[petsc-users] MG Preconditioning
Gaetan Kenway kenway at utias.utoronto.ca
Sat Sep 1 16:20:49 CDT 2012
Sorry about the last email...I hit sent it too early.
The full calling sequence is:
  call KSPCreate(SUMB_COMM_WORLD, ksp, PETScIerr)
  call EChk(PETScIerr,__FILE__,__LINE__)
  useAD = .False.
  useTranspose = .True.
  usePC = .True.
  call setupStateResidualMatrix(drdwpret,useAD,usePC,useTranspose)
 ! dRdwT has already been created
  call KSPSetOperators(ksp, dRdWT, dRdwpreT, &
       DIFFERENT_NONZERO_PATTERN, PETScIerr)
  call KSPSetFromOptions(ksp, PETScIerr)
  call KSPSetType(ksp, KSPFGMRES, PETScIerr)
  call KSPGMRESSetRestart(ksp, adjRestart, PETScIerr)
  call KSPGMRESSetCGSRefinementType(ksp, &
       KSP_GMRES_CGS_REFINE_IFNEEDED, PETScIerr)
  call kspgetpc(ksp, pc, PETScIerr)
  call pcsettype(pc, PCMG, PETScIerr)
  call PetscOptionsSetValue('-pc_mg_levels','2',PETScIerr)
 ! Set command line options
  call PCSetFromOptions(pc, PETScIerr)
  call PCMGSetGalerkin(pc, PETSC_TRUE, PETScIerr)
  ! Create the restriction operator between finest and one below:
  call createRestrictOperator(RL1, 1)
  call PCMGSetRestriction(pc, 1, RL1, PETScierr)
  call PCSetup(pc, PETScierr)
 The error occurs in PCSetup() which calls PCSetup_MG() and the issue is in
KSPGetVecs() on line 644 in mg.c. Just to clarify, this isn't a memory
problem/segfault. PETSc returns control cleanly and I my code exits when
the error is detected. Therefore a backtrace or valgrind doesn't yield any
additional information. ( I Ran both). The terminal output is:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR:
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
PETSc or MPI Error. Error Code 73. Detected on Proc  0
Error at line:   130 in file: setupPETScKsp.F90
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] MatGetVecs line 8142
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] KSPGetVecs line 774
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/iterativ.c
[0]PETSC ERROR: [0] PCSetUp_MG line 508
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: [0] PCSetUp line 810
/nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/interface/precon.c
I had a look at ex42.c but it uses a DM which I am not doing. From the
example there is the following:
ierr = PCMGSetLevels(pc,nlevels,PETSC_NULL);CHKERRQ(ierr);
  ierr = PCMGSetType(pc,PC_MG_MULTIPLICATIVE);CHKERRQ(ierr);
  ierr = PCMGSetGalerkin(pc,PETSC_TRUE);CHKERRQ(ierr);
  for (k=1; k<nlevels; k++){
    ierr =
DMCreateInterpolation(da_list[k-1],da_list[k],&R,PETSC_NULL);CHKERRQ(ierr);
    ierr = PCMGSetInterpolation(pc,k,R);CHKERRQ(ierr);
    ierr = MatDestroy(&R);CHKERRQ(ierr);
Is there anything special about "R" in this case? As I mentioned before, I
know what the issue is, the coarse grid operators are not set at all. From
what I can tell, they should be set in the routine PCSetup_MG in mg.c, but
the code is never run unless pc->dm is True.  I guess I'll just create the
operators myself. Even if I modify the code to make it enter the if
statement at line 577
  if (mg->galerkin == 1) {
    Mat B;
    /* currently only handle case where mat and pmat are the same on
coarser levels */
    ierr =
KSPGetOperators(mglevels[n-1]->smoothd,&dA,&dB,&uflag);CHKERRQ(ierr);
    if (!pc->setupcalled) {
      for (i=n-2; i>-1; i--) {
        ierr =
MatPtAP(dB,mglevels[i+1]->interpolate,MAT_INITIAL_MATRIX,1.0,&B);CHKERRQ(ierr);
        ierr =
KSPSetOperators(mglevels[i]->smoothd,B,B,uflag);CHKERRQ(ierr);
        if (i != n-2) {ierr =
PetscObjectDereference((PetscObject)dB);CHKERRQ(ierr);}
        dB   = B;
      if (n > 1) {ierr =
    } else {
        ierr =
KSPGetOperators(mglevels[i]->smoothd,PETSC_NULL,&B,PETSC_NULL);CHKERRQ(ierr);
        ierr =
MatPtAP(dB,mglevels[i+1]->interpolate,MAT_REUSE_MATRIX,1.0,&B);CHKERRQ(ierr);
        ierr =
        dB   = B;
which seems like where it should be done....the MatPTAP will not run. I'm
using a mpibaij matrix for 'dRdwPreT' and my restriction matrix 'RL1' is a
mpiaij matrix. When I try to run  MatRART myself with the code:
 call MatRART(dRdwT, RL1, MAT_INITIAL_MATRIX, 1.0, newMat, PETScIERR)
I receive error code 56: /* no support for requested operation */ (this is
a clean exit from PETSc)
In conclusion, I have two issues: 1) The coarse grid operators are not
being set automatically in mg.c. 2) Using MatRART() with a mpibaij matrix
and a mpiaij matrix is unsupported.
Is there a PCMG example that doesn't use a DM to generate the
restriction/prolongation/matrix information I can have a look at?
Gaetan
On Sat, Sep 1, 2012 at 4:54 PM, Gaetan Kenway <kenway at utias.utoronto.ca>wrote:
>   useAD = .False.
>   usePC = .True.
> On Sat, Sep 1, 2012 at 3:27 PM, Jed Brown <five9a2 at gmail.com> wrote:
>> Can you send the whole calling sequence and the full error message? It's
>> not clear from your email how to reproduce. You might also look at
>> src/ksp/ksp/examples/tutorials/ex42.c which uses PCMGSetGalerkin. Did you
>> set the fine grid operators before calling PCSetUp()? The coarse grid
>> operators should have been constructed earlier in PCSetUp_MG().
>>  On Sep 1, 2012 10:05 AM, "Gaetan Kenway" <kenway at utias.utoronto.ca>
>> wrote:
>>> I believe I partially tracked down my problem. The issue arises at line
>>> 644 in mg.c with a call to KSPGetVecs(). This is used to get the coarse
>>> grid vectors for the RHS. The issue is that up until this point, the actual
>>> operator for mglevels[i]->smoothd have not actually been set and therefore
>>> it cannot get the vectors.
>>> I am using
>>> with the intention of having the coarse matrices approximately
>>> automatically. However, from looking over the code, it appears when it is
>>> used in this manner, the coarse grid operators never get set. From what I
>>> can tell, it is only possible to create these matrices automatically if
>>> (pc->dm) is True which I think means that the preconditioner is derived
>>> from a distributed matrix.
>>> I've set my own restriction operator, but mg->galerkin has a value of -1
>>> in mg.c and none of the KSPSetOperators() are executed.
>>> I've also tried to generate the matrices myself using MatRARt() or
>>> MatPtAP, but I receive error code 56 "* /* no support for requested
>>> operation */" . *Is this op only implemented from matrices derived from
>>> from DM objects?
>>> Any other suggestions for creating the coarse grid operators manually?
>>> Thank you,
>>> Gaetan
>>> On Sat, Sep 1, 2012 at 12:29 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> On Fri, Aug 31, 2012 at 11:22 PM, Gaetan Kenway <
>>>> kenway at utias.utoronto.ca> wrote:
>>>>> Hi Again
>>>>> I also tried petsc-3.2 version and I still get the same backtrace.
>>>>> If its not possible to figure out where the communicator segfault is
>>>>> coming from its not a huge deal...I've just set the option using
>>>>> PetscOptionsSetValue() and then use PCSetFromOptions() to pull it back out.
>>>>>  That seems to work fine.
>>>>> Even avoiding the above problem, with the PetscOptionsSetValue I'm
>>>>> still receiving an error code 73 when I run the multigrid solver.  I've
>>>>> included the backtrace output below but its not a lot of help since the
>>>>> code exited cleaning using my error checking procedure
>>>>> Error at line:   122 in file: solveADjointTransposePETSc.F90
>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>> 0xb68c98f0 in PMPI_Abort () from /usr/local/lib/libmpi.so.0
>>>>> (gdb) bt
>>>>> #0  0xb68c98f0 in PMPI_Abort () from /usr/local/lib/libmpi.so.0
>>>>> #1  0xb519f190 in pmpi_abort__ () from /usr/local/lib/libmpi_f77.so.0
>>>>> #2  0xb44c9e4c in echk (ierr=@0x49, file=..., line=@0x7a,
>>>>> .tmp.FILE.len_V$eb=30) at terminate.f90:154
>>>>> #3  0xb44bd68f in solveadjointtransposepetsc () at
>>>>> solveADjointTransposePETSc.F90:122
>>>>> #4  0xb44138a9 in f2py_rout_sumb_solveadjointtransposepetsc () from
>>>>> /tmp/tmpKYF_DT/sumb.so
>>>>> #5  0xb440fd35 in fortran_call () from /tmp/tmpKYF_DT/sumb.so
>>>>> #6  0x0805fd6a in PyObject_Call ()
>>>>> #7  0x080dd5b0 in PyEval_EvalFrameEx ()
>>>>> #8  0x080dfbb2 in PyEval_EvalCodeEx ()
>>>>> #9  0x08168f1f in ?? ()
>>>>> #10 0x0805fd6a in PyObject_Call ()
>>>>> #11 0x080dcbeb in PyEval_EvalFrameEx ()
>>>>> #12 0x080dfbb2 in PyEval_EvalCodeEx ()
>>>>> #13 0x080de145 in PyEval_EvalFrameEx ()
>>>>> #14 0x080dfbb2 in PyEval_EvalCodeEx ()
>>>>> #15 0x080dfca7 in PyEval_EvalCode ()
>>>>> #16 0x080fd956 in PyRun_FileExFlags ()
>>>>> #17 0x080fdbb2 in PyRun_SimpleFileExFlags ()
>>>>> #18 0x0805b6d3 in Py_Main ()
>>>>> #19 0x0805a8ab in main ()
>>>>  This stack doesn't involve PETSc at all.
>>>>> Valgrid was clean right up until the end where I get the normal error
>>>>> message:
>>>>> [0]PETSC ERROR:
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>>>> corruption errors
>>>>> available,
>>>>> function
>>>>> [0]PETSC ERROR: [0] KSPSetUp line 182
>>>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/itfunc.c
>>>>> [0]PETSC ERROR: [0] KSPSolve line 351
>>>>> I will try it on a different system tomorrow to see if I have any more
>>>>> luck.
>>>>> Thanks,
>>>>> Gaetan
>>>>> On Fri, Aug 31, 2012 at 11:08 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>> On Fri, Aug 31, 2012 at 10:06 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> True, but the backtrace also shows that comm = 0x0 on the call to
>>>>>>> KSPCreate(), which
>>>>>>> leads me to believe that your petsc4py has not initialized PETSc,
>>>>>>> and therefor not
>>>>>>> initialized PETSC_COMM_WORLD.
>>>>>> Could catch, maybe PetscFunctionBegin() should check that PETSc has
>>>>>> been initialized.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120901/55613cc5/attachment-0001.html>
