[petsc-users] Performance of PETSc TS solver
Sat Aug 31 18:10:04 CDT 2013
You can choose the number of rows per process so that each has about the
same number of entries.  "Residual" meant IFunction and/or RHSFunction,
when applicable.
On Aug 31, 2013 3:53 PM, "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov>
wrote:
>  Hi, Jed, I think you have a good point here. The load imbalance might be
> a big problem for us, since the Jaociban matrix is not symmetric, and the
> distributed computation of each part of the Jacobian matrix elements on
> different processor can vary a lot. However, that’s what the matrix looks
> like. Do we have any control over that? And what do you mean by “distribute
> the work for residual evaluation better?” I think I can only distribute the
> Ifunction and Ijacobian computation, but have no control of residual
> evaluation. Isn’t it a black box inside TS?
> For the gprof Barry suggested, I tried to compile with gcc –pg with the
> sequential mode, couldn’t create the gmon.out file after running the
> executable...
> Thanks,
> Shuangshuang
> On 8/30/13 4:57 PM, "Jed gov>" <jedbrown at mcs.anl.gov> wrote:
> "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> > Hello, I'm trying to update some of my status here. I just managed to"
> _distribute_ the work of computing the Jacobian matrix" as you suggested,
> so each processor only computes a part of elements for the Jacobian matrix
> instead of a global Jacobian matrix. I observed a reduction of the
> computation time from 351 seconds to 55 seconds, which is much better but
> still slower than I expected given the problem size is small. (4n functions
> in IFunction, and 4n*4n Jacobian matrix in IJacobian, n = 288).
> > I looked at the log profile again, and saw that most of the computation
> time are still for Functioan Eval and Jacobian Eval:
> > TSStep               600 1.0 5.6103e+01 1.0 9.42e+0825.6 3.0e+06 2.9e+02
> 7.0e+04 93100 99 99 92 152100 99 99110   279
> > TSFunctionEval      2996 1.0 2.9608e+01 4.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 3.0e+04 30  0  0  0 39  50  0  0  0 47     0
> The load imbalance is pretty significant here, so maybe you can
> distribute the work for residual evaluation better?
> > TSJacobianEval      1796 1.0 2.3436e+01 1.0 0.00e+00 0.0 5.4e+02 3.8e+01
> 1.3e+04 39  0  0  0 16  64  0  0  0 20     0
> > Warning -- total time of even greater than time of entire stage --
> something is wrong with the timer
> SNESSolve contains the Jacobian and residual evaluations, as well as
> KSPSolve.  Pretty much all the cost is in those three things.
> > SNESSolve            600 1.0 5.5692e+01 1.1 9.42e+0825.7 3.0e+06 2.9e+02
> 6.4e+04 88100 99 99 84 144100 99 99101   281
> > SNESFunctionEval    2396 1.0 2.3715e+01 3.4 1.04e+06 1.0 0.0e+00 0.0e+00
> 2.4e+04 25  0  0  0 31  41  0  0  0 38     1
> > SNESJacobianEval    1796 1.0 2.3447e+01 1.0 0.00e+00 0.0 5.4e+02 3.8e+01
> > SNESLineSearch      1796 1.0 1.8313e+01 1.0 1.54e+0831.4 4.9e+05 2.9e+02
> 2.5e+04 30 16 16 16 33  50 16 16 16 39   139
> > KSPGMRESOrthog      9090 1.0 1.1399e+00 4.1 1.60e+07 1.0 0.0e+00 0.0e+00
> 9.1e+03  1  3  0  0 12   2  3  0  0 14   450
> > KSPSetUp            3592 1.0 2.8342e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 3.0e+01  0  0  0  0  0   0  0  0  0  0     0
> > KSPSolve            1796 1.0 2.3052e+00 1.0 7.87e+0825.2 2.5e+06 2.9e+02
> 2.0e+04  4 84 83 83 26   6 84 83 83 31  5680
> > PCSetUp             3592 1.0 9.1255e-02 1.7 6.47e+05 2.5 0.0e+00 0.0e+00
> 1.8e+01  0  0  0  0  0   0  0  0  0  0   159
> > PCSetUpOnBlocks     1796 1.0 6.6802e-02 2.3 6.47e+05 2.5 0.0e+00 0.0e+00
> 1.2e+01  0  0  0  0  0   0  0  0  0  0   217
> > PCApply            10886 1.0 2.6064e-01 1.3 4.70e+06 1.5 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   1  1  0  0  0   481
> > I was wondering why SNESFunctionEval and SNESJacobianEval took over 23
> > seconds each, however, the KSPSolve only took 2.3 seconds, which is 10
> > times faster. Is this normal? Do you have any more suggestion on how
> > to reduce the FunctionEval and JacobianEval time?
> It means that the linear systems are easy to solve (probably because
> they are small), but the IFunction and IJacobian are expensive.  As
> Barry says, you might be able to speed it up by sequential optimization.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130831/5e03af92/attachment.html>
