[petsc-users] Creating PCFieldSplit Preconditioner in source code
Thomas Witkowski thomas.witkowski at tu-dresden.de
Mon Nov 19 01:29:43 CST 2012
In the implementation of my Navier-Stokes solver, I initialize the
PCFieldSplit preconditioner in my source code (thus not on the command
line) in the following way:
     PCSetType(pc, PCFIELDSPLIT);
     PCFieldSplitSetType(pc, PC_COMPOSITE_SCHUR);
     PCFieldSplitSetSchurFactType(pc, PC_FIELDSPLIT_SCHUR_FACT_FULL);
     KSPSetUp(ksp);
     KSP *subKsp;
     PetscInt nSubKsp;
     PCFieldSplitGetSubKSP(pc, &nSubKsp, &subKsp);
     KSP kspVelocity = subKsp[0];
     KSP kspSchur = subKsp[1];
And then kspVelocity and kspSchur are filled with appropriate options.
The point is now, that to get the sub solver objects, I have to run
KSPSetUp before. In this case, the sub solver objects are also
initialized with some predefined options (block jacobi ILU), which I
don't need and what takes some time and memory. Is there any other way
to get the sub solver objects before and to initialize than the outer
solver correctly with the inner solver I have specified?
Thomas
