[petsc-users] Optimized run crashes on one machine but not another
Thu Aug 29 06:32:52 CDT 2013
On Thu, Aug 29, 2013 at 1:45 AM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
> Hi Matt,
> I figured out what was causing the problems. I never had
> an optimized build built on my laptop before. So I did not
> run the reconfigure script but had to build from scratch.
> I recently changed my build script to keep only what was
> required for this project. By mistake, the --download-chaco
> was taken out. Hence, the code was running on all debug
> builds + optimized build on the desktop and crashed on
> my laptop.
> Once I rebuilt 3.4.2 it crashed for all builds since chaco
> was not available on any of them now. The IS of
> the partition returned here was corrupt.
> plex.c line 2503
Crap! Thats a bug. Thanks for finding it. I will fix it in next today.
    Matt
>     if (1) {
> #if defined(PETSC_HAVE_CHACO)
>       ierr = DMPlexPartition_Chaco(dm, numVertices, start, adjacency,
> partSection, partition);CHKERRQ(ierr);
> #endif
>     } else {
> #if defined(PETSC_HAVE_PARMETIS)
>       ierr = DMPlexPartition_ParMetis(dm, numVertices, start, adjacency,
> #endif
> I do have parmetis installed but I do not know why it did not
> work.
> Since you were able to run the code it helped a lot. The
> code runs on all builds/machines now without any problems
> once chaco was downloaded.
> Thanks a lot for the help.
> Regards,
> Garnet
> On Wed, Aug 28, 2013 at 7:22 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Aug 28, 2013 at 4:53 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Garnet Vaz <garnet.vaz at gmail.com> writes:
>>> > Hi Matt,
>>> > Within gdb how can I view an IS? I tried 'call ISView(*partition,0)'
>>> > following the VecView() syntax but it causes a segmentation fault
>>> > inside gdb.
>>> That'll work if you're passing an IS and it's not already corrupt.
>> Just to recap, I have run in both debug and optimized with complex, and
>> through valgrind,
>> and I get no problems on my machine (using downloaded MPICH).
>> I think we will need you to narrow it down with the debugger there.
>>   Thanks,
>>      Matt
>> experiments lead.
>> -- Norbert Wiener
> Regards,
> Garnet
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130829/74d4d981/attachment.html>
