[petsc-users] MUMPS memory allocation problem
Thu Sep 13 16:27:07 CDT 2012
No point wasting time debugging such archaeological relics. There have been
numerous improvements and bug fixes to both packages since then. You should
upgrade to petsc-3.3 which also has the latest MUMPS.
On Thu, Sep 13, 2012 at 4:24 PM, Lukasz Kaczmarczyk <
Lukasz.Kaczmarczyk at glasgow.ac.uk> wrote:
> Hello,
> I use petsc-3.1-p3 and MUMPS_4.9.2.  I hope that this will help, it is
> tricky to track the error, usually is for relatively large problems,  I
> have to check if it happens always at the same time, or is random error.
> CYCLE 19 ref_mesh 0
> Vol = 1.6749e+08 ave_Vol = 4.2698e+03 min_quali = 1.7609e-01
> Nodes Ordering
> Elemnets Ordering
> arc length lambda 4.4581e-01
> arc length lambda value 5.6751e+02
>   0 SNES Function norm 7.929158005697e+01
>   0 SNES (MY) norms Fint 6.7783e+01, arc length res_lambda 0.0000e+00
> lambda 4.4581e-01
>     0 KSP (MY) F 9.0999e-01 Res 1.0000e+00
>     1 KSP (MY) F 3.8659e-15 Res 4.4892e-15
>     PC ArcLength norm dF_dLambda 5.8658e+03 norm dD_dF_dLambda 3.29e+01
> b_dD_dF_dLambda 0.00e+00
>     0 KSP (MY) norms F 6.7783e+01 Res 7.9292e+01 res arc length lambda
> 0.0000e+00 dlambda 0.0000e+00
>     1 KSP (MY) norms F 9.1576e-14 Res 9.9498e-14 res arc length lambda
>   1 SNES Function norm 2.355295496832e-02
>   1 SNES (MY) norms Fint 2.0118e-02, arc length res_lambda 0.0000e+00
> lambda 4.4581e-01
> At line 593 of file dmumps_part3.F
> Fortran runtime error: Attempt to DEALLOCATE unallocated 'perm'
> mpirun has exited due to process rank 3 with PID 25487 on
> node rdb-srv1 exiting without calling "finalize". This may
> have caused other processes in the application to be
> terminated by signals sent by mpirun (as reported here).
> On 13 Sep 2012, at 21:23, Hong Zhang wrote:
> > Lukasz :
> > Hello,
> > I solve a strongly nonlinear problem using SNES. When I use MUMS with
> petsc form time to time I get following error,
> > I've never seen report from our users about this error.
> > Can you provide more info about it, e.g., run with a debugger and find
> > error stack showing which routine and the line number that the error
> occurs?
> > Which version of petsc and mumps do you use?
> > Does it work on petsc examples, e.g.
> > petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec -n 4 ./ex2 -pc_type lu
> -pc_factor_mat_solver_package mumps
> > Norm of error 2.71948e-15 iterations 1
> > Hong
> > Other solvers (f.e. SuperLU Dist) working without problems. Is this know
> issue with MUMPS and similar problem where reported in past?
> > Lukasz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120913/c3a84b6a/attachment.html>
