[petsc-users] Iterative solution for schur complement
Umut Tabak u.tabak at tudelft.nl
Wed Aug 14 14:39:50 CDT 2013
Dear all,
I am looking at a system where I am trying to investigate this
ill-conditioned problem with some iterative tricks or not. Namely, the
system that I try to solve is
(B - C^T A^{-1}C) x2 = b2
which results from block symmetric representation
A  C
C^T B
Unfortunately, B is indefinite, I tried some tries in MATLAB but none of
them gave convergence. What I tried is listed below:
+ Even if B is indefinite, it is symmetric, and I am trying to use its
LDLT decomposition as a preconditioner for the above system. Besides, I
am also using the LDLT for the matrix vector multiplications which comes
from A^{-1} related terms. I am not forming the operator matrix here but
it is a function handle that represents the matrix-vector
multiplication. Also the preconditioner solve related to B2 is also a
function handle. Of course in this case, my preconditioner B is not SPD
however it is the direct factor of B. Due to this reason, I was
expecting to get better results while using also the direct
factorization of A2.
+ The strange thing in MATLAB is that CG fails on the very first
iteration due to the reason that some parameters are too small to
continue, I can understand this since that implicitly boils down to the
Cholesky decomposition of the projected system. But minres also fails
with the same error. I am hesitating whether I shall program minres or
gmres myself to detect the source of the problem, any ideas on where the
problem might come from, especially while using minres?
+ C matrix can be relatively sparse in comparison to A and B which is a
coupling matrix, I am not sure if I can make use of this information or not?
+ Are there any SPD preconditioners that I can try with this system? I
guess the above mentioned break down is also related to the selection of
the preconditioner although I am not sure on this.
Any other pointers and ideas are appreciated on this problem.
Best regards,
Umut
