[petsc-users] Attach approximate null space to a fieldsplit block
Tue Aug 20 13:00:14 CDT 2013
"Garth N. Wells" <gnw20 at cam.ac.uk> writes:
>>> Note that if you use MatSetValuesLocal, you can use the
>>> NEST format with identical code in assembly; only matrix creation is
>>> different, see src/snes/example/tutorials/ex28.c for an example that
>>> works with both AIJ and NEST formats.
> Is there a reason why MatSetValues can't be used? We rely on PETSc
> caching and then communicating off-process entries.
MatSetValuesLocal() just takes indices described in a local ordering
(defined by their mapping to global indices, see
MatSetLocalToGlobalMapping), but you can still set global indices.
A global-to-global map is expensive/non-scalable, so we can't
efficiently support it when assembling sub-blocks that correspond to
general index sets.
The MatSetValuesLocal interface also makes a number of other domain
decomposition methods accessible.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130820/b9d0d1f6/attachment.pgp>
