreconditioned -stokes_ksp_rtol 1e-8 -c_str 3 -sinker_eta0 1.0 -sinker_eta1 100 -sinker_dx 0.4 -sinker_dy 0.3 -mx 128 -my 128 -stokes_ksp_monitor_short -stokes_pc_type mg -stokes_mg_levels_pc_type fieldsplit -stokes_pc_mg_galerkin -stokes_mg_levels_pc_fieldsplit_block_size 3 -stokes_mg_levels_pc_fieldsplit_0_fields 0,1 -stokes_mg_levels_pc_fieldsplit_1_fields 2 -stokes_mg_levels_fieldsplit_0_pc_type sor -stokes_mg_levels_fieldsplit_1_pc_type sor -stokes_mg_levels_ksp_type chebyshev -stokes_mg_levels_ksp_max_it 1 -stokes_mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.2,0,1.1 -stokes_pc_mg_levels 4 -stokes_ksp_view > ex43_3.tmp 2>&1;	  \
	   ${DIFF} output/ex43_3.out ex43_3.tmp || echo ${PWD} "\nPossible problem with with ex43_3, diffs above \n========================================="; \
	   ${RM} -f ex43_3.tmp
runex43_bjacobi:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_pc_type bjacobi -stokes_pc_bjacobi_blocks 2 -mat_type aij -stokes_ksp_converged_reason > ex43.tmp 2>&1;	  \
	   ${DIFF} output/ex43_bjacobi.out ex43.tmp || echo ${PWD} "\nPossible problem with with ex43_bjacobi, diffs above \n========================================="; \
	   ${RM} -f ex43.tmp
runex43_bjacobi_baij:
	-@${MPIEXEC} -n 4 ./ex43 -stokes_pc_type bjacobi -stokes_pc_bjacobi_blocks 2 -mat_type baij -stokes_ksp_converged_reason > ex43.tmp 2>&1;	  \
	   ${DIFF} output/ex43_bjacobi.out ex43.tmp || echo ${PWD} "\nPossible problem with with ex43_bjacobi_baij, diffs above \n========================================="; \
	   ${RM} -f ex43.tmp
runex45:
	-@${MPIEXEC} -n 4 ./ex45 -pc_type exotic -ksp_monitor_short -ksp_type fgmres -mg_levels_ksp_type gmres -mg_levels_ksp_max_it 1 -mg_levels_pc_type bjacobi > ex45_1.tmp 2>&1;	  \
	   ${DIFF} output/ex45_1.out ex45_1.tmp || echo ${PWD} "\nPossible problem with with ex45_1, diffs above \n========================================="; \
	   ${RM} -f ex45_1.tmp
runex45_2:
	-@${MPIEXEC} -n 4 ./ex45 -ksp_monitor_short -da_grid_x 21 -da_grid_y 21 -da_grid_z 21 -pc_type mg -pc_mg_levels 3 -mg_levels_ksp_type richardson -mg_levels_ksp_max_it 1 -mg_levels_pc_type bjacobi > ex45_2.tmp 2>&1; \
	   ${DIFF} output/ex45_2.out ex45_2.tmp || echo ${PWD} "\nPossible problem with with ex45_2, diffs above \n========================================="; \
	   ${RM} -f ex45_2.tmp
runex45f:
	-@${MPIEXEC} -n 4 ./ex45f -ksp_monitor_short -da_refine 5 -pc_type mg -pc_mg_levels 5 -mg_levels_ksp_type chebyshev -mg_levels_ksp_max_it 2 -mg_levels_pc_type jacobi -ksp_pc_side right > ex45f_1.tmp 2>&1; \
	   ${DIFF} output/ex45f_1.out ex45f_1.tmp || echo ${PWD} "\nPossible problem with with ex45f_1, diffs above \n========================================="; \
	   ${RM} -f ex45f_1.tmp
runex49:
	-@${MPIEXEC} -n 1 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 3 -sponge_E0 1 -sponge_E1 1000 -sponge_nu0 0.4 -sponge_nu1 0.2 -sponge_t 1 -sponge_w 8 > ex49_1.tmp 2>&1;	  \
	   ${DIFF} output/ex49_1.out ex49_1.tmp || echo ${PWD} "\nPossible problem with with ex49_1, diffs above \n========================================="; \
	   ${RM} -f ex49_1.tmp
runex49_2:
	-@${MPIEXEC} -n 4 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 3 -sponge_E0 1 -sponge_E1 1000 -sponge_nu0 0.4 -sponge_nu1 0.2 -sponge_t 1 -sponge_w 8 -elas_ksp_type gcr -elas_pc_type asm -elas_sub_pc_type lu > ex49_2.tmp 2>&1;	  \
	   ${DIFF} output/ex49_2.out ex49_2.tmp || echo ${PWD} "\nPossible problem with with ex49_2, diffs above \n========================================="; \
	   ${RM} -f ex49_2.tmp
runex49_3:
	-@${MPIEXEC} -n 4 ./ex49 -mx 20 -my 30 -elas_ksp_monitor_short -no_view -c_str 2 -brick_E 1,10,1000,100 -brick_nu 0.4,0.2,0.3,0.1 -brick_span 3 -elas_pc_type asm -elas_sub_pc_type lu > ex49_3.tmp 2>&1; \
	   ${DIFF} output/ex49_3.out ex49_3.tmp || echo ${PWD} "\nPossible problem with with ex49_3, diffs above \n========================================="; \
	   ${RM} -f ex49_3.tmp
runex49_4:
	-@${MPIEXEC} -n 4 ./ex49 -elas_ksp_monitor_short -elas_ksp_converged_reason -elas_ksp_type cg -elas_ksp_norm_type unpreconditioned -mx 40 -my 40 -c_str 2 -brick_E 1,1e-6,1e-2 -brick_nu .3,.2,.4 -brick_span 8 -elas_mg_levels_ksp_type chebyshev -elas_pc_type ml -elas_mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.2,0,1.1 -elas_mg_levels_pc_type pbjacobi -elas_mg_levels_ksp_max_it 2 -use_nonsymbc -elas_pc_ml_nullspace user > ex49_4.tmp 2>&1; \
	   ${DIFF} output/ex49_4.out ex49_4.tmp || echo ${PWD} "\nPossible problem with with ex49_4, diffs above \n========================================="; \
	   ${RM} -f ex49_4.tmp
runex50:
	-@${MPIEXEC} -n 1 ./ex50 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 1 -mg_levels_pc_factor_shift_type nonzero -mg_coarse_pc_factor_shift_type nonzero -ksp_view  > ex50.tmp 2>&1;         \
        ${DIFF} output/ex50.out ex50.tmp || echo ${PWD} "\nPossible problem with with ex50, diffs above \n========================================="; \
        ${RM} -f ex50.tmp
runex50_2:
	-@${MPIEXEC} -n 2 ./ex50 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -da_refine 1 -mg_levels_sub_pc_factor_shift_type nonzero -mg_coarse_pc_type redundant -mg_coarse_redundant_pc_type svd -ksp_view > ex50_2.tmp 2>&1;         \
        ${DIFF} output/ex50_2.out ex50_2.tmp || echo ${PWD} "\nPossible problem with with ex50_2, diffs above \n========================================="; \
        ${RM} -f ex50_2.tmp
runex52_mumps:
	-@${MPIEXEC} -n 1 ./ex52 -use_mumps_lu > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_1.out ex52.tmp || echo ${PWD} "\nPossible problem with with ex52_mumps, diffs above \n========================================="; \
	   ${RM} -f ex52.tmp
runex52_mumps_2:
	-@${MPIEXEC} -n 1 ./ex52 -use_mumps_ch > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_1.out ex52.tmp || echo ${PWD} "\nPossible problem with with ex52_mumps_2, diffs above \n========================================="; \
	   ${RM} -f ex52.tmp
runex52_superlu:
	-@${MPIEXEC} -n 1 ./ex52 -use_superlu_ilu > ex52.tmp 2>&1;	  \
	   ${DIFF} output/ex52_1.out ex52.tmp || echo ${PWD} "\nPossible problem with with ex52, diffs above \n========================================="; \
	   ${RM} -f ex52.tmp
runex53:
	-@${MPIEXEC} -n 1 ./ex53 > ex53.tmp 2>&1;         \
        ${DIFF} output/ex53.out ex53.tmp || echo ${PWD} "\nPossible problem with with ex53, diffs above \n========================================="; \
        ${RM} -f ex53.tmp
runex53_2:
	-@${MPIEXEC} -n 2 ./ex53 > ex53.tmp 2>&1;	  \
	   ${DIFF} output/ex53.out ex53.tmp || echo ${PWD} "\nPossible problem with with ex53_2, diffs above \n========================================="; \
	   ${RM} -f ex53.tmp
runex54:
	-@${MPIEXEC} -n 4 ./ex54 -ne 109 -alpha 1.e-3 -ksp_monitor_short -ksp_type cg -pc_gamg_type geo  -ksp_converged_reason -pc_gamg_coarse_eq_limit 80 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.05,0,1.05 -mg_levels_pc_type jacobi > ex54.tmp 2>&1;	  \
         ${DIFF} output/ex54_0.out ex54.tmp || echo ${PWD} "\nPossible problem with with ex54_0, diffs above \n========================================="; \
        ${RM} -f ex54.tmp
runex54_SA:
	-@${MPIEXEC} -n 4 ./ex54 -ne 109 -alpha 1.e-3 -ksp_monitor_short -ksp_type cg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1  -ksp_converged_reason -pc_gamg_coarse_eq_limit 80 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.05,0,1.05 -mg_levels_pc_type jacobi > ex54_sa.tmp 2>&1; \
         ${DIFF} output/ex54_1.out ex54_sa.tmp || echo ${PWD} "\nPossible problem with with ex54_1, diffs above \n======================================"; \
        ${RM} -f ex54_sa.tmp
runex54f:
	-@${MPIEXEC} -n 4 ./ex54f -ne 59 -theta 30.0 -epsilon 1.e-1 -ksp_monitor_short -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -ksp_converged_reason  -pc_gamg_coarse_eq_limit 80 -blob_center 0.,0. -mat_coarsen_type hem -pc_gamg_square_graph false > ex54f.tmp 2>&1; \
         ${DIFF} output/ex54f.out ex54f.tmp || echo ${PWD} "\nPossible problem with with ex54f, diffs above \n======================================"; \
        ${RM} -f ex54f.tmp
runex55:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_monitor_short -ksp_type cg -pc_gamg_type geo -use_coordinates -ksp_converged_reason -pc_gamg_coarse_eq_limit 80 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.05,0,1.05 -mg_levels_pc_type jacobi > ex55.tmp 2>&1;	  \
         ${DIFF} output/ex55_0.out ex55.tmp || echo ${PWD} "\nPossible problem with with ex55_0, diffs above \n========================================="; \
        ${RM} -f ex55.tmp
runex55_SA:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_monitor_short -ksp_type cg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -use_coordinates -ksp_converged_reason -pc_gamg_coarse_eq_limit 80 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.05,0,1.05 -mg_levels_pc_type jacobi > ex55_sa.tmp 2>&1; \
         ${DIFF} output/ex55_sa.out ex55_sa.tmp || echo ${PWD} "\nPossible problem with with ex55_SA, diffs above \n========================================="; \
        ${RM} -f ex55_sa.tmp
runex55_NC:
	-@${MPIEXEC} -n 4 ./ex55 -ne 29 -alpha 1.e-3 -ksp_monitor_short -ksp_type cg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1  -ksp_converged_reason -pc_gamg_coarse_eq_limit 80 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.05,0,1.05 -mg_levels_pc_type jacobi > ex55_nc.tmp 2>&1; \
         ${DIFF} output/ex55_NC.out ex55_nc.tmp || echo ${PWD} "\nPossible problem with with ex55_NC, diffs above \n======================================"; \
        ${RM} -f ex55_nc.tmp
runex56:
	-@${MPIEXEC} -n 8 ./ex56 -ne 19 -alpha 1.e-3 -ksp_monitor_short -ksp_type cg -ksp_max_it 50 -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -ksp_converged_reason -pc_gamg_coarse_eq_limit 80 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.05,0,1.05 -mg_levels_pc_type sor -pc_gamg_reuse_interpolation true -two_solves > ex56.tmp 2>&1;	\
         ${DIFF} output/ex56_0.out ex56.tmp || echo ${PWD} "\nPossible problem with with ex56_0, diffs above \n========================================="; \
         ${RM} -f ex56.tmp
runex56_ml:
	-@${MPIEXEC} -n 8 ./ex56 -ne 19 -alpha 1.e-3 -ksp_monitor_short -ksp_type cg -ksp_max_it 50 -pc_type ml -ksp_converged_reason -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.05,0,1.05 -mg_levels_pc_type jacobi > ex56.tmp 2>&1;	\
         ${DIFF} output/ex56_ml.out ex56.tmp || echo ${PWD} "\nPossible problem with with ex56_2, diffs above \n========================================="; \
        ${RM} -f ex56.tmp
runex58:
	-@${MPIEXEC} -n 1 ./ex58 -mat_type aij > ex58.tmp 2>&1;         \
	${DIFF} output/ex58.out ex58.tmp || echo ${PWD} "\nPossible problem with with ex58, diffs above \n========================================="; \
	${RM} -f ex58.tmp
runex58_baij:
	-@${MPIEXEC} -n 1 ./ex58 -mat_type baij > ex58.tmp 2>&1;         \
	${DIFF} output/ex58.out ex58.tmp || echo ${PWD} "\nPossible problem with with ex58_baij, diffs above \n========================================="; \
	${RM} -f ex58.tmp
runex58_sbaij:
	-@${MPIEXEC} -n 1 ./ex58 -mat_type sbaij > ex58.tmp 2>&1;         \
	${DIFF} output/ex58.out ex58.tmp || echo ${PWD} "\nPossible problem with with ex58_sbaij, diffs above \n========================================="; \
	${RM} -f ex58.tmp
TESTEXAMPLES_C		       = ex1.PETSc runex1 runex1_2 runex1_3 ex1.rm ex2.PETSc runex2 runex2_2 runex2_3 \
                                 runex2_4 runex2_bjacobi runex2_bjacobi_2 runex2_bjacobi_3 runex2_specest_1 runex2_specest_2 \
                                 runex2_chebyest_1 runex2_chebyest_2 runex2_chebyest_3 runex2_chebyest_4 runex2_fbcgs runex2_fbcgs_2 ex2.rm \
                                 ex7.PETSc runex7 ex7.rm ex5.PETSc runex5 runex5_2 ex5.rm \
                                 ex8g.PETSc runex8g_1 runex8g_2 runex8g_3 ex8g.rm \
                                 ex9.PETSc runex9 ex9.rm ex12.PETSc runex12 ex12.rm ex13.PETSc runex13 ex13.rm \
                                 ex15.PETSc runex15 ex15.rm ex16.PETSc runex16 ex16.rm \
                                 ex23.PETSc runex23 runex23_2 ex23.rm  ex25.PETSc runex25 runex25_2 ex25.rm \
                                 ex27.PETSc ex27.rm ex28.PETSc ex28.rm ex29.PETSc  ex29.rm \
                                 ex31.PETSc ex31.rm ex32.PETSc runex32 ex32.rm ex34.PETSc runex34 ex34.rm ex38.PETSc runex38 ex38.rm \
                                 ex43.PETSc runex43 runex43_2 runex43_3 runex43_bjacobi runex43_bjacobi_baij ex43.rm \
                                 ex45.PETSc runex45 runex45_2 ex45.rm \
                                 ex49.PETSc runex49 runex49_2 runex49_3 ex49.rm ex53.PETSc runex53 ex53.rm ex55.PETSc runex55_SA ex55.rm\
                                 ex58.PETSc runex58 runex58_baij runex58_sbaij ex58.rm
TESTEXAMPLES_C_X	       = ex2.PETSc runex2_5 ex2.rm ex5.PETSc runex5_5 ex5.rm ex8.PETSc ex8.rm ex28.PETSc runex28 ex28.rm
TESTEXAMPLES_FORTRAN	       = ex1f.PETSc runex1f ex1f.rm ex2f.PETSc runex2f ex2f.rm ex6f.PETSc ex6f.rm \
                                 ex14f.PETSc runex14f ex14f.rm ex15f.PETSc runex15f ex15f.rm ex22f.PETSc runex22f \
                                 ex22f.rm ex21f.PETSc runex21f ex21f.rm ex45f.PETSc runex45f ex45f.rm
TESTEXAMPLES_FORTRAN_MPIUNI    = ex1f.PETSc runex1f ex1f.rm ex6f.PETSc runex6f ex6f.rm
TESTEXAMPLES_C_X_MPIUNI      = ex1.PETSc runex1 runex1_2 runex1_3 ex1.rm ex2.PETSc runex2 runex2_3 ex2.rm \
                                 ex7.PETSc ex7.rm ex5.PETSc ex5.rm  ex9.PETSc runex9 ex9.rm \
                                 ex23.PETSc runex23 ex23.rm
TESTEXAMPLES_C_COMPLEX	       = ex10.PETSc runex10 ex10.rm ex11.PETSc runex11 ex11.rm ex39.PETSc runex39 ex39.rm ex40.PETSc runex40 ex40.rm
TESTEXAMPLES_DATAFILESPATH     = ex10.PETSc runex10_2 runex10_3 runex10_4 runex10_5 runex10_6 runex10_7 runex10_8 \
                                 runex10_9 runex10_10 runex10_19 runex10_22 runex10_23 runex10_24 runex10_25  runex10_ILU runex10_ILUBAIJ runex10_cg \
                                 runex10_cg_singlereduction runex10_seqaijcrl runex10_mpiaijcrl runex10_seqaijperm runex10_mpiaijperm ex10.rm
# even though ex10.c is -pc_mg_smoothdown na C example to run with -mat_type lusol requires a Fortran compiler, hence
# we list it with the fortran examples
TESTEXAMPLES_FORTRAN_NOCOMPLEX =
TESTEXAMPLES_FORTRAN_COMPLEX   = ex11f.PETSc runex11f ex11f.rm
TESTEXAMPLES_F90	       = ex13f90.PETSc runex13f90 ex13f90.rm
TESTEXAMPLES_13		       = ex3.PETSc ex3.rm ex14f.PETSc ex14f.rm
TESTEXAMPLES_MATLAB_ENGINE     = ex10.PETSc runex10_12  ex10.rm
TESTEXAMPLES_17		       = ex10.PETSc runex10_11 ex10.rm
TESTEXAMPLES_18		       = ex2.PETSc runex2_6 ex2.rm
TESTEXAMPLES_SPAI	       = ex10.PETSc runex10_14 ex10.rm
TESTEXAMPLES_HYPRE	       = ex10.PETSc runex10_15 runex10_16 runex10_17 runex10_18 ex10.rm
TESTEXAMPLES_LUSOL	       = ex10.PETSc runex10_13 ex10.rm
TESTEXAMPLES_MUMPS             = ex10.PETSc runex10_mumps_lu_1 runex10_mumps_lu_2 runex10_mumps_lu_3 runex10_mumps_lu_4 \
				 runex10_mumps_cholesky_1 runex10_mumps_cholesky_2 runex10_mumps_cholesky_3 runex10_mumps_cholesky_4 runex10_mumps_redundant \
                                 runex10_mumps_cholesky_spd_1 runex10_mumps_cholesky_spd_2 ex10.rm ex53.PETSc runex53 runex53_2 ex53.rm \
                                 ex52.PETSc runex52_mumps runex52_mumps_2 ex52.rm
TESTEXAMPLES_SUPERLU           = ex10.PETSc runex10_superlu_lu_1 ex10.rm ex52.PETSc runex52_superlu ex52.rm
TESTEXAMPLES_FFTW              =
TESTEXAMPLES_SUPERLU_DIST      = ex10.PETSc runex10_superlu_dist_lu_1 runex10_superlu_dist_lu_2 runex10_superlu_dist_redundant ex10.rm
TESTEXAMPLES_TXPETSCGPU        = ex10.PETSc runex10_aijcusparse ex10.rm
include ${PETSC_DIR}/conf/test
rm -f Check.dat
make ex45
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -pc_type gamg -ksp_type gmres -pc_gamg_agg_nsmooths 1 -mg_levels_ksp_max_it 1 -mg_levels_ksp_type richardson -ksp_rtol 1.0e-7 -ksp_monitor
#Residual norm 1.82355e+09
#L2Norm = 3.106827e+01
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -ksp_type richardson -pc_type hypre -pc_hypre_type boomeramg -ksp_rtol 1.0e-7 -ksp_monitor
#Residual norm 1.93203e+09
#L2Norm = 2.546364e+01
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -ksp_type gmres -pc_type hypre -pc_hypre_type boomeramg -ksp_rtol 1.0e-7 -ksp_monitor
#Residual norm 6.3083e+09
#L2Norm = 3.766155e+01
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -pc_type gamg -ksp_type gmres -pc_gamg_agg_nsmooths 1 -mg_levels_ksp_max_it 1 -mg_levels_ksp_type richardson -ksp_rtol 1.0e-10 -ksp_monitor
#Residual norm 473554
#L2Norm = 1.573811e-02
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -ksp_type richardson -pc_type hypre -pc_hypre_type boomeramg -ksp_rtol 1.0e-10 -ksp_monitor
#Residual norm 1.39368e+06
#L2Norm = 1.846820e-02
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -ksp_type gmres -pc_type hypre -pc_hypre_type boomeramg -ksp_rtol 1.0e-10 -ksp_monitor
#Residual norm 703125
#L2Norm = 4.971447e-03
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -pc_type gamg -ksp_type gmres -pc_gamg_agg_nsmooths 1 -mg_levels_ksp_max_it 1 -mg_levels_ksp_type richardson -ksp_rtol 1.0e-15 -ksp_monitor
#Residual norm 7.3617
#L2Norm = 3.444358e-07
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -ksp_type richardson -pc_type hypre -pc_hypre_type boomeramg -ksp_rtol 1.0e-15 -ksp_monitor
#Residual norm 28.3279
#L2Norm = 4.487079e-07
#/work/zlwei/PETSc/petsc-dev/linux-gnu-c-nodebug/bin/mpiexec -np 1 ./ex45 -ksp_type gmres -pc_type hypre -pc_hypre_type boomeramg -ksp_rtol 1.0e-15 -ksp_monitor
#Residual norm 81.3155
#L2Norm = 5.140724e-07
Name: Non-Uniform Poisson.docx
Type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131210/317ea090/attachment-0001.docx>
