[petsc-users] MG Preconditioning
Gaetan Kenway kenway at utias.utoronto.ca
Sat Sep 1 18:31:52 CDT 2012
Never mind.
I figured out the problem.
I was creating the transpose of the restriction operator with
MatCreateTranspose()
But the PTAP operation requires an actual matrix so you need to run
MatTranspose()
To create an actual transpose.
Slowly making progress.
Gaetan
On Sat, Sep 1, 2012 at 7:02 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
> Hi Jed
> That commit fixes the mg->galerkin issue.
> I'm still having issues with the projection/restriction matrices. Are the
> projection/restriction matrices supposed to be serial matrices operating on
> the unknowns on each processor even when running in parallel?
> Thanks,
> Gaetan
> On Sat, Sep 1, 2012 at 6:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Sep 1, 2012, at 5:16 PM, Gaetan Kenway <kenway at utias.utoronto.ca>
>> wrote:
>> > Hi Jed
>> > After probing why the following code snippit isn't run:
>> >   if (mg->galerkin == 1) {
>> >     Mat B;
>> >     /* currently only handle case where mat and pmat are the same on
>> coarser levels */
>> >         dB   = B;
>> > It is because after I use  PCMGSetGalerkin(),  mg->galerkin has a value
>> of -1 not 1. From what I can tell the value of PETSC_TRUE is
>> architecture/implementation dependant.  I can't see where/how the value of
>> mg->galerkin obtains a value of 1 and runs the code above.
>> > As for the other issue, after converting my baij matrix to aij, running
>> MatRART() is ok.
>> > So we just have to figure out why calling
>> >   call PCMGSetGalerkin(pc, PETSC_TRUE, PETScIerr)
>> >   call EChk(PETScIerr,__FILE__,__LINE__)
>> > sets mg->galerkin to a value of -1 and the code above is expecting a
>> value of 1.
>>     This is a mistake with our Fortran interface.  Some Fortran compilers
>> (for what crazy reason I don't know) use -1 as bool for true. Normally this
>> doesn't matter because we have if (boolvalue) { checks and so negative one
>> and one work the same way;
>>     But the code   mg->galerkin = (PetscInt)use;  in PCMGSetGalekin()
>> fails because we then check the numerical value of the result, instead of
>> just if it is zero or nonzero.
>>      I can change this conversion to   mg->galerkin = use ?  1 : 0  so
>> the the Fortran use of -1 gets converted to one and this should resolve the
>> problem.
>>     I have pushed this fix into the petsc-3.3 and petsc-dev repositories.
>> If you are using 3.3 I've attached a new src/ksp/pc/impls/mg/mg.c that you
>> can drop into that directory and run make in that directory to update your
>> library. If you are using petsc-dev then do an hg pull -u and rerun make in
>> that directory.[see attached file: mg.c]
>>     Thanks for determining the cause of this rather nasty bug.
>>    Barry
>> > Gaetan
>> > On Sat, Sep 1, 2012 at 5:34 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> > On Sat, Sep 1, 2012 at 4:20 PM, Gaetan Kenway <kenway at utias.utoronto.ca>
>> wrote:
>> > Sorry about the last email...I hit sent it too early.
>> > The full calling sequence is:
>> >   call KSPCreate(SUMB_COMM_WORLD, ksp, PETScIerr)
>> >   useAD = .False.
>> >   useTranspose = .True.
>> >   usePC = .True.
>> >   call setupStateResidualMatrix(drdwpret,useAD,usePC,useTranspose)
>> >  ! dRdwT has already been created
>> >   call KSPSetOperators(ksp, dRdWT, dRdwpreT, &
>> >        DIFFERENT_NONZERO_PATTERN, PETScIerr)
>> >   call KSPSetFromOptions(ksp, PETScIerr)
>> >   call KSPSetType(ksp, KSPFGMRES, PETScIerr)
>> >   call KSPGMRESSetRestart(ksp, adjRestart, PETScIerr)
>> >   call KSPGMRESSetCGSRefinementType(ksp, &
>> >        KSP_GMRES_CGS_REFINE_IFNEEDED, PETScIerr)
>> >   call kspgetpc(ksp, pc, PETScIerr)
>> >   call pcsettype(pc, PCMG, PETScIerr)
>> >   call PetscOptionsSetValue('-pc_mg_levels','2',PETScIerr)
>> >  ! Set command line options
>> >   call PCSetFromOptions(pc, PETScIerr)
>> >   ! Create the restriction operator between finest and one below:
>> >   call createRestrictOperator(RL1, 1)
>> >   call PCMGSetRestriction(pc, 1, RL1, PETScierr)
>> >   call PCSetup(pc, PETScierr)
>> >  The error occurs in PCSetup() which calls PCSetup_MG() and the issue
>> is in KSPGetVecs() on line 644 in mg.c. Just to clarify, this isn't a
>> memory problem/segfault.
>> > The output below is a SEGV.
>> > PETSc returns control cleanly and I my code exits when the error is
>> detected. Therefore a backtrace or valgrind doesn't yield any additional
>> information. ( I Ran both).
>> > You can still set a breakpoint in PetscError (-start_in_debugger /
>> -on_error_attach_debugger does this automatically). Then you can examine
>> the stack.
>> > The terminal output is:
>> > [0]PETSC ERROR:
>> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> > [0]PETSC ERROR: Try option -start_in_debugger or
>> > [0]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>> corruption errors
>> > [0]PETSC ERROR: likely location of problem given in stack below
>> > [0]PETSC ERROR: ---------------------  Stack Frames
>> > PETSc or MPI Error. Error Code 73. Detected on Proc  0
>> > Error at line:   130 in file: setupPETScKsp.F90
>> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> > [0]PETSC ERROR:       INSTEAD the line number of the start of the
>> function
>> > [0]PETSC ERROR:       is given.
>> > [0]PETSC ERROR: [0] MatGetVecs line 8142
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/mat/interface/matrix.c
>> > [0]PETSC ERROR: [0] KSPGetVecs line 774
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/iterativ.c
>> > [0]PETSC ERROR: [0] PCSetUp_MG line 508
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/mg.c
>> > [0]PETSC ERROR: [0] PCSetUp line 810
>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/interface/precon.c
>> > I had a look at ex42.c but it uses a DM which I am not doing.
>> > It uses the DM for convenience to build the operators, but it does
>> *not* tell the KSP about the DM. That is, it does not call KSPSetDM() or
>> PCSetDM(). So the code in mg.c does not know about the DM.
>> > From the example there is the following:
>> > ierr = PCMGSetLevels(pc,nlevels,PETSC_NULL);CHKERRQ(ierr);
>> >   ierr = PCMGSetType(pc,PC_MG_MULTIPLICATIVE);CHKERRQ(ierr);
>> >   ierr = PCMGSetGalerkin(pc,PETSC_TRUE);CHKERRQ(ierr);
>> >   for (k=1; k<nlevels; k++){
>> >     ierr =
>> DMCreateInterpolation(da_list[k-1],da_list[k],&R,PETSC_NULL);CHKERRQ(ierr);
>> >     ierr = PCMGSetInterpolation(pc,k,R);CHKERRQ(ierr);
>> >     ierr = MatDestroy(&R);CHKERRQ(ierr);
>> > Is there anything special about "R" in this case?
>> > Nothing special, it is just an MAIJ matrix that performs the
>> interpolation.
>> > As I mentioned before, I know what the issue is, the coarse grid
>> operators are not set at all. From what I can tell, they should be set in
>> the routine PCSetup_MG in mg.c, but the code is never run unless pc->dm is
>> True.
>> > What code is not run unless pc->dm?
>> > I guess I'll just create the operators myself. Even if I modify the
>> code to make it enter the if statement at line 577
>> > You called PCMGSetGalerkin() so the code below should run, constructing
>> the coarse levels. You could try setting a breakpoint in there to see why
>> it's not running.
>> >     Mat B;
>> coarser levels */
>> >     ierr =
>> KSPGetOperators(mglevels[n-1]->smoothd,&dA,&dB,&uflag);CHKERRQ(ierr);
>> >     if (!pc->setupcalled) {
>> >       for (i=n-2; i>-1; i--) {
>> >         ierr =
>> MatPtAP(dB,mglevels[i+1]->interpolate,MAT_INITIAL_MATRIX,1.0,&B);CHKERRQ(ierr);
>> >         ierr =
>> KSPSetOperators(mglevels[i]->smoothd,B,B,uflag);CHKERRQ(ierr);
>> >         if (i != n-2) {ierr =
>> PetscObjectDereference((PetscObject)dB);CHKERRQ(ierr);}
>> >         dB   = B;
>> >       if (n > 1) {ierr =
>> >     } else {
>> >         ierr =
>> KSPGetOperators(mglevels[i]->smoothd,PETSC_NULL,&B,PETSC_NULL);CHKERRQ(ierr);
>> >         ierr =
>> MatPtAP(dB,mglevels[i+1]->interpolate,MAT_REUSE_MATRIX,1.0,&B);CHKERRQ(ierr);
>> >         ierr =
>> >         dB   = B;
>> > which seems like where it should be done....the MatPTAP will not run.
>> > What do you mean "will not run"?
>> > I'm using a mpibaij matrix for 'dRdwPreT' and my restriction matrix
>> 'RL1' is a mpiaij matrix. When I try to run  MatRART myself with the code:
>> >  call MatRART(dRdwT, RL1, MAT_INITIAL_MATRIX, 1.0, newMat, PETScIERR)
>> > I receive error code 56: /* no support for requested operation */ (this
>> is a clean exit from PETSc)
>> > MatRARt (or MatPtAP, for that matter) is not implemented for BAIJ with
>> an AIJ projection. The AIJ projection will lose the block structure anyway,
>> so just use AIJ for both.
>> > In conclusion, I have two issues: 1) The coarse grid operators are not
>> being set automatically in mg.c. 2) Using MatRART() with a mpibaij matrix
>> and a mpiaij matrix is unsupported.
>> > Is there a PCMG example that doesn't use a DM to generate the
>> restriction/prolongation/matrix information I can have a look at?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120901/e38970c7/attachment-0001.html>
