[petsc-users] use kspsolve repeately
Sat Aug 24 07:00:40 CDT 2013
On Sat, Aug 24, 2013 at 6:48 AM, 丁老师 <ztdepyahoo at 163.com> wrote:
>    thank you . but the matrix element has been changed in the third and
> fourth call. how to re calculate the preconditioner.
Don't give SAME_PRECONDITIONER, and read the KSP section of the manual.
   Matt
> 在 2013-08-24 18:18:17,"Matthew Knepley" <knepley at gmail.com> 写道:
> On Sat, Aug 24, 2013 at 4:57 AM, 丁老师 <ztdepyahoo at 163.com> wrote:
>> in  my code, i need to use kspsolve in the following way
>>     KSP ksp;
>>     KSPCreate(PETSC_COMM_WORLD,&ksp);
>>     KSPSetOperators(ksp,A,A,SAME_NONZERO_PATTERN);
>>     KSPSetOperators(ksp,A,A,SAME_PRECONDITIONER);
>>     KSPSetInitialGuessNonzero(ksp,PETSC_TRUE)
>>      KSPSetType(ksp,KSPBCGS);
>>     KSPSetFromOptions(ksp);
>>   set the matrix A value and right hand side bu and bv.
>>     kspsolve(A,bu);
>>     kspsolve(A,bv);
>>   change the value of matrix A and bu bv,
>>      kspsolve(A,bu);
>>      kspsolve(A,bv);
>>  the first and second call to the kspsolve use the same preconditioner.
>> but which preconditoner does the third and fourth call to the kspsolve
>> since the value of the matrix A has changed.
> The first call is redundant, and the subsequent solves use the same
> preconditioner, as you asked.
>    Matt
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130824/98abc7fa/attachment.html>
