[petsc-users] When pull the petsc-dev for update:Connection timed out
Alan zhenglun.wei at gmail.com
Sun Nov 25 12:09:25 CST 2012
Thanks Sean,
     I tried the method you recommend. However, it shows;
warning: bitbucket.org certificate not verified (check web.cacerts
config setting)
     I missed this step:
[Optional:] For ssh access - register your public ssh key at:'YourName'
-> 'Account' -> 'SSH keys'.
     Since I think it is a option.
     When it pulls the petsc-dev, it is fine. However, when it pulls the
BuildSystem, it says:
  abort: repository is unrelated
     What should I do for this?
thanks,
Alan
> On Sun, Nov 25, 2012 at 11:05 AM, Alan <zhenglun.wei at gmail.com> wrote:
>> Dear folks,
>> I hope you had a nice Thanksgiving.
>> I was trying to 'hg pull -u' for the PETSc development update; however,
>> an error message saying:
>> abort: error: Connection timed out
>> Is the update server down? Or what should I do for this? I tested that
>> my internet is on.
> Unfortunately, the petsc.cs.iit.edu server died. So, we moved the
> repos to bitbucket,
> http://www.mcs.anl.gov/petsc/developers/mercurial-hosting.html
> Basically, you just need to change the urls in your
> $PETSC_DIR/.hg/hgrc and $PETSC_DIR/config/buildsystem/.hg/hgrc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121125/31fbe1ca/attachment.html>
