[petsc-users] use kspsolve repeately
丁老师 ztdepyahoo at 163.com
Sat Aug 24 06:48:14 CDT 2013
   thank you . but the matrix element has been changed in the third and fourth call. how to re calculate the preconditioner.
在 2013-08-24 18:18:17,"Matthew Knepley" <knepley at gmail.com> 写道:
On Sat, Aug 24, 2013 at 4:57 AM, 丁老师 <ztdepyahoo at 163.com> wrote:
in  my code, i need to use kspsolve in the following way
    KSP ksp;
    KSPCreate(PETSC_COMM_WORLD,&ksp);
    KSPSetOperators(ksp,A,A,SAME_NONZERO_PATTERN);
    KSPSetOperators(ksp,A,A,SAME_PRECONDITIONER);
    KSPSetInitialGuessNonzero(ksp,PETSC_TRUE)
     KSPSetType(ksp,KSPBCGS);
    KSPSetFromOptions(ksp);
  set the matrix A value and right hand side bu and bv.
    kspsolve(A,bu);
    kspsolve(A,bv);
  change the value of matrix A and bu bv,
     kspsolve(A,bu);
     kspsolve(A,bv);
 the first and second call to the kspsolve use the same preconditioner. but which preconditoner does the third and fourth call to the kspsolve since the value of the matrix A has changed.
The first call is redundant, and the subsequent solves use the same preconditioner, as you asked.
   Matt
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130824/7dc23678/attachment.html>
