[petsc-users] Should I synchronize processes explicitly, for instance using MPI_Barrier?
Fri Aug 16 06:54:30 CDT 2013
On Fri, Aug 16, 2013 at 6:31 AM, Cong Li <solvercorleone at gmail.com> wrote:
> Hi, Matthew
> Thank you very much for the answer.
> And I met a new problem.
> When there some PetscScalar type data operations before the VecWAXPY call,
> for example
> PetscScalar, a,b, c;
> c=a+b;
> ierr = VecWAXPY(r, c, Ax, b);CHKERRQ(ierr);
> , should I add MPI_Barrier call right before VecWAXPY call ?
Never put in a barrier.
   Matt
> Best regards
> Cong
> On Fri, Aug 16, 2013 at 7:56 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Aug 16, 2013 at 2:11 AM, Cong Li <solvercorleone at gmail.com>wrote:
>>> Hi
>>> I am a rookie to PETSc, and I am wondering about whether I should call
>>> MPI_Barrier to explicitly synchronize processes between PETSc calls.
>>> For example, a piece of code like below
>>>   ierr = MatMult(A,x,Ax); CHKERRQ(ierr);
>>>   ierr = VecWAXPY(r, neg_one, Ax, b);CHKERRQ(ierr);
>>> Should I add MPI_Barrier inbetween MatMult call and VecWAXPY call ?
>> No
>>    Matt
>>> My guess is that it is unnecessary. However, I am not so confident in
>>> this guess, for I don't have much experience on using PETSc.
>>> Thanks in advance.
>>> Cong Li
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130816/10a52a1d/attachment.html>
