[petsc-users] When pull the petsc-dev for update:Connection timed out
Sean Farley sean at mcs.anl.gov
Sun Nov 25 11:32:12 CST 2012
On Sun, Nov 25, 2012 at 11:05 AM, Alan <zhenglun.wei at gmail.com> wrote:
> Dear folks,
> I hope you had a nice Thanksgiving.
> I was trying to 'hg pull -u' for the PETSc development update; however,
> an error message saying:
> abort: error: Connection timed out
> Is the update server down? Or what should I do for this? I tested that
> my internet is on.
Unfortunately, the petsc.cs.iit.edu server died. So, we moved the
repos to bitbucket,
http://www.mcs.anl.gov/petsc/developers/mercurial-hosting.html
Basically, you just need to change the urls in your
$PETSC_DIR/.hg/hgrc and $PETSC_DIR/config/buildsystem/.hg/hgrc
