[petsc-users] When pull the petsc-dev for update:Connection timed out
Alan zhenglun.wei at gmail.com
Sun Nov 25 12:30:13 CST 2012
Thanks Sean,
      my /petsc-dev/.hg/hgrc shows:
[paths]
default = https://bitbucket.org/petsc/petsc-dev
[hostfingerprints]
bitbucket.org = 24:9c:45:8b:9c:aa:ba:55:4e:01:6d:58:ff:e4:28:7d:2a:14:ae:3b
      When pulling the petsc-dev, it shows:
abort: no certificate for bitbucket.org with configured hostfingerprint
      The same thing happens if it pull the BuildSystem with:
[paths]
default = https://bitbucket.org/petsc/buildsystem
thanks,
Alan
> On Sun, Nov 25, 2012 at 12:09 PM, Alan <zhenglun.wei at gmail.com> wrote:
>> Thanks Sean,
>>      I tried the method you recommend. However, it shows;
>> warning: bitbucket.org certificate not verified (check web.cacerts config
>> setting)
> To suppress that warning, you could add this to your ~/.hgrc
> [hostfingerprints]
>>      I missed this step:
>> [Optional:] For ssh access - register your public ssh key at: 'YourName' ->
>> 'Account' -> 'SSH keys'.
>>      Since I think it is a option.
> This is only if you want to push (over ssh as opposed to https). If
> you don't plan on patching petsc, you don't need this option. You can
> always change it later since it's just changing the wire protocol
> method.
>>      When it pulls the petsc-dev, it is fine. However, when it pulls the
>> BuildSystem, it says:
>>   abort: repository is unrelated
>>      What should I do for this?
> What does $PETSC_DIR/config/buildsystem/.hg/hgrc contain? The
> default url should be
> [paths]
