[petsc-users] MG Preconditioning
Gaetan Kenway kenway at utias.utoronto.ca
Sat Sep 1 15:54:15 CDT 2012
The full calling sequence is:
  call KSPCreate(SUMB_COMM_WORLD, ksp, PETScIerr)
  call EChk(PETScIerr,__FILE__,__LINE__)
  useAD = .False.
  useTranspose = .True.
  usePC = .True.
  call setupStateResidualMatrix(drdwpret,useAD,usePC,useTranspose)
  call KSPSetOperators(ksp, dRdWT, dRdwpreT, &
       DIFFERENT_NONZERO_PATTERN, PETScIerr)
  call KSPSetFromOptions(ksp, PETScIerr)
  call KSPSetType(ksp, KSPFGMRES, PETScIerr)
  call KSPGMRESSetRestart(ksp, adjRestart, PETScIerr)
  call KSPGMRESSetCGSRefinementType(ksp, &
       KSP_GMRES_CGS_REFINE_IFNEEDED, PETScIerr)
  call kspgetpc(ksp, pc, PETScIerr)
  call pcsettype(pc, PCMG, PETScIerr)
  call PetscOptionsSetValue('-pc_mg_levels','2',PETScIerr)
 ! Set command line options
  call PCSetFromOptions(pc, PETScIerr)
  call PCMGSetGalerkin(pc, PETSC_TRUE, PETScIerr)
  ! Create the restriction operator between finest and one below:
  call createRestrictOperator(RL1, 1)
  call PCMGSetRestriction(pc, 1, RL1, PETScierr)
  call PCSetup(pc, PETScierr)
On Sat, Sep 1, 2012 at 3:27 PM, Jed Brown <five9a2 at gmail.com> wrote:
> Can you send the whole calling sequence and the full error message? It's
> not clear from your email how to reproduce. You might also look at
> src/ksp/ksp/examples/tutorials/ex42.c which uses PCMGSetGalerkin. Did you
> set the fine grid operators before calling PCSetUp()? The coarse grid
> operators should have been constructed earlier in PCSetUp_MG().
> On Sep 1, 2012 10:05 AM, "Gaetan Kenway" <kenway at utias.utoronto.ca> wrote:
>> I believe I partially tracked down my problem. The issue arises at line
>> 644 in mg.c with a call to KSPGetVecs(). This is used to get the coarse
>> grid vectors for the RHS. The issue is that up until this point, the actual
>> operator for mglevels[i]->smoothd have not actually been set and therefore
>> it cannot get the vectors.
>> I am using
>> with the intention of having the coarse matrices approximately
>> automatically. However, from looking over the code, it appears when it is
>> used in this manner, the coarse grid operators never get set. From what I
>> can tell, it is only possible to create these matrices automatically if
>> (pc->dm) is True which I think means that the preconditioner is derived
>> from a distributed matrix.
>> I've set my own restriction operator, but mg->galerkin has a value of -1
>> in mg.c and none of the KSPSetOperators() are executed.
>> I've also tried to generate the matrices myself using MatRARt() or
>> MatPtAP, but I receive error code 56 "* /* no support for requested
>> operation */" . *Is this op only implemented from matrices derived from
>> from DM objects?
>> Any other suggestions for creating the coarse grid operators manually?
>> Thank you,
>> Gaetan
>> On Sat, Sep 1, 2012 at 12:29 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Fri, Aug 31, 2012 at 11:22 PM, Gaetan Kenway <
>>>> Hi Again
>>>> I also tried petsc-3.2 version and I still get the same backtrace.
>>>> If its not possible to figure out where the communicator segfault is
>>>> coming from its not a huge deal...I've just set the option using
>>>> PetscOptionsSetValue() and then use PCSetFromOptions() to pull it back out.
>>>>  That seems to work fine.
>>>> Even avoiding the above problem, with the PetscOptionsSetValue I'm
>>>> still receiving an error code 73 when I run the multigrid solver.  I've
>>>> included the backtrace output below but its not a lot of help since the
>>>> code exited cleaning using my error checking procedure
>>>> PETSc or MPI Error. Error Code 73. Detected on Proc  0
>>>> Error at line:   122 in file: solveADjointTransposePETSc.F90
>>>> Program received signal SIGSEGV, Segmentation fault.
>>>> 0xb68c98f0 in PMPI_Abort () from /usr/local/lib/libmpi.so.0
>>>> (gdb) bt
>>>> #0  0xb68c98f0 in PMPI_Abort () from /usr/local/lib/libmpi.so.0
>>>> #1  0xb519f190 in pmpi_abort__ () from /usr/local/lib/libmpi_f77.so.0
>>>> #2  0xb44c9e4c in echk (ierr=@0x49, file=..., line=@0x7a,
>>>> .tmp.FILE.len_V$eb=30) at terminate.f90:154
>>>> #3  0xb44bd68f in solveadjointtransposepetsc () at
>>>> solveADjointTransposePETSc.F90:122
>>>> #4  0xb44138a9 in f2py_rout_sumb_solveadjointtransposepetsc () from
>>>> /tmp/tmpKYF_DT/sumb.so
>>>> #5  0xb440fd35 in fortran_call () from /tmp/tmpKYF_DT/sumb.so
>>>> #6  0x0805fd6a in PyObject_Call ()
>>>> #7  0x080dd5b0 in PyEval_EvalFrameEx ()
>>>> #8  0x080dfbb2 in PyEval_EvalCodeEx ()
>>>> #9  0x08168f1f in ?? ()
>>>> #10 0x0805fd6a in PyObject_Call ()
>>>> #11 0x080dcbeb in PyEval_EvalFrameEx ()
>>>> #12 0x080dfbb2 in PyEval_EvalCodeEx ()
>>>> #13 0x080de145 in PyEval_EvalFrameEx ()
>>>> #14 0x080dfbb2 in PyEval_EvalCodeEx ()
>>>> #15 0x080dfca7 in PyEval_EvalCode ()
>>>> #16 0x080fd956 in PyRun_FileExFlags ()
>>>> #17 0x080fdbb2 in PyRun_SimpleFileExFlags ()
>>>> #18 0x0805b6d3 in Py_Main ()
>>>> #19 0x0805a8ab in main ()
>>>  This stack doesn't involve PETSc at all.
>>>> Valgrid was clean right up until the end where I get the normal error
>>>> message:
>>>> [0]PETSC ERROR:
>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably memory access out of range
>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>>>> corruption errors
>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,
>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>>> function
>>>> [0]PETSC ERROR:       is given.
>>>> [0]PETSC ERROR: [0] MatGetVecs line 8142
>>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/mat/interface/matrix.c
>>>> [0]PETSC ERROR: [0] KSPGetVecs line 774
>>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/iterativ.c
>>>> [0]PETSC ERROR: [0] PCSetUp_MG line 508
>>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/impls/mg/mg.c
>>>> [0]PETSC ERROR: [0] PCSetUp line 810
>>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/pc/interface/precon.c
>>>> [0]PETSC ERROR: [0] KSPSetUp line 182
>>>> /nfs/mica/home/kenway/Downloads/petsc-3.3/src/ksp/ksp/interface/itfunc.c
>>>> [0]PETSC ERROR: [0] KSPSolve line 351
>>>> I will try it on a different system tomorrow to see if I have any more
>>>> luck.
>>>> Thanks,
>>>> Gaetan
>>>> On Fri, Aug 31, 2012 at 11:08 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>> On Fri, Aug 31, 2012 at 10:06 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> True, but the backtrace also shows that comm = 0x0 on the call to
>>>>>> KSPCreate(), which
>>>>>> leads me to believe that your petsc4py has not initialized PETSc, and
>>>>>> therefor not
>>>>>> initialized PETSC_COMM_WORLD.
>>>>> Could catch, maybe PetscFunctionBegin() should check that PETSc has
>>>>> been initialized.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120901/4655e00d/attachment.html>
