[petsc-users] When pull the petsc-dev for update:Connection timed out
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Sun Nov 25 18:35:02 CST 2012
Thank you so much, Dr. Brown.
    Another little question is that:
        After I update the PETSc, the ${PETSC_ARCH}/conf/bin/mpiexec
does not work and shows:
[mpiexec at ...edu] set_default_values (./ui/mpich/utils.c:1541): no
executable provided
[mpiexec at ...edu] HYD_uii_mpx_get_parameters (./ui/mpich/utils.c:1745):
setting default values failed
[mpiexec at ...edu] main (./ui/mpich/mpiexec.c:154): error parsing parameters
        Any idea on this?
thanks,
Alan
> Sounds like you didn't "hg update" and had a bad mergetool or
> something. You can use hg revert to discard any local changes. Since
> you have many stale files around, you may want to use hg clean (this
> will delete all untracked files!) to get back to a state like if you
> had a fresh clone.
> On Mon, Nov 26, 2012 at 1:25 AM, Zhenglun (Alan) Wei
> <zhenglun.wei at gmail.com <mailto:zhenglun.wei at gmail.com>> wrote:
>>     On Mon, Nov 26, 2012 at 12:59 AM, Zhenglun (Alan) Wei
>>         Dear Sean,
>>              Thank you so much for your help. Here I have another
>>         question.
>>              After updating the PETSc, I tried to 'make ex45' in
>>         /src/ksp/ksp/example/tutorial/. It says that 'petscksp.h' can
>>         not be found; therefore, I commented this library in ex45.c
>>         to see what will happen. It, then, shows that the
>>         'petscdmmg.h' can not be found. Any idea on this? :)
>>     Since DMMG is gone, baby gone, this means your environment
>>     (PETSC_DIR) is still pointing to an old version of PETSc.
>          Since my PETSc was updated, the PETSC_DIR of the new version
>     of the PETSc should be the same as the old version of the PETSc,
>     isn't it?
>          BTW, it works after I re-configure and make the PETSc.
>     However, I found that it as a lot of dummy things in the ex45.c, i.e.:
>     <<<<<<<<<<local
>     >>>>>>>>>other
>          It seems that the update changes the original program of
>     ex45.c by adding fractions of the new code into the old code. It
>     confused me a lot. Is there any way that I can just replace the
>     old code by the new code?
>     thanks,
>     Alan
>>         thanks,
>>         Alan
>>             On Sun, Nov 25, 2012 at 4:16 PM, Zhenglun (Alan) Wei
>>             wrote:
>>                 Thank you Sean,
>>                     I changed the
>>                 $ cd config/buildsystem
>>                 $ hg showconfig paths.default
>>                     to
>>                 https://bitbucket.org/petsc/buildsystem
>>                    It gives me 2 extra changes.
>>             Great! Glad to know it's working.
>>                  Although, it always giev me the warning of
>>                 'certificate not verified',
>>                 it updated lots of files. Should I just ignore this
>>                 warning?
>>             You could ignore those warnings, yes, but it would
>>             probably be better
>>             to upgrade your mercurial and see if the host fingerprint
>>             option
>>             works. Or you could try to use the ssh protocol, assuming
>>             your
>>             university proxy allows ssh out.
>>                    BTW, the reason I used 'https' instead of 'http'
>>                 is that 'https' is shown
>>                 in the website you gave to me. :) It may needs to be
>>                 changed.
>>             Well, as I said previously, bitbucket redirects all http
>>             traffic to
>>             https, so I don't think changing it to just http would
>>             really work.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121125/6350a34d/attachment-0001.html>
