[petsc-users] MG Preconditioning
Sat Sep 1 19:24:51 CDT 2012
On Sat, Sep 1, 2012 at 6:31 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
> Never mind.
> I figured out the problem.
> I was creating the transpose of the restriction operator with
> MatCreateTranspose()
> But the PTAP operation requires an actual matrix so you need to run
> MatTranspose()
> To create an actual transpose.
For what it's worth, it's better to assemble P directly than to assemble R
and MatTranspose().
> Slowly making progress.
> Thanks,
> Gaetan
> On Sat, Sep 1, 2012 at 7:02 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
>> Hi Jed
>> That commit fixes the mg->galerkin issue.
>> I'm still having issues with the projection/restriction matrices. Are the
>> projection/restriction matrices supposed to be serial matrices operating on
>> the unknowns on each processor even when running in parallel?
>> Thanks,
>> Gaetan
>> On Sat, Sep 1, 2012 at 6:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Sep 1, 2012, at 5:16 PM, Gaetan Kenway <kenway at utias.utoronto.ca>
>>> wrote:
>>> > Hi Jed
>>> > After probing why the following code snippit isn't run:
>>> >   if (mg->galerkin == 1) {
>>> >     Mat B;
>>> >     /* currently only handle case where mat and pmat are the same on
>>> coarser levels */
>>> >         dB   = B;
>>> > It is because after I use  PCMGSetGalerkin(),  mg->galerkin has a
>>> value of -1 not 1. From what I can tell the value of PETSC_TRUE is
>>> architecture/implementation dependant.  I can't see where/how the value of
>>> mg->galerkin obtains a value of 1 and runs the code above.
>>> > As for the other issue, after converting my baij matrix to aij,
>>> running MatRART() is ok.
>>> > So we just have to figure out why calling
>>> >   call PCMGSetGalerkin(pc, PETSC_TRUE, PETScIerr)
>>> >   call EChk(PETScIerr,__FILE__,__LINE__)
>>> > sets mg->galerkin to a value of -1 and the code above is expecting a
>>> value of 1.
>>>     This is a mistake with our Fortran interface.  Some Fortran
>>> compilers (for what crazy reason I don't know) use -1 as bool for true.
>>> Normally this doesn't matter because we have if (boolvalue) { checks and so
>>> negative one and one work the same way;
>>>     But the code   mg->galerkin = (PetscInt)use;  in PCMGSetGalekin()
>>> fails because we then check the numerical value of the result, instead of
>>> just if it is zero or nonzero.
>>>      I can change this conversion to   mg->galerkin = use ?  1 : 0  so
>>> the the Fortran use of -1 gets converted to one and this should resolve the
>>> problem.
>>>     I have pushed this fix into the petsc-3.3 and petsc-dev
>>> repositories. If you are using 3.3 I've attached a new
>>> src/ksp/pc/impls/mg/mg.c that you can drop into that directory and run make
>>> in that directory to update your library. If you are using petsc-dev then
>>> do an hg pull -u and rerun make in that directory.[see attached file: mg.c]
>>>     Thanks for determining the cause of this rather nasty bug.
>>>    Barry
>>> > Gaetan
>>> > On Sat, Sep 1, 2012 at 5:34 PM, Jed Brown <jedbrown at mcs.anl.gov>
>>> wrote:
>>> > On Sat, Sep 1, 2012 at 4:20 PM, Gaetan Kenway <
>>> kenway at utias.utoronto.ca> wrote:
>>> > Sorry about the last email...I hit sent it too early.
>>> > The full calling sequence is:
>>> >   call KSPCreate(SUMB_COMM_WORLD, ksp, PETScIerr)
>>> >   useAD = .False.
>>> >   useTranspose = .True.
>>> >   usePC = .True.
>>> >   call setupStateResidualMatrix(drdwpret,useAD,usePC,useTranspose)
>>> >  ! dRdwT has already been created
>>> >   call KSPSetOperators(ksp, dRdWT, dRdwpreT, &
>>> >        DIFFERENT_NONZERO_PATTERN, PETScIerr)
>>> >   call KSPSetFromOptions(ksp, PETScIerr)
>>> >   call KSPSetType(ksp, KSPFGMRES, PETScIerr)
>>> >   call KSPGMRESSetRestart(ksp, adjRestart, PETScIerr)
>>> >   call KSPGMRESSetCGSRefinementType(ksp, &
>>> >        KSP_GMRES_CGS_REFINE_IFNEEDED, PETScIerr)
>>> >   call kspgetpc(ksp, pc, PETScIerr)
>>> >   call pcsettype(pc, PCMG, PETScIerr)
>>> >   call PetscOptionsSetValue('-pc_mg_levels','2',PETScIerr)
>>> >  ! Set command line options
>>> >   call PCSetFromOptions(pc, PETScIerr)
>>> >   ! Create the restriction operator between finest and one below:
>>> >   call createRestrictOperator(RL1, 1)
>>> >   call PCMGSetRestriction(pc, 1, RL1, PETScierr)
>>> >   call PCSetup(pc, PETScierr)
>>> >  The error occurs in PCSetup() which calls PCSetup_MG() and the issue
>>> is in KSPGetVecs() on line 644 in mg.c. Just to clarify, this isn't a
>>> memory problem/segfault.
>>> > The output below is a SEGV.
>>> > PETSc returns control cleanly and I my code exits when the error is
>>> detected. Therefore a backtrace or valgrind doesn't yield any additional
>>> information. ( I Ran both).
>>> > You can still set a breakpoint in PetscError (-start_in_debugger /
>>> -on_error_attach_debugger does this automatically). Then you can examine
>>> the stack.
>>> > The terminal output is:
>>> > [0]PETSC ERROR:
>>> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>> probably memory access out of range
>>> > [0]PETSC ERROR: Try option -start_in_debugger or
>>> > [0]PETSC ERROR: or see
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>>> corruption errors
>>> > [0]PETSC ERROR: likely location of problem given in stack below
>>> > [0]PETSC ERROR: ---------------------  Stack Frames
>>> > PETSc or MPI Error. Error Code 73. Detected on Proc  0
>>> > Error at line:   130 in file: setupPETScKsp.F90
>>> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> > [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>> function
>>> > [0]PETSC ERROR:       is given.
>>> > [0]PETSC ERROR: [0] MatGetVecs line 8142
>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/mat/interface/matrix.c
>>> > [0]PETSC ERROR: [0] KSPGetVecs line 774
>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/iterativ.c
>>> > [0]PETSC ERROR: [0] PCSetUp_MG line 508
>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/mg.c
>>> > [0]PETSC ERROR: [0] PCSetUp line 810
>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/interface/precon.c
>>> > I had a look at ex42.c but it uses a DM which I am not doing.
>>> > It uses the DM for convenience to build the operators, but it does
>>> *not* tell the KSP about the DM. That is, it does not call KSPSetDM() or
>>> PCSetDM(). So the code in mg.c does not know about the DM.
>>> > From the example there is the following:
>>> > ierr = PCMGSetLevels(pc,nlevels,PETSC_NULL);CHKERRQ(ierr);
>>> >   ierr = PCMGSetType(pc,PC_MG_MULTIPLICATIVE);CHKERRQ(ierr);
>>> >   ierr = PCMGSetGalerkin(pc,PETSC_TRUE);CHKERRQ(ierr);
>>> >   for (k=1; k<nlevels; k++){
>>> >     ierr =
>>> DMCreateInterpolation(da_list[k-1],da_list[k],&R,PETSC_NULL);CHKERRQ(ierr);
>>> >     ierr = PCMGSetInterpolation(pc,k,R);CHKERRQ(ierr);
>>> >     ierr = MatDestroy(&R);CHKERRQ(ierr);
>>> > Is there anything special about "R" in this case?
>>> > Nothing special, it is just an MAIJ matrix that performs the
>>> interpolation.
>>> > As I mentioned before, I know what the issue is, the coarse grid
>>> operators are not set at all. From what I can tell, they should be set in
>>> the routine PCSetup_MG in mg.c, but the code is never run unless pc->dm is
>>> True.
>>> > What code is not run unless pc->dm?
>>> > I guess I'll just create the operators myself. Even if I modify the
>>> code to make it enter the if statement at line 577
>>> > You called PCMGSetGalerkin() so the code below should run,
>>> constructing the coarse levels. You could try setting a breakpoint in there
>>> to see why it's not running.
>>> >     Mat B;
>>> coarser levels */
>>> >     ierr =
>>> KSPGetOperators(mglevels[n-1]->smoothd,&dA,&dB,&uflag);CHKERRQ(ierr);
>>> >     if (!pc->setupcalled) {
>>> >       for (i=n-2; i>-1; i--) {
>>> >         ierr =
>>> MatPtAP(dB,mglevels[i+1]->interpolate,MAT_INITIAL_MATRIX,1.0,&B);CHKERRQ(ierr);
>>> >         ierr =
>>> KSPSetOperators(mglevels[i]->smoothd,B,B,uflag);CHKERRQ(ierr);
>>> >         if (i != n-2) {ierr =
>>> PetscObjectDereference((PetscObject)dB);CHKERRQ(ierr);}
>>> >         dB   = B;
>>> >       if (n > 1) {ierr =
>>> >     } else {
>>> >         ierr =
>>> KSPGetOperators(mglevels[i]->smoothd,PETSC_NULL,&B,PETSC_NULL);CHKERRQ(ierr);
>>> >         ierr =
>>> MatPtAP(dB,mglevels[i+1]->interpolate,MAT_REUSE_MATRIX,1.0,&B);CHKERRQ(ierr);
>>> >         ierr =
>>> >         dB   = B;
>>> > which seems like where it should be done....the MatPTAP will not run.
>>> > What do you mean "will not run"?
>>> > I'm using a mpibaij matrix for 'dRdwPreT' and my restriction matrix
>>> 'RL1' is a mpiaij matrix. When I try to run  MatRART myself with the code:
>>> >  call MatRART(dRdwT, RL1, MAT_INITIAL_MATRIX, 1.0, newMat, PETScIERR)
>>> > I receive error code 56: /* no support for requested operation */
>>> (this is a clean exit from PETSc)
>>> > MatRARt (or MatPtAP, for that matter) is not implemented for BAIJ with
>>> an AIJ projection. The AIJ projection will lose the block structure anyway,
>>> so just use AIJ for both.
>>> > In conclusion, I have two issues: 1) The coarse grid operators are not
>>> being set automatically in mg.c. 2) Using MatRART() with a mpibaij matrix
>>> and a mpiaij matrix is unsupported.
>>> > Is there a PCMG example that doesn't use a DM to generate the
>>> restriction/prolongation/matrix information I can have a look at?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120901/7abc26b8/attachment.html>
