[petsc-users] MUMPS memory allocation problem
Lukasz Kaczmarczyk Lukasz.Kaczmarczyk at glasgow.ac.uk
Thu Sep 13 16:24:05 CDT 2012
Hello,
I use petsc-3.1-p3 and MUMPS_4.9.2.  I hope that this will help, it is tricky to track the error, usually is for relatively large problems,  I have to check if it happens always at the same time, or is random error.
CYCLE 19 ref_mesh 0
Vol = 1.6749e+08 ave_Vol = 4.2698e+03 min_quali = 1.7609e-01
Nodes Ordering
Elemnets Ordering
arc length lambda 4.4581e-01
arc length lambda value 5.6751e+02
  0 SNES Function norm 7.929158005697e+01
  0 SNES (MY) norms Fint 6.7783e+01, arc length res_lambda 0.0000e+00 lambda 4.4581e-01
    0 KSP (MY) F 9.0999e-01 Res 1.0000e+00
    1 KSP (MY) F 3.8659e-15 Res 4.4892e-15
    PC ArcLength norm dF_dLambda 5.8658e+03 norm dD_dF_dLambda 3.29e+01 b_dD_dF_dLambda 0.00e+00
    0 KSP (MY) norms F 6.7783e+01 Res 7.9292e+01 res arc length lambda 0.0000e+00 dlambda 0.0000e+00
    1 KSP (MY) norms F 9.1576e-14 Res 9.9498e-14 res arc length lambda 0.0000e+00 dlambda 0.0000e+00
  1 SNES Function norm 2.355295496832e-02
  1 SNES (MY) norms Fint 2.0118e-02, arc length res_lambda 0.0000e+00 lambda 4.4581e-01
At line 593 of file dmumps_part3.F
Fortran runtime error: Attempt to DEALLOCATE unallocated 'perm'
mpirun has exited due to process rank 3 with PID 25487 on
node rdb-srv1 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
On 13 Sep 2012, at 21:23, Hong Zhang wrote:
> Lukasz :
> Hello,
> I solve a strongly nonlinear problem using SNES. When I use MUMS with petsc form time to time I get following error,
> I've never seen report from our users about this error.
> Can you provide more info about it, e.g., run with a debugger and find
> error stack showing which routine and the line number that the error occurs?
> Which version of petsc and mumps do you use?
> Does it work on petsc examples, e.g.
> petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec -n 4 ./ex2 -pc_type lu -pc_factor_mat_solver_package mumps
> Norm of error 2.71948e-15 iterations 1
> Hong
> Other solvers (f.e. SuperLU Dist) working without problems. Is this know issue with MUMPS and similar problem where reported in past?
> Lukasz
